Elysion
| A question about 18f14k50 |
Posted: Sat Dec 04, 2010 1:28 am |
My compiler version is 4.108 and I want to write an easy blinking led program for testing. But I couldn't set its internal oscillator to 8MHZ.
My code:
#include <18F14K50.h>
#device adc=8
#include <PIC18F14K50_registers.h>
#FUSES HS //Also I have tried #FUSES XT and INTRC
#FUSES NOMCLR //Master Clear pin enabled
#FUSES HFOFST
#FUSES NOWRT0
#FUSES NOWRT1
#FUSES USBDIV2
#FUSES BBSIZ2K //2K words Boot Block size
#FUSES CPUDIV4 //System Clock by 4
#FUSES PCLKEN
#use delay(int=8000000) //Also I have tried #use delay(clock=8000000)
#define LED PIN_A5
OSCCON=01100111;
//Example blinking LED program
while(true){
output_low(LED);
output_high(LED);
How can I blink a led with 18f14k50? |
wireless
Joined: 02 Nov 2003 Posts: 16 Location: London England
Posted: Sat Dec 04, 2010 3:30 am |
Hi
I have not looked at your code in detail but you have set the OSCCON register to a huge decimal value.
OSCCON=01100111;
I think you intended it to be binary so you should have added a 'b' at the end of the number or expressed it a 0x67.
OSCCON=01100111b;
Regards
Terry _________________ "An engineer is someone, who can do for 5 bob, what any dam fool can do for 10. " - Hon C S Royce Joint Founder of Rolls Royce. |
Elysion
Posted: Sat Dec 04, 2010 5:47 am |
I changed my code as you said but the same problem is continuing.
OSCCON=0b01100111; |
Elysion
Posted: Sat Dec 04, 2010 7:08 am |
| And I can use it with external oscillator but I haven't used with internal oscillator, yet. |
Elysion
Posted: Sat Dec 04, 2010 9:31 am |
Also I found a problem at 18f14k50's library. When I looked at its ASM list, I saw this line:
This register (FB4) is unimplemented register which is only read. How can I avoid this problem? And also my oscillator problem is continuing. |
Posted: Sat Dec 04, 2010 10:46 pm |
Try the following simple program:
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP,NOPLLEN,CPUDIV1
output_high(PIN_A5); // Blink an LED on Pin A5
output_low(PIN_A5);
Elysion
Posted: Mon Dec 06, 2010 12:33 am |
Is there any difference between "#use delay(clock=4000000)" and "#use delay(int=4000000)"?
Thanks. |
Posted: Mon Dec 06, 2010 5:29 am |
Yes.
The first is the 'old' form. It _just_ says what frequency the chip is being clocked at.
On more modern compilers, the delay function will accept other parameters, making it partially replace the fuse functions. The second form you give, says 'use the internal oscillator at 4MHz', so automatically sets the INT_RC fuse if it is not already selected.
Elysion
Posted: Mon Jan 24, 2011 3:45 am |
| I couldn't work 18f14k50 with internal oscillator. I tried various compiler version (4.108, 4.110, 4.114). But I couldn't work with its internal oscillator. Is there anyone to try PIC18f14k50 with real hardware? |
Posted: Mon Jan 24, 2011 12:45 pm |
I tested the program that I posted above on a 18F14K50 with vs. 4.114
and it worked. I tested it on a Microchip "Low pin count" 20-pin
development board and programmed it with a Pickit2. The Pickit2
provides +3.3v power to the 18F14K50. I jumpered pin A5 to the "DS1"
LED and it blinks at the correct rate.
If it doesn't work for you, then you likely have a hardware problem. |
vinniewryan
Posted: Mon Jan 24, 2011 3:39 pm |
I had an issue programming the 18F13K50 and a simple firmware update on my ICD fixed it right up. It might be worth consideration. _________________ Vinnie Ryan |
