ktallevi
Posted: Thu Jul 22, 2010 6:24 pm |
Has anyone modified this to count milliseconds as well?
thanks |
princejude
Posted: Wed Aug 11, 2010 7:08 am |
Hello everyone, I am a student and new in CCS and C language in general. I have worked with PIC MCUs using ASSEMBLY LANGUAGE. My School project is to design and construct a DIGITAL CLOCK using PIC MCU. I modified (Mr/Engr...) ckielstra's"Timer based Real Time Clock (RTC)" code posted since Tue Feb 28, 2006 shown below to get a digital clock. The digital clock worked on proteus but the problem I have is that the first three digits are flashing ON and OFF(though there timing is correct). It is only the last digit that is permanent ON.
PLSSSSS how will I make the four digits to be ON instead of flashing ?
I will also be happy if anyone can give me materials or links on how to learn CCS (PIC C).
Here is the code posted by ckielstra
// Zero Drift Real Time Clock
// Original code supplied by Neutone.
// Some small optimizations by C.Kielstra.
#include <18F458.h>
#fuses HS,NOWDT,NOLVP
//RTC variables
#define XTAL_FREQUENCY 20000000
#define TIMER1_FREQUENCY (XTAL_FREQUENCY / 4) // 1 clock tick = 1 instr. cycle = crystal frequency / 4
int32 Ticker;
int8 Seconds=0;
//optional:
// int8 Year=0,Month=0,Days=0,Hours=0,Minutes=0;
// Test whether a given year is a leap year.
// This optimized version only works for the period 2001 - 2099
#define IS_LEAP(year) (year%4 == 0)
// Initialize RTC
void Initialize_RTC(void)
Ticker = TIMER1_FREQUENCY; // initialize clock counter to number of clocks per second
setup_timer_1( T1_INTERNAL | T1_DIV_BY_1 ); // initialize 16-bit Timer1 to interrupt
// exactly every 65536 clock cycles
// (about 76 times per second)
enable_interrupts( INT_TIMER1 ); // Start RTC
// -=Process Zero Drift Real Time Clock Information=-
// Most algorithms configure the timer to generate an interrupt every 100ms, and
// then count the number of interrupts. The problem in that approach is that most
// clock frequencies can't be divided by 256 and you don't get an exact 100ms.
// The small errors will add up to an error of several seconds a day.
// The algorithm presented here is exact in the long run because it doesn't
// count the number of interrupts but counts the number of clock cycles.
#int_TIMER1
void TIMER1_isr()
Ticker -= 65536; // Decrement ticker by clocks per interrupt
if ( Ticker < 65536 ) // If second has expired
{ Ticker += TIMER1_FREQUENCY; // Increment ticker by clocks per second
seconds++; // Increment number of seconds
/* --- Optional part start ---
if(Seconds == 60) {Minutes++; Seconds=0;
if(Minutes == 60) {Hours++; Minutes=0;
if(Hours == 24) {Days++; Hours=0;
if ( (Days == 29 && Month==2 && !IS_LEAP(Year))
|| (Days == 30 && Month==2)
|| (Days == 31 && (Month==4 || Month==6 || Month==9 || Month==11 ))
|| (Days == 32)
) {Month++;Days=0;}
if(Month == 13) {Year++; Month=0;}
--- Optional part end --- */
// Example program for using the RTC
int8 prev_second;
Initialize_RTC();
enable_interrupts( GLOBAL );
// loop forever
// Toggle output every second
if (seconds != prev_second)
prev_second = seconds;
output_toggle(PIN_A1);
HERE IS MY MODIFIED CODE
I changed the crystal value to 25MHz (instead of 20MHz) because i did not see 20MHz in our market. Will this different crystal value affect the timing? Is my one second timing still correct?
#include <16F887.h>
#use delay(clock=25000000)
#FUSES PUT //No Power Up Timer
//RTC variables
#define XTAL_FREQUENCY 25000000
int32 Ticker;
int8 Seconds=0;
//optional:
// Initialize RTC
int decode(int8 Minutes)
int code;
switch(Minutes)
case 0: code = 0x40;break;
case 1: code = 0x79;break;
case 2: code = 0x24;break;
case 3: code = 0x30;break;
case 4: code = 0x19;break;
case 5: code = 0x12;break;
case 6: code = 0x02;break;
case 7: code = 0x78;break;
case 8: code = 0x00;break;
case 9: code = 0x10;break;
return code;
int8 prev_second;
int Sec_units, Min_units, Sec_tens, Min_tens;
int Result;
set_tris_b(0x00);
set_tris_a(0x00);
Initialize_RTC();
// loop forever
Sec_tens = Seconds/10;
Sec_units= Seconds%10;
Min_tens = Minutes/10;
Min_units= Minutes%10;
output_A(0x02);
Result = decode(Min_tens);
output_C(Result);
delay_ms(10);
output_A(0x01);
Result = decode(Min_units);
output_C(Result);
delay_ms(10);
output_A(0x08);
Result = decode(Sec_tens);
output_C(Result);
delay_ms(10);
output_A(0x04);
Result = decode(Sec_units);
output_C(Result);
delay_ms(10);
#int_TIMER1
void TIMER1_isr()
// --- Optional part start ---
|| (Days == 32)
) {Month++;Days=0;}
// --- Optional part end ---
andrewg
Joined: 17 Aug 2005 Posts: 316 Location: Perth, Western Australia
Posted: Fri Aug 13, 2010 9:43 pm |
The reason your display is flickering is because you're only updating it when the seconds change. You need to update it all the time.
