Help! PWM on PIC16F886
paulw300568
PostPosted: Mon Oct 04, 2010 2:47 pm     Reply with quote
I'm trying to get the PWM module running on the 16F886, with the following code to give a 1MHz signal with 50% duty, but it doesn't want to work! I have got it working in assembler, but won't work in C. Anyone any ideas about what I'm missing please?
#include <16F886.h>
#fuses INTRC_IO, NOWDT,PWRT,NOLVP
#use delay(clock=8000000)
setup_ccp1(CCP_PWM);
setup_timer_2(T2_DIV_BY_1, 2, 1);
set_pwm1_duty(4);
Gabriel
PostPosted: Mon Oct 04, 2010 3:01 pm     Reply with quote
Mabey you should put:
While(1){}
it probably does not make a difference.... but its how i code my loops..
and ive never seen
Void Main(void)
whats wrong with plain old Void Main() ?
CCS PCM 5.078 & CCS PCH 5.093
PostPosted: Mon Oct 04, 2010 3:06 pm     Reply with quote
I assume you're using 10-bit PWM mode in assembler ?
In CCS, to invoke 10-bit mode, you need to specify the duty cycle
parameter as a 'long'. If it's a 8-bit constant, append an 'L' to it, or if it's
a variable, then declare it as an 'int16'. Example:
set_pwm1_duty(4L);
paulw300568
PostPosted: Mon Oct 04, 2010 3:24 pm     Reply with quote
Thanks for the replies so far. I have recoded it like the following, so accessing the registers directly (copying from my assembler code), and it still doesn't work! Definitely starting to drive me nuts now!
#include <16F886.h>
#byte PR2 = 0x92
#byte CCPR1L = 0x15
#byte CCP1CON = 0x17
#byte OSCCON = 0x8F
#bit TMR2ON = 0x12.2
#byte ANSEL = 0x188
#byte ANSELH = 0x189
#byte TRISA = 0x85
#byte TRISB = 0x86
#byte TRISC = 0x87
#byte PORTA = 0x05
#byte PORTB = 0x06
#byte PORTC = 0x07
TRISA = 0xC0;
TRISB = 0x00;
TRISC = 0xB0;
PORTA = 0x00;
PORTB = 0x00;
PORTC = 0x00;
OSCCON = 0x77;
PR2=1;
CCPR1L = 0;
CCP1CON = 0x3C;
TMR2ON = 1;
PostPosted: Mon Oct 04, 2010 3:31 pm     Reply with quote
What was so wrong with doing it with my modification to your code ?
Did it not work ? If that's the case, post your compiler version.
I tested it with vs. 4.112.
If it worked, and you want to see what the assembly code was,
then go to Build Options and set the compiler's List file format to Symbolic.
Then re-compile and look at the .LST file. It will show you the assembler
code necessary to make it work.
paulw300568
PostPosted: Mon Oct 04, 2010 3:53 pm     Reply with quote
Hi PCM programmer,
No that didn't work. I'm using version PCM 4.007 with MPLAB IDE version 8.56.
I am wondering if it's my #fuses settings or something, because this just doesn't make sense.
Also, in another program I noticed that with this compiler if I use the following
set_tris_a(OxXX);
set_tris_b((OxXX);
set_tris_c(OxXX);
Where XX is some 8 bit number, then the compiler complains at set_tris_a(), throwing up about 40 or so errors, but it has no problem with
set_tris_b((OxXX);
set_tris_c(OxXX);
set_tris_a(OxXX);
Now, what is that about?
Regards,
Paul
PostPosted: Mon Oct 04, 2010 4:36 pm     Reply with quote
That's the problem. I wouldn't do anything with that early of a version.
It's just not worth it. It's just endless problems.
Here's the ASM code produced by vs. 4.112 for the 16F886.
Note that it's using a shadow register for TRISC, to avoid conflicts
with peripheral overrides.
.................... void main(void)
0004:  CLRF   FSR
0005:  BCF    STATUS.IRP
0006:  MOVLW  1F
0007:  ANDWF  STATUS,F
0008:  MOVLW  61
0009:  BSF    STATUS.RP0
000A:  MOVWF  OSCCON
000B:  MOVF   OSCCON,W
000C:  MOVLW  FF
000D:  BCF    STATUS.RP0
000E:  MOVWF  @TRIS_C
000F:  BSF    STATUS.RP0
0010:  BSF    STATUS.RP1
0011:  MOVF   ANSELH,W
0012:  ANDLW  C0
0013:  MOVWF  ANSELH
0014:  BCF    STATUS.RP1
0015:  BCF    ADCON1.VCFG0
0016:  BCF    ADCON1.VCFG1
0017:  MOVLW  00
0018:  BSF    STATUS.RP1
0019:  MOVWF  ANSEL
001A:  BCF    STATUS.RP0
001B:  CLRF   CM1CON0
001C:  CLRF   CM2CON0
001D:  CLRF   CM2CON1
.................... setup_ccp1(CCP_PWM);
001E:  BCF    STATUS.RP1
001F:  BCF    @TRIS_C.2
0020:  MOVF   @TRIS_C,W
0021:  BSF    STATUS.RP0
0022:  MOVWF  TRISC
0023:  BCF    STATUS.RP0
0024:  BCF    PORTC.2
0025:  BSF    STATUS.RP0
0026:  BCF    TRISE.-
0027:  MOVLW  0C
0028:  BCF    STATUS.RP0
0029:  MOVWF  CCP1CON
002A:  BSF    STATUS.RP0
002B:  CLRF   PWM1CON
002C:  CLRF   ECCPAS
002D:  MOVLW  01
002E:  MOVWF  PSTRCON
.................... setup_timer_2(T2_DIV_BY_1, 2, 1);
002F:  MOVLW  00
0030:  MOVWF  @78
0031:  IORLW  04
0032:  BCF    STATUS.RP0
0033:  MOVWF  T2CON
0034:  MOVLW  02
0035:  BSF    STATUS.RP0
0036:  MOVWF  PR2
.................... set_pwm1_duty(4L);
0037:  MOVLW  01
0038:  BCF    STATUS.RP0
0039:  MOVWF  CCPR1L
003A:  MOVF   CCP1CON,W
003B:  ANDLW  CF
003C:  MOVWF  CCP1CON
.................... while(1);
003D:  GOTO   03D
Configuration Fuses:
   Word  1: 2FE4   INTRC_IO NOWDT PUT NOLVP NODEBUG NOPROTECT BROWNOUT FCMEN MCLR NOCPD IESO
   Word  2: 3FFF   NOWRT BORV40
paulw300568
PostPosted: Mon Oct 04, 2010 4:56 pm     Reply with quote
OK thanks very much for taking the time to investigate that. I'll upgrade as soon as I get a chance.
P
paulw300568
PostPosted: Tue Oct 05, 2010 10:37 am     Reply with quote
Just to let you know that I upgraded to the latest compiler version and my the code now works fine.
Thanks very much for all the help!
P
