read digital data by pic18f4550
spec
View user's profile Send private message Yahoo Messenger ICQ Number
PostPosted: Sat Oct 02, 2010 11:31 am     Reply with quote
Hi everyone,
I have a TDC-GP1 chip (time to digital converter: www.acam.de/fileadmin/Download/pdf/English/DB_GP1_e.pdf) used to measure ultra fast-time. I want to develop a electronics kit for some applications. I use a pic184550 to read data from TDC-GP1 chip and trans. to PC. Can you help me? How can I design ..?
Thanks!
spectroscopy
PostPosted: Sat Oct 02, 2010 12:26 pm     Reply with quote
You need to build or buy a demo board. Or buy a "break-out" board for
the TDC-GP1 chip, and then connect it to a PIC demo board. Then you
need to write a software driver for the TDC-GP1, using the CCS compiler.
If you are a newbie in hardware and software, this is going to be
extremely difficult. You really need to know at least some of the C
language before you begin. This TDC-GP1 project should not be your
first PIC project. Do some other work first, so you can learn the basics.
The TDC-GP1 data sheet has some generic sample C source code in it.
This could possibly be used to help you write the driver in CCS. I don't
want to do the project for you. I just wanted to tell you what you need to
do, to begin.
spec
PostPosted: Sun Oct 03, 2010 1:28 am     Reply with quote
do, to begin.
Thank you for your support. I have developed a test boad, this link are SCH. and PCB files in DXP2004 protel: http://www.megaupload.com/?d=L7VX2UBM
I'm also learning some projects in CCS with pic18f4550 such as led blink, communication with rs232 standard by this test boad. But I don't know that how to configure control registers of TDC-GP1 to read data. Can you suggest something to help me?
Thanks so much!
spectroscopy
spec
PostPosted: Thu Oct 07, 2010 11:28 pm     Reply with quote
Hi every one,
I have made test board and program for this project. And I'm trying to test program, I want to create two pulses from pin C0 and C1 (C1 delay 10us compare with C0) but it's not run:
#include "C:\gpt2\main.h"
int8 valid, nk0, vk0;
int16 nk1, vk1, t;
   setup_adc(ADC_CLOCK_DIV_2);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
   // TODO: USER CODE!!
  while (true)
      while(true)
      output_high(PIN_C0);
      delay_us(10);
      output_high(PIN_C1);
      output_low(PIN_C0);
      delay_us(10);
      output_toggle(pin_c2);
         Output_high(pin_a0);
         Output_high(pin_a1);
         Output_low(pin_a2);
         Output_high(pin_a3);
         Output_d(0x07);
         output_low(pin_b0);
         valid=0;
      output_high(pin_b1);
      output_low(pin_b2);
      output_low(pin_b3);
      output_low(pin_b4);
            while(valid==0)
            valid=pin_b0;
         Output_low(pin_a0);
         Output_low(pin_a1);
         Output_low(pin_a2);
         Output_low(pin_a3);
         nk0=input_d();
         nk1=input_d();
         vk0=input_d();
         vk1=input_d();
      vk1=vk1*256;
      vk1=vk1|vk0;
      nk1=nk1*256;
      nk1=nk1|nk0;
      t = 83.333*((float)(vk1)+(float)(nk1)/65536.0);
      t = output_d(t);
      printf("gia tri la: %lu\n", t);
can you help me!
Thanks so much!
spectroscopy
tae
PostPosted: Fri Oct 08, 2010 5:15 am     Reply with quote
      while(true)
      delay_us(10);
      output_low(PIN_C0);
      delay_us(10);
A rather strange use of "While" Smile
            while(valid==0)
            valid=pin_b0;
And what's this ??
spec
PostPosted: Fri Oct 08, 2010 11:58 pm     Reply with quote
tae wrote:
      while(true)
      delay_us(10);
      output_low(PIN_C0);
      delay_us(10);
            while(valid==0)
            valid=pin_b0;
And what's this ??
Thanks, Pin B0 connect with Int.flag of TDC-GP1 chip (when Int.flag in high level, TDC-GP1 allow data to read from register), hence I use while loop this.
spectroscopy
PostPosted: Sat Oct 09, 2010 2:55 am     Reply with quote
The problem is the syntax.
'PIN_B0', is just a _number_, used as a reference to address a particular pin. To read a value _from_ 'PIN_B0', requires the used of an 'input' statement. Then, there is no point at all in copying the value into another register.
So:
while (input(PIN_B0))==0) ;
Waits for PIN_B0 to go high. What you currently have, will never wait.