| Quote: | | I changed the crystal value to 25MHz |
Check the PIC datasheet. You'll find the maximum oscillator frequency (table 17-1) is 20MHz. While you're probably OK (PICs are pretty tough), you really should use a slower crystal. _________________ Andrew |
princejude
Posted: Tue Aug 17, 2010 7:15 am |
Thanks Mr Andrew, I have edited the code as follows:
1. I changed the crystal value to 4MHz.
| Code: | #use delay(clock=25000000) to #use delay(clock=4000000)
and #define XTAL_FREQUENCY 25000000 to #define XTAL_FREQUENCY 4000000 |
2. I also changed the switch variable from Minutes to Seconds
| Code: | | switch(Minutes) to switch(Seconds) |
3. I reduced the "delay_ms(10);" from 10ms to 1ms
| Code: | | delay_ms(10); to delay_ms(1); |
After all these changes the FLICKERING/FLASHING/BLINKING STOPPED
I AM STILL WORKING ON THE TIME SETTING FUNCTIONS (need help if any).
I will like to use 4 push button switches labeled SET,MODE,UP and DOWN
The expected operation is as follows:
If i press the SET button - the clock will display the current time, call the MODE function(by default the MODE function will select SET_Min function) and wait for the next button to be pressed.
If i press the MODE button - it will select SET_Hr function
When the SET_Min function is selected - if i press UP button the Minutes value will increase and if i press DOWN the Minutes value will decrease.
When the SET_Hr function is selected - if i press UP button the Hours value will increase and if i press DOWN the Hours value will decrease.
Pls i need some advice (or help) on how to achieve these.
HERE IS MY CODE (the time setting section is not yet complete)
| Code: | #include <16F887.h>
#FUSES XT //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#define D 1
#define SET PIN_D0
#define MODE PIN_D1
#define UP PIN_D2
#define DOWN PIN_D3
int32 Ticker;
int8 Seconds=0;
// int1 flg=false;
// Initialize RTC
enable_interrupts(INT_TIMER1); // Start RTC
// Set Time
void set_Hr()
if(!input(UP)) {enable_interrupts(INT_TIMER1); Seconds++;}
else if(!input(DOWN)) {enable_interrupts(INT_TIMER1); Seconds--;}
void set_Min()
// Main Program Start Here
int decode(int8 Seconds)
int code;
switch(Seconds)
return code;
int8 prev_second;
int Sec_units, Min_units, Sec_tens, Min_tens, Hr_units, Hr_tens;
int Result;
Initialize_RTC();
while(true)
if(!input(SET)) {disable_interrupts(INT_TIMER1); SET_Hr();}
{ prev_second = seconds; }
Hr_tens = Hours/10;
Hr_units= Hours%10;
output_A(0x20);
Result = decode(Hr_tens);
output_C(Result);
delay_ms(D);
output_A(0x10);
Result = decode(Hr_units);
output_C(Result);
delay_ms(D);
output_A(0x02);
output_C(Result);
delay_ms(D);
output_A(0x01);
output_C(Result);
delay_ms(D);
output_A(0x08);
output_C(Result);
delay_ms(D);
output_A(0x04);
output_C(Result);
delay_ms(D);
// set_Hr();
#int_TIMER1
void TIMER1_isr()
if(Seconds == 60)
if(Minutes == 60)
Hours++; Minutes=0;
if(Hours == 24)
Days++; Hours=0;
if((Days == 29 && Month==2 && !IS_LEAP(Year))|| (Days == 30 && Month==2)
|| (Days == 31 && (Month==4 || Month==6 || Month==9 || Month==11 ))||(Days == 32))
{Month++;Days=0;}
if(Month == 13)
{Year++; Month=0;}
| [/b] |
andrewg
Posted: Tue Aug 17, 2010 8:26 am |
It's good to hear your display is working now.
Do you have any specific questions about handling your input switches? I suggest that you Google "switch debouncing" and have a read. _________________ Andrew |
hayate_kun
| LCD to PIC pin connection |
Posted: Fri Nov 12, 2010 3:57 am |
Hello!
I've tried the code above and it can be programm well without any error.
However, i might have connected it wrongly because the LCD doesn't display the character.
