daraos
| I2C: 18f2550 master and 30f3013 slave, won't work |
Posted: Wed Sep 15, 2010 8:43 am |
I'm using a PIC18f2550 as a master and a dsPIC30f3013 as a slave, and the interrupt in the slave never triggers.
I started 2 new projects leaving the code at its bare minimum.
The oscilloscope shows the data and the clock correctly, but the pin_f6 never goes high. I've tried with force_hw and force_sw in the master.
This is the code for the master:
#include<18F2550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN,nomclr, put
#use delay(clock=48000000)
#use i2c(master, I2C1, slow, force_hw)
void main(){
byte data_i2c;
while(TRUE){
i2c_start();
i2c_write(0xB0);
i2c_write(data_i2c);
i2c_write(0x00); //dummy, segundo byte que se envia a dspic
i2c_start();
i2c_write(0xB1);
data_i2c=i2c_read(0);
i2c_stop();
delay_ms(5000);
and the code for the slave:
#include<30f3013.h>
byte channel,cama;
#fuses frc_pll16, nowdt, nodebug, nomclr, nobrownout, noprotect
#use i2c(SLAVE, I2C1, address=0xB0, force_hw)
#INT_SI2C
void ssp_interupt ()
BYTE state, incoming;
state = i2c_isr_state();
output_high(pin_f6); //to check if the interrupt triggers
if(state <= 0x80){ //Master is sending data
incoming = i2c_read(0);
if(state == 1){ //First received byte is address
channel = incoming;
else if(state == 2){ //Second received byte is data
cama = incoming;
if(state == 0x80){ //Master is requesting data
i2c_write(0x55);
void main(){
//initial setup
output_low(pin_f6);
enable_interrupts(INT_SI2C);
while(TRUE){}
I have 3 days now trying to solve this, please help! |
daraos
Posted: Thu Sep 16, 2010 10:41 am |
I don't know why, but I solved it changing the Master Address to 0x60, and the Slave answer at the address 0xB0. Really weird, probably because I'm using a invalid address for the slave or something like that. I'll look into it once I'm finished with the project.
Also, in the slave's interrupt routine, I changed
| Code: | | if(state <= 0x80){ //Master is sending data |
with
| Code: | | if(state < 0x80){ //Master is sending data |
and works perfectly |
