Posted: Wed Oct 27, 2010 3:51 pm |
| I don't have Proteus. I don't know very much about it. |
matheuslps
Posted: Wed Oct 27, 2010 6:42 pm |
Sure you can simulate with Proteus.
Most of the codes works fine.
bye |
alex_ccs
Posted: Thu Oct 28, 2010 9:43 am |
Thanks both.
I have simulate on Proteus but nothing happen. |
matheuslps
Posted: Thu Oct 28, 2010 12:43 pm |
Please post your circuit and your code.
I will simulate it for you.
EDIT:
Done:
Circuit:
http://img7.imageshack.us/img7/6990/adclcd.png
| Code: | #include <16F877A.h>
#device adc=8
#FUSES XT //Crystal osc <= 4mhz
#FUSES PUT //Power Up Timer
#include <LCD.C>
int8 q;
float p;
setup_ccp1(CCP_PWM);
setup_timer_2(T2_DIV_BY_16, 255, 1);
setup_adc_ports(AN0); //Analogic channel 0
setup_adc(ADC_CLOCK_INTERNAL); //internal clock
lcd_init();
set_adc_channel(0); //enable channel 0
delay_us(20);
while (TRUE)
q = read_adc(); //read channel 0
p=0.392*q;
printf (lcd_putc, "\fADC = %4u \n%4.2f percent", q, p);
set_pwm1_duty(q);
bye |
alex_ccs
asmboy
| proteus .... |
Posted: Thu Jul 21, 2011 3:50 pm |
You can simulate quite a few pic situations with Proteus
But - after having it suggested to me
and trying it exactly ONCE - i will NEVER touch it again.
If you want to know how a program really works - you should make the effort to build the actual hardware and do it for REAL.
Proteus simulated pic code is NOT a basis for a working product that i would ever rely on.
For school class maybe -
but not in the world of designs that HAVE to work. |
