Liamthesnake
| using memset to erase buffer within a structure |
Posted: Fri Sep 10, 2010 10:10 am |
Hi all
I'm erasing a buffer using memset. If this was a normal buffer it would be
| Code: | | memset(buffer,0,sizeof(buffer)); |
and to erase a structure it would be
| Code: | | memset(&structure_test,0,sizeof(structure_test)); |
but what happens if it's a buffer within a structure? do you use the address symbol or not?
| Code: | | memset(&structure_test.buffer,0,sizeof(structure_test.buffer)); |
Thanks in advance, |
Posted: Fri Sep 10, 2010 12:55 pm |
According to the .LST file, the compiler generates the same address for
either method (with vs. 4.112).
.... addr = structure_test.buffer;
0022: MOVLW 02 // Load addr with 0x0283
0024: MOVWF 06
0026: MOVLW 83
0028: MOVWF 05
.... addr = &structure_test.buffer;
002A: MOVLW 02 // Load addr with 0x0283
002C: MOVWF 06
002E: MOVLW 83
0030: MOVWF 05
// Symbol table
000 @SCRATCH
001 @SCRATCH
001 _RETURN_
002 @SCRATCH
003 @SCRATCH
004 rs232_errors
005-006 main.addr // 'addr' is at 0x0005
280-28C structure_test // Structure is at 0x280
F83 PSP_DATA
FBB CCP_2_LOW
Test program:
#include <18F452.h>
#fuses XT,NOWDT,PUT,BROWNOUT,NOLVP
struct
int8 a;
int16 b;
int8 buffer[10];
}structure_test;
#locate structure_test = 0x280
int16 addr;
The same results occur for a C program compiled in MSVC++ 6.0:
| Quote: |
structure_test.buffer = 004237D4
&structure_test.buffer = 004237D4
Test program for MSVC++ 6.0 (C program, not C++):
#include <stdio.h>
struct
unsigned char a;
unsigned short b;
unsigned char buffer[10];
}structure_test;
printf("structure_test.buffer = %p \n", structure_test.buffer);
printf("&structure_test.buffer = %p \n", &structure_test.buffer);
Wayne_
Posted: Mon Sep 13, 2010 1:47 am |
| It also depends on the buffer, if it is a defined array then the compiler knows the size of the overall structure and should clear all memory, if it is a dynamic buffer (pointer) then you would need to free this as clearing the structure will nullify the pointer, you would then re-allocate a new buffer to your pointer. |
Posted: Mon Sep 13, 2010 3:32 am |
But of course, far more efficient, to use pointers, and reset these, leaving the contents uncleared. Saved a huge amount of processing to do it this way.....
