marcuslim Guest
help!!LCD and keypad + application |
Posted: Wed Sep 11, 2002 11:32 am |
i have done a simple transceiver to transmit the data keyed in by keypad, i have test and comfirm that my transceiver is working and the other part lcd + the keypad also work properly.
but when i combine the tranceiver to the lcd and keypad ,the transceiver part is not working
i'm using 16C76 with portb used for keypad and the lcd and the port A and C for transciver
the code shows in below
void main(void) // Main function
{ char k;
int i=0;
int t=0;
lcd_init();
kbd_init();
lcd_putc("\fPress # to Enter...\n");
{ k=kbd_getc();
if(k!=0)
if(k=='*')
{lcd_putc('\f');
strcpy(security_code,empty);
{ lcd_putc(k);
security_code [i]=k;
i++;
if (k=='#')
{lcd_putc(k);
break;}
lcd_putc("\fverify...\n");
for (t=0;t<4;t++)
lcd_putc(security_code [t]);
lcd_putc(" start..");
while(TRUE){
int_rpc(); //initial transciever
strcpy(buff,"911");
transmit();
delay_ms(30);
receive(); //////program discontinue from this part
delay_ms(50);
if (buff[2]=='2')
{strcpy(buff,"");
lcd_putc("\fbreak...\n");
break;}
delay_ms(30);
any body can help or face a similar problem before??halp
thank,
sorry for poor english
___________________________
Original Post ID: 7037 |
alert Guest
Re: help!!LCD and keypad + application |
Posted: Thu Sep 12, 2002 8:04 am |
sorry for my poor english too.
i have not read your code completely. you saying im using transceiver so that means any other receiver or transceiver present. close distance causes interference. i was worked on similar project. (two transceiver) first i think problem cause by MCU but than i see this problem.
good work.
:=i have done a simple transceiver to transmit the data keyed in by keypad, i have test and comfirm that my transceiver is working and the other part lcd + the keypad also work properly.
:=but when i combine the tranceiver to the lcd and keypad ,the transceiver part is not working
:=i'm using 16C76 with portb used for keypad and the lcd and the port A and C for transciver
:=the code shows in below
:=void main(void) // Main function
:={ char k;
:= int i=0;
:= int t=0;
:= lcd_init();
:= kbd_init();
:= lcd_putc("\fPress # to Enter...\n");
:=while(TRUE)
:= { k=kbd_getc();
:= if(k!=0)
:= if(k=='*')
:= {lcd_putc('\f');
:= strcpy(security_code,empty);
:= else
:= { lcd_putc(k);
:= security_code [i]=k;
:= i++;
:= if (k=='#')
:= {lcd_putc(k);
:= break;}
:= lcd_putc("\fverify...\n");
:= for (t=0;t<4;t++)
:= lcd_putc(security_code [t]);
:= lcd_putc(" start..");
:=while(TRUE){
:= int_rpc(); //initial transciever
:= strcpy(buff,"911");
:= transmit();
:= delay_ms(30);
:= receive(); //////program discontinue from this part
:= delay_ms(50);
:= if (buff[2]=='2')
:= {strcpy(buff,"");
:= lcd_putc("\fbreak...\n");
:= break;}
:=delay_ms(30);
:=any body can help or face a similar problem before??halp
:=thank,
:=sorry for poor english
Original Post ID: 7058 |
