program LCD in C
oran
program LCD in C
PostPosted: Thu Sep 09, 2010 11:46 am     Reply with quote
I'm trying now to control an LCD display (LM044L) with a pic 16F877A.
I need a program the pic in C and compiled with CCS PCW.
and here are my connections:
RD0 -> E
RD1 -> RS
RD2 -> R / W
RD4 -> D4
RD5 -> D5
RD6 -> D6
RD7 -> D7
D0 ,D1 ,D2 ,D3 in air
VSS in ground
VDD in alimentation
VEE in potentiometer
help me
PostPosted: Thu Sep 09, 2010 12:59 pm     Reply with quote
I'm trying now to control an LCD display (LM044L).
That's a 20x4 lcd, so you can use the Flex 20x4 driver:
http://www.ccsinfo.com/forum/viewtopic.php?t=28268
oran
program LCD in c
PostPosted: Thu Sep 09, 2010 4:53 pm     Reply with quote
I do not want that, I need a simple program which controls the LCD based on a 4-bit PIC16F877 which displays two lines such as the duty ratio of chopper
help me
deperkin
PostPosted: Thu Sep 09, 2010 6:07 pm     Reply with quote
the flex driver that he gave you in the above link will do that.
all you need to do is print to the lines you want.
It will work for your lcd.
dyeatman
PostPosted: Thu Sep 09, 2010 6:12 pm     Reply with quote
In two successive posts he has been asking for someone to write his
program for him. He started out saying he wasn't a C programmer.
Apparently he wants someone to write the program, debug it, compile it with
PCW and give him the hex file...
Google and Forum Search are some of your best tools
oran
program LCD in c
PostPosted: Thu Sep 09, 2010 6:20 pm     Reply with quote
I have a project to do as regards the control of a chopper mosfet is connected to the LCD is well worth the duty cycle is possible that if you help me write a few lines necessary to correspondent to charge my notebook, we of course respect the connections
help me
deperkin
PostPosted: Thu Sep 09, 2010 6:58 pm     Reply with quote
Hi Oran,
I don't quite understand what you are looking for.
You want to charge your notebook? what type of connection?
The link to the LCD program provided will help you with the LCD part of the code.
What language do you speak? I can translate if you like.
Please clarify what you are looking for.
oran
LCD programming in C
PostPosted: Fri Sep 10, 2010 4:21 am     Reply with quote
I just need a program in C using CCS PCW compiler, in my setup to simulate under ISIS a pic 16f877A + LCD (LMO44L) to 4 bits, connections here is message previous to view a value example .
help me.
