CRC_calculate Help...
kmp84
PostPosted: Sat Sep 25, 2010 5:09 pm     Reply with quote
Hi Developers..Smile
I've problem with calculation of specific CRC. I'll put simple test program for calculating CRC with example packet (data).
   #include <16F628A.h>        //
   #device *=16        //
   #fuses HS, NOWDT,PROTECT,BROWNOUT,PUT,NOLVP,MCLR ///////////////////////////////////////////
   #use delay(clock=10 000 000)                                                              //
   #use rs232(baud=9600,rcv=PIN_B1,xmit=PIN_B2,errors,enable=PIN_B3,STREAM=rs_485)           //
 char   buffer_485_tx []={0xF2,0x94,0x02,0x00,0x37,0x38,0x30,0x30,0x30,0x33,0x32,0x30,0x36,0x31};
 char  pc_crc_tx ()
      unsigned int16 hlp;
      int1  cary;
      int byte_counter;
      char CHEKSUM=0x00;
   printf ("START CRC CALC\n\r");
   for (byte_counter=0;byte_counter<=13;byte_counter++)
       printf ("For byte No:******************************* %d \n\r",byte_counter);
       printf ("INPUT_BYTE %X\n\r",buffer_485_tx[byte_counter]);
       printf ("CHEKSUM: %X\n\r",CHEKSUM);
       printf ("HLP: %4X\n\r",hlp);
        hlp = buffer_485_tx[byte_counter] + CHEKSUM;
       printf ("HLP_0: %4X\n\r",hlp);
      if (hlp > 0xFF)
         cary = 1;
      }else cary=0;
      printf ("Cary___________1: %d\n\r",cary);
      hlp=hlp & 0xFF;
      printf ("HLP_1: %4X\n\r",hlp);
      hlp=hlp+hlp;
       printf ("HLP_2: %4X\n\r",hlp);
      if (cary)
         hlp++;
      printf ("HLP_3: %4X\n\r",hlp);
      if(hlp>0xFF)
         cary=1;
      }else cary=0;
     printf ("Cary___________2: %d\n\r",cary);
      hlp=hlp & 0xFF;
      printf ("HLP_4: %4X\n\r",hlp);
      if (!cary)
         hlp=hlp ^ 0xDD;
      printf ("HLP_5: %4X\n\r",hlp);
      if (hlp >=0xE0)
         hlp=hlp-0xE0;
      printf ("HLP_6: %4X\n\r",hlp);
      CHEKSUM = hlp;
     // fputc (CHEKSUM,rs_485);
         printf ("CRC_byte_LAST: %X\n\r",CHEKSUM);
     return CHEKSUM;
   void main (){
      while (TRUE)
         pc_crc_tx ();
The Calculated CRC is 0x18, but it's Wrong. Correct CRC is 0x12.
Also I make test program with Visual C++ and Source work with little change of data type.
Any idea...??
Thanks before:)
PostPosted: Sat Sep 25, 2010 9:54 pm     Reply with quote
Also I make test program with Visual C++.
Did you get the algorithm from the internet ? If so, post a link to a
working version of the code that is written in C (not C++).
kmp84
PostPosted: Sun Sep 26, 2010 12:17 am     Reply with quote
Hi PCM:) I got the algorithm from Delphi working code. Also I've assembler code for 8086 CPU...
  ADDCHECK:  PUSH    AX
                         ADD     AL,CHECKSUM
                         RCL     AL,1
                         JC      ADCK3
                           XOR     AL,11011101b
            ADCK3:       MOV     CHECKSUM,AL
                         SUB     AL,224
                         JC      ADCK4
                           MOV     CHECKSUM,AL
            ADCK4:     POP     AX
                       RET
My Compiler version is v.4.104
PostPosted: Sun Sep 26, 2010 5:24 pm     Reply with quote
For me, it's far easier to translate the Intel x86 ASM code into PIC ASM
than to try to convert it to C, so that's what I did below. I also cleaned
up your function interface. I created a function called get_checksum()
with accepts a pointer to an array of bytes and also the size of the array,
and then it calculates the checksum on that array and returns the result.
Now, unlike your code, it's a self-contained function. You give it
parameters and it gives you a result.
Running it in MPLAB simulator with compiler vs. 4.112 gives 0x12, which
you said is the expected result, so it's probably working.
Checksum = 12
#include <18F452.h>
char buffer_485_tx[]={0xF2,0x94,0x02,0x00,0x37,0x38,0x30,0x30,0x30,0x33,0x32,0x30,0x36,0x31};
int8 get_checksum(int8 *buffer, int8 bufsize)
int8 i;
int8 AL;
int8 checksum;
if(bufsize == 0)  // Safety check.  Is the count = 0 ?
