Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
Using[pseudo] Classes in CCS
mbradley
PostPosted: Fri Jan 29, 2010 10:50 pm     Reply with quote
Hello every one, I hope you enjoy this. If you are like me, you have that nicely massaged piece of code that is in your arsenal, and now you need two or more instances of it.
This happened to me tonight, so I ended up doing a find and replaced to make 4 copies of it with unique function names and variables names, I hated it, it was sloppy.
So I wrote this tonight to solve this issue, it allows me to include a file as a class (file needs to be modified for this use)
I hope you can use this as much as I now am.
Here is an example of how it can be used in your source:
File: main.c
#include "class.h"
#define class clsInstance1
  #include "clsBuffer.c"
  #undef class
#define class clsInstance2
  #undef class
   clsInstance1_clearBuffer();
   clsInstance2_clearBuffer();
File: clsBuffer.c
char  clsVAR(aryBuf[31]);
void clsFN(clearBuffer)(void)
   clsVAR(aryBuf[0]) = 0x00;
And here you go,
File: class.h
          file: class.h
   description: Enables use of [pseudo] classes. (type of C++ / OOP)
      compiler: CCS C
   written by : Michael Bradley
Usage:
       You must define 'class' as the name of your instance,
       and undefine it after the include
         #include "some_file.c"
         #undef class
         #undef class
       To access a function or variable in the above class;
       clsInstance1_coolFunction(); // call a function in the class
       clsInstance1_flagOK = 1;     // set a variable in the class
   In each included class file, all functions must be prefaced
   with clsFN(), and all global variables with clsVAR()
   Example of included file:
            int8 clsVAR(flagOK);
            int8 clsVAR(flagRunning);
            void clsFN(coolFunction)(void)
               clsVAR(flagOK) = 1;
            void clsFN(setRunFlag)(int8 status)
               int8 localVar; // since local, no class preface needed
               localVar = 1;
               clsVAR(flagRunning) = status;
#define mDEFCLASS(cls,df)  ##cls##_##df
#define clsFN(f)           mDEFCLASS(class,f)
#define clsVAR(f)          mDEFCLASS(class,f)
Michael Bradley
www.mculabs.com
Open Drivers and Projects
mbradley
PostPosted: Mon Feb 01, 2010 11:13 am     Reply with quote
I am just curious, did anyone find this useful?
I know I have read posts in the past about C++ and/or OOP, and this seems to fill the bill doesn't it?
For me, it was for a set of serial routines/manipulation, I moved to a chip with 4 uarts, and I needed 4 instances of the same code, and buffers.
Michael Bradley
www.mculabs.com
MikeW
PostPosted: Tue Feb 09, 2010 7:43 am     Reply with quote
Mike,
I havent used it, but keep your goodies coming, its all good stuff
mbradley
PostPosted: Tue Feb 09, 2010 5:04 pm     Reply with quote
Mike, Thank you. I just didnt want to be "that guy" posting alot of useless stuff.
Michael Bradley
www.mculabs.com
Gary Smithson
PostPosted: Fri Nov 19, 2010 1:39 pm     Reply with quote
Michael,
I wanted to let you know that I find your pseudo class concept very clever and that I have now used it for the first time. It works well for modifying function and variable names thus cloning a single driver into multiple. Very nice.
In one of my drivers I needed to use it for creating a #define but through compiler weakness it failed to work. I have reported this to CCS and ask them to add the functionality. An example of what didn't work properly is below:
#define class   example_class
#define cls(FLAG)  // Does not create example_class_FLAG
#if defined (cls(FLAG))  // Condition test causes compilation problems
#if !defined (cls(FLAG))  // Condition test causes compilation problems
I hope CCS will make a contribution here to fully enable this functionality.
Thanks for the fresh idea,
Gary Smithson
mbradley
PostPosted: Fri Nov 19, 2010 8:46 pm     Reply with quote
Thank you so much. I wasnt sure if I just got into a roll of posting useless stuff.
This piece has helped me alot, I had a set of serial functions for buffered in and out in the background, and I needed to use it across 4 serial ports. What a nightmare modifying the source.
Thank you again.
Michael Bradley
www.mculabs.com
Gary Smithson
PostPosted: Fri Nov 19, 2010 9:31 pm     Reply with quote
Michael,
Speaking of your class driver for UART; what is your preferred method for tying the class to the specific UART peripheral? In other words, if the class is defined as uart1, how do you cause the generic UART class driver to compile for and manipulate only UART 1 registers?
Does the UART class driver contain something of this fashion:
#define cls(IN_USE)
#if defined (uart1_IN_USE)
   // function calls specific to UART 1
#endif
#if defined (uart2_IN_USE)
   // function calls specific to UART 2
#endif
... and so on
Obviously the code above is not exactly what you are using because the compiler doesn't seem to be able to handle it, so I would enjoy learning your solution for this.
Thanks,
Gary
mbradley
PostPosted: Fri Nov 19, 2010 10:36 pm     Reply with quote
Here is a snippet of some code I pulled up
#use rs232(UART1,baud=BAUD_NMEA,parity=N,bits=8,stream=ttys0)
#use rs232(UART2,baud=BAUD_CMDIO,parity=N,bits=8,stream=ttys1)
#include "class.h"
#define class clsTTY0
  #include "clsTTY.c"
  #undef class
#define class clsTTY1
  #include "clsTTY.c"
  #undef class
// internal serial port
#int_RDA
void  isr_serRx_ttls0(void)
   clsTTY0_intRX( fgetc(ttls0) );
#int_RDA2
void  isr_serRx_ttls1(void)
   clsTTY0_intRX( fgetc(ttls1) );
****** snipped of my tty code *****
void clsFN(intRX)(int8 data)
   if (clsVAR(serFifoPntr_ttls1) < SERIAL_FIFO_SIZE)
     if (data == 0x0D) { clsVAR(cntSerHasStrings_ttls1)++; }
     clsVAR(serFifo_ttls1[serFifoPntr_ttls1]) = data;
     clsVAR(serFifoPntr_ttls1)++;
     clsVAR(serFifo_ttls1[serFifoPntr_ttls1]) = 0x00;
   if (clsVAR(serFifoPntr_ttls1) == SERIAL_FIFO_SIZE)
     clsVAR(flagSerOverFlow_ttls1) = TRUE;
Michael Bradley
www.mculabs.com
