Clock declaration?!!
doryme
PostPosted: Mon Oct 18, 2010 3:46 pm     Reply with quote
Hello
I am using pic16f877A. I don't understand what to write in declaration to define my 10MHz crystal.
Should I write #USE DELAY (CLOCK=10000000)??
Also I don't understand what are fuses?!
PostPosted: Mon Oct 18, 2010 4:03 pm     Reply with quote
There is a tutorial that explains all your questions. It's about 1/2 way down
the page on the following link. Look for the section called "Sample Code".
He explains a small program line-by-line:
http://harfordhackerspace.org/2010/02/programming-pic-microcontrollers-in-c/
doryme
PostPosted: Mon Oct 18, 2010 4:16 pm     Reply with quote
Thanks alot for this link..it is very useful!
but i know now that i use INTRC_IO fuse when i use internal oscillator, what should i write when i use external one?!
bkamen
PostPosted: Mon Oct 18, 2010 4:22 pm     Reply with quote
You will probably want either HS (depends on the PIC).
You want to read the datasheet for the device.
-Ben
Humberto
PostPosted: Mon Oct 18, 2010 4:29 pm     Reply with quote
You can find a short explanation to understand the FUSES meaning in:
http://www.ccsinfo.com/forum/viewtopic.php?t=24336&highlight=fuses
Regards