   return(0);     // Just return if so
checksum = 0;
for(i = 0; i < bufsize; i++)
    AL = buffer[i];
    #asm
    ;    ADD   AL,CHECKSUM  // Add checksum to AL, update Cy
         movf  checksum, W
         addwf AL,F
    ;    RCL   AL,1         // Rotate AL left, thru Cy
         rlcf  AL,F
    ;    JC    ADCK3        // Jump on Cy to ADCK3
         bc    ADCK3
    ;    XOR   AL,11011101b // XOR AL with 0xDD
         movlw 0xDD
         xorwf AL,F
    ADCK3:
    ;    MOV   CHECKSUM,AL  // Put AL in Checksum
         movff AL,checksum
    ;    SUB   AL,224
         movlw 224
         subwf AL,F
    ;    JC    ADCK4
         bnc   ADCK4    // Cy is opposite with subwf so use bnc
         movff AL, checksum
    ADCK4:
    #endasm
return(checksum);
// Original x86 source code
 ADDCHECK:
            PUSH    AX
            ADD     AL,CHECKSUM  // Add Checksum to AL, update Cy
 ADCK3:
            SUB     AL,224
            JC      ADCK4
            MOV     CHECKSUM,AL
 ADCK4:
            POP     AX
            RET
int8 result;
result = get_checksum(buffer_485_tx, sizeof(buffer_485_tx));
printf("Checksum = %x\r", result);
kmp84
PostPosted: Mon Sep 27, 2010 4:39 am     Reply with quote
Checksum = 12
#include <18F452.h>
int8 i;
int8 AL;
int8 checksum;
checksum = 0;
    AL = buffer[i];
    #asm
         movf  checksum, W
         addwf AL,F
         rlcf  AL,F
         bc    ADCK3
         movlw 0xDD
         xorwf AL,F
    ADCK3:
         movff AL,checksum
    ;    SUB   AL,224
         movlw 224
         subwf AL,F
    ;    JC    ADCK4
         movff AL, checksum
    ADCK4:
    #endasm
return(checksum);
 ADDCHECK:
            PUSH    AX
 ADCK3:
            SUB     AL,224
            JC      ADCK4
            MOV     CHECKSUM,AL
 ADCK4:
            POP     AX
            RET
int8 result;
Thanks again .Smile PCM , but it dosn't work with PCM devices (14bit Parts), and return error from compilations "rlcf AL,F--->Expecting an opcode mnemonic"
PostPosted: Mon Sep 27, 2010 4:53 am     Reply with quote
Just change RLCF to RLF.
On the PIC16, the only rotation does it through the carry, so there is just one instruction (fortunately the one we want!). On the PIC18's, other versions were added, so the instruction became 'RLCF' to say 'through the carry'.
kmp84
PostPosted: Mon Sep 27, 2010 5:18 am     Reply with quote
Hi Ttelmah Smile
I saw this , but have other ASM different instruction set ..
I have err on line : "bc ADCK3" What is "bc"??
PostPosted: Mon Sep 27, 2010 7:05 am     Reply with quote
Branch if carry. Jumps to ADCK3, if the carry bit is set.
On the PIC16, this has to be done as:
#byte STATUS=3
Then in the assembler:
BTFSC STATUS,0
GOTO ADCK3
So you test the 'carry' bit in the status register, and if it is 'set' (carry), then execute the next instruction, which is the jump to ADCK3, otherwise skip this.
kmp84
PostPosted: Mon Sep 27, 2010 7:26 am     Reply with quote
#byte STATUS=3
BTFSC STATUS,0
GOTO ADCK3
Hi Ttelmah Smile I made up this for BC --> BTFSC 3,0
goto ADCK3
and for bnc --> BTFSS 3,0
goto ADCK4
but still have a errors and diferent from MOVFF instruction
Question
PostPosted: Mon Sep 27, 2010 9:09 am     Reply with quote
To 'put you out of your misery', I have done what PCM didn't want to, and changed the routine into C.
int8 get_checksum(int8 *buffer, int8 bufsize) {
   int8 i;
   int16 AL;
   int8 checksum,temp;
   int1 carry;
   checksum = 0;
   for(i = 0; i < bufsize; i++) {
    AL = buffer[i];
    AL+=checksum;
    if (AL & 0x100)
         //Here have carry, so rotate one into the byte
         carry=shift_left(&AL,1,1);
         //Else zero
         carry=shift_left(&AL,1,0);
    //Carry is now the bit that came out the bottom
    if (carry==0)
       AL^=0xDD;
    temp=make8(AL,0); //Get LSB
    if (temp<224)
       checksum=temp;
       checksum=temp-224;
   return checksum;
I think this is 'right', and should work identically with PIC16 or PIC18 chips.
kmp84
PostPosted: Tue Sep 28, 2010 9:04 am     Reply with quote
Hi Ttelmah ! Thanks for your help. Your 'C' CRC calc. routine work. I've never done programing in assembler, but with little reading data sheet - PIC instruction set summary and your help this also work:
int8 i;
int8 AL;
int8 checksum;
//#byte STATUS=3
checksum = 0;
    AL = buffer[i];
    #asm
         movf  checksum, W
         addwf AL,F
         rlf  AL,F
         BTFSC 3,0
         goto ADCK3
         movlw 0xDD
         xorwf AL,F
    ADCK3:
         movf AL ,W
         movwf checksum
         movlw 224
         subwf AL,F //demo
         BTFSS 3,0
         goto ADCK4
         movf AL,W
         movwf checksum
    ADCK4:
    #endasm
return(checksum);
