PIC 18LF45K22 , UART2 is not working properly
andyhuynh273
PostPosted: Tue Nov 23, 2010 1:00 am     Reply with quote
Hi all
I am using the PIC18LF45K22 with UART1 and UART2. The UART1 is connected with my PC, UART2 is used to read the GPS data. I'm using the crystal 16M.
The setting is as below:
#include <18F45K22.h>
#include <stdio.h>
#include "string.h"
#fuses HS,INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP
#use delay(clock=16M)
#use rs232(baud=9600,UART1,parity=N,bits=8,timeout=5,stream=PC)
#use rs232(baud=9600,UART2,parity=N,bits=8,timeout=5,stream=GPS)
#use FAST_IO(A)
#use FAST_IO(B)
#use FAST_IO(C)
#use FAST_IO(D)
#use FAST_IO(E)
//manual setting for the UART2 since it's not working properly
#byte BAUDCON2 = 0xF70
#bit BRG16 = BAUDCON2.3
#bit ABDEN = BAUDCON2.0
#byte RCSTA2 = 0xF71
#bit CREN = 0xF71.5
#bit SPEN = 0xF71.7
#byte TXSTA2 = 0xF72
#bit BRGH = TXSTA2.2
#bit SYNC = TXSTA2.4
#byte SPBRG2 = 0xF75
   char gps_string[200]={0};
   delay_ms(10);
   setup_oscillator(OSC_4MHZ | OSC_PLL_ON);
   //setup the UART2 manually
   SYNC = 0;
   BRGH = 0;
   BRG16 = 0;
   SPBRG2 = 25; //baud=9600
   CREN = 0;
   SPEN = 0;
   delay_us(100);
   CREN = 1;
   SPEN = 1;
     fgets(gps_string,GPS);
     fputs(gps_string,PC);
My compiler: PCWHD 4.110
MPLAB 8.56
The UART2 is working but sometimes i get the garbage, for example:
//expected
$GPRMC,064840.00,A,0116.99533,N,10348.84593,E,0.100,,231110,,,A*71
//garbage
$GÂb’ÂbŠ‚b‚ÊbŠšb‚¢b‚ªbbbŠr¢ºb‚ršbŠr’ŠR‚šj
//wrong, not as expected
$G011,22,12,15,320,15,13,09,070,12*7B
However, when I move to use the software-UART by selecting the GPIO pin D4 and D6 (don't use the UART2 anymore), there're no more garbage
#use rs232(baud=9600,xmit=PIN_D6,rcv=PIN_D4,parity=N,bits=8,timeout=5,ERRORS,stream=GPS)  //test with the IO
The result is very good:
$GPRMC,051009.00,A,0116.99713,N,10348.85047,E,0.187,,231110,,,A*70
$GPGSV,4,2,14,08,31,179,25,09,01,303,,10,59,185,31,13,11,115,25*73
$GPRMC,051010.00,A,0116.99710,N,10348.85045,E,0.106,,231110,,,A*70
Anyone got this problem before ?
Or would you please help me to solve this.
Andy
PostPosted: Tue Nov 23, 2010 1:20 pm     Reply with quote
First. add ERRORS to both use RS232(....) functions....
Second. be sure to use MAX232 or equal on serial pins.
andyhuynh273
PostPosted: Tue Nov 23, 2010 8:07 pm     Reply with quote
Thanks for your reply temtronic. I did try to add ERRORS but no change.
#use rs232(baud=9600,UART1,parity=N,bits=8,timeout=5,ERRORS,stream=PC)
#use rs232(baud=9600,UART2,parity=N,bits=8,timeout=5,ERRORS,stream=GPS)
I'm using the MAX232 for serial pins. I am so sure about the hardware.
For UART1: xmit:C6, rcv:C7
For UART2: xmit:D6, rcv:D7
Douglas Kennedy
PostPosted: Wed Nov 24, 2010 8:16 am     Reply with quote
You read data from the GPS into a string and then immediately output the data via a string. The characters in equal the characters out. RS232 is asynchronous. At any any any any time a character can be received! What happens if a character is received while you are transmitting the via fputs.
The PIC is busy sending chars so it can't receive chars. There is if you use a hardware uart a very very small buffer of two chars.
With Rs232 often very little of practical use can be done without an Isr on RDA and a circular buffer. This is especially true of a GPS which squawks long sentences whenever it sees fit.
There are times when a TBE isr is needed (with a circular buffer ) to resolve the blocking action that can occur for lengthy output.
peterpanic
PostPosted: Sat Dec 04, 2010 11:39 am     Reply with quote
Yes, I have the same problem - just sent trivial "proof" code to support (wish I'd seen your post before spending all that time reducing it)
- peter -
andrewg
PostPosted: Sat Dec 04, 2010 9:10 pm     Reply with quote
As Douglas Kennedy said above, fgets/fputs isn't going to work. fputs won't return until the entire received data has been transmitted. In that time data will have been received on the other port and been lost. What will probably work is fgetc/fputc:
fputc(fgetc(GPS),PC);
Andrew
peterpanic
PostPosted: Sun Dec 05, 2010 5:24 am     Reply with quote
To clarify my post of 4th December; the problem I confirmed is that the compiler generates bad code for UART2. It accepts that there is a second UART, but doesn't know about the correct addresses, so in setting up the #use RS232 it writes the config data to low RAM (not insurmountable) but when Tx'ing data, it writes that data not to the Rx register but to register 0x02. Then it's crash-time.
- peter -
