piire
| rs485 - SP490 or MAx490 Full Duplex ??? |
Posted: Sat Sep 11, 2010 4:48 pm |
hi there,
I was wondering if full duplex rs-485 chip such as the sp490 or max490 work with ccs?
do you use the following code without the enable, you normally use with the half duplex rs485, as there is a dedicated line for tx and rx?
#use rs232(baud=9600,rcv=PIN_C7,xmit=PIN_C6,stream=PIC)
So i would just need to connect RO to C7-RX and DI to C6-TX, or is there any other code i need to use? i have searched the forums but couldn't find the answer, i sorry if this has been asked before!
I'm going to use this to connect two pic together, which is not in master and slave mode. so the full duplex with four wire, which i can be use for long distance transmissions.
thanks in advance
piire! |
Humberto
Posted: Sat Sep 11, 2010 7:33 pm |
| Quote: |
Yes. both are transceivers to use with RS485 levels.
| Quote: |
No. You should define as follow:
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, enable=PIN_xx, stream=PIC)
Then wire the transceiver as follows:
PIN_C7 to RO
PIN_C6 to DI
and
PIN_xx to DE
PIN_xx to RE
DE and RE are wired together to use it in half duplex.
Write code as usual with RS232.
Humberto |
piire
Posted: Sun Sep 12, 2010 3:48 am |
the sp490 and max490 dont have DE and RE pins
the data sheet is below, the enable pins is used to determine if you can send or receive. or is the enable used to tell the complier that a rs485 ic is being used?
http://www.datasheetcatalog.org/datasheet/sipex/SP490.pdf
thanks
piire |
Posted: Sun Sep 12, 2010 4:18 am |
Yes.
There are two different 'full duplex' setups used. Humberto, is thinking I think of the 491 chip, where you still have the RE/DE pins, so that you can still have multiple master devices on the bus.
With the 490, you effectively just have an alternative 'point to point' signaling method, as a direct replacement for RS232. You can still have multiple receivers tapped onto the bus, but no ability for these other devices to transmit. The bus becomes 'single master' in each direction.
If all you want is a point to point connection between two devices, the 490, offers nice long distances, compared to RS232, but at the 'cost' of needing four wires.
It'll work just like RS232 with sch a connection, with no enable needed.
piire
Posted: Sun Sep 12, 2010 5:47 am |
Thank you for your advice, the confusion is cleared up!
regards
piire! |