Can some one please check my connection? Thank you.
(I'm using PIC16F877A)
pin 1 to GND
pin 2 to +5V
pin 3 to GND
pin 4 to RB1
pin 5 to RB2
pin 6 to RB0
pin 7 to -
pin 8 to -
pin 9 to -
pin 10 to -
pin 11 to RB4
pin 12 to RB5
pin 13 to RB6
pin 14 to RB7
pin 15 to +5V
pin 16 to GND
SCL (DS1307) to RC3
SDA (DS1307) to RC4 |
andrewg
Posted: Fri Nov 12, 2010 5:37 am |
For most LCD modules, pin 3 is the contrast input and should be something in the order of 0.8V, not GND as you have shown. Typically you have a 10-20K trimpot connected to +5V and GND (pins 1 and 2), and the center wiper connecting to the contrast (pin 3). _________________ Andrew |
hayate_kun
Posted: Fri Nov 12, 2010 7:00 am |
Thank you Mr. Andrew,
I've connected pin 3 to the center wiper of the trimpot and pin 1 & 2 to +5V and GND. The LCD is on and I can varies the level of contrast with nothing to be displayed! Is there something in the code that I should alter if I'm using PIC 16F877A?
Please take a look at my code:
#include <16F877A.h>
#define use_portb_lcd TRUE
#include <lcd.c>
#byte PORTA=5
#byte PORTB=6
#byte PORTC=7
#byte PORTD=8
#byte PORTE=9
//RTC variables
int32 Ticker;
int8 Seconds=0;
//optional:
// Initialize RTC
#int_TIMER1
void TIMER1_isr()
int8 prev_second;
set_tris_a(0b00111111);
set_tris_b(0b00000000);
set_tris_c(0b00000000);
Initialize_RTC();
// loop forever
andrewg
Posted: Fri Nov 12, 2010 8:37 am |
lcd_init() clears the display, but then you don't call any functions to send characters to the screen, so of course it will remain blank! _________________ Andrew |
hayate_kun
Posted: Sat Nov 13, 2010 6:14 am |
Thank you Mr Andrew, now i can see the display. I've added the following code:
int8 prev_second;
Initialize_RTC();
// loop forever
printf(lcd_putc,"\nTime:%d",prev_second); }
But, why it counted from 0 till 128?and then went down to -128 to 0?
and, can you explain what is output_toggle(PIN_A1); mean? |
andrewg
Posted: Sat Nov 13, 2010 9:28 am |
%d is for signed numbers, you want %u. See the CCS manual/help for the printf function.
| Code: | | output_toggle(PIN_A1); | is toggling pin A1 on and off every second, I presume for debugging purposes. _________________ Andrew |
Ringo42
Posted: Thu Dec 16, 2010 3:22 pm |
I'm using a 18f4520 running at 20Mhz.
so I have this code
| Code: | #use delay(clock=20000000)
#define TIMER1_FREQUENCY (XTAL_FREQUENCY / 4) // 1 clock tick = 1 instr. cycle = crystal frequency / 4 |
in the beginning,
then
| Code: | ////////////////////////////////////////////////////////////////////////////////
// Initialize RTC
#int_TIMER1
void TIMER1_isr()
This used to work. I switched from a 452 to an LF4520. There were lots of changes in code after changing processors, but I just noticed the time is off. Now it seems to run at 33% of normal speed. What could I have done to mess it up? I'm also using other timers in my code, could this have done something? I'm sure I could tweak the numbers to make it work, but I want to know how I messed it up. Any help will be greatly appreciated.
Ringo _________________ Ringo Davis |
andrewg
Posted: Thu Dec 16, 2010 11:09 pm |
Your code looks fine to me. Are you disabling interrupts elsewhere in your code - that might be delaying your timer1 interrupt. _________________ Andrew |
Ringo42
Posted: Fri Dec 17, 2010 7:56 am |
I'm disabling int#2, I'm not messing with #1 anywhere. Mostly what I'm doing is is reading an I2C sensor and printing stuff on an LCD. Actually while it is displaying the time I'm not even messing with Timer 2.
I am using a bootloader, would that matter in any way?
I read the I2C sensor then do a delay_ms(710). That works out so that I'm reading the sensor once per second and updating the LCD. I see the LCD blink 2-3 times for each time the seconds are updated, so it looks to me like the rest of the code is running at the right speed, just not the time part.
Ringo42
Posted: Fri Dec 17, 2010 1:26 pm |
I stripped my code down to almost nothing.
After everything is initialized I have a main loop that does this
| Code: | printf(lcd_putc"\f%ld:0%d\n",TotalMinutes,Seconds);
printf("%ld:0%d\n",TotalMinutes,Seconds);
This code results in a time that runs at about 10% of the intended speed. Taking out the delay_ms seems to fix the problem.
Does the delay command use timer1? Is there a way around this issue? I use delay_ms in a bunch of places.
