How do I Printf a Semicolon between 2 bits of text ?
P D
PostPosted: Fri Jan 30, 2004 5:08 am     Reply with quote
Hi everyone,
How do I printf a Semicolon between 2 bits of text? i.e.
printf( "Here is the "problem" I have" );
I want to see :
appear on my screen.
Thanks in advance, Question
Peter
P D
Sorry, Not Semicolon - I mean Inverted commas
PostPosted: Fri Jan 30, 2004 5:12 am     Reply with quote
Peter
wedilo
PostPosted: Fri Jan 30, 2004 5:28 am     Reply with quote
Hello P D,
Normally you can use the fprintf command with %c and append the char as ascii No. 34
But I think the following way with the Backslash is also possible.
34dez = 22hex
printf( "Here is the \x22problem\x22 I have" );    ???
or...
printf( "Here is the '\x22'problem'\x22' I have" );
or...
printf( "Here is the 'problem' I have" );    :-)
I can't try it here. Please try it out and inform me...
Hope to help you
73 Sven
PostPosted: Fri Jan 30, 2004 5:43 am     Reply with quote
wedilo wrote:
Hello P D,
34dez = 22hex
or...
or...
Hope to help you
73 Sven
Potentially you can put any ASCII value into a string using the \nnn format.
The allowable 'extra' string characters are:
\a 'bell' alert character
\b 'backspace'
\f 'formfeed'
\n 'newline'
\r 'carriage return'
\t 'horizontal tab'
\v 'vertical tab'
\\ the bakslash character itself.
\? the ? character
\' the single quote character
\" the double quote character
\ooo Any ASCII character. Three octal digits
\xhh Any ASCII character. Two hex digits.
I think:
printf( "Here is the \"problem\" I have" );
Is probably clearer, and easier to remember.
PostPosted: Fri Jan 30, 2004 9:53 am     Reply with quote
I finally got
printf( "Here is the %Cproblem%C I have", 0x22, 0x22 );
to work
I think I tried the
option but as soon as it saw the " it thought that was the end of the string and carried on to make nonsense of the rest.
I can't use ' as the " is part of a fixed protocol I am working on.
I will try all the others and see what works and which is the most compact.
Thanks for the help everyone,
Peter
Al
PostPosted: Fri Jan 30, 2004 10:41 am     Reply with quote
This works for me and it is simple.
printf("\r\n the \"problem\" i am having"); Smile
Alan Murray
dgoldman
A broken corner case to watch for:
PostPosted: Tue Aug 24, 2010 2:52 pm     Reply with quote
Broken corner case to watch for:
#define FOO "D=1\""
printf(FOO);
doesn't work on PCWH 4.111. I think it is the double "".
To get this to work, change to
#define FOO "D=1\x22"
printf(FOO);
Wayne_
PostPosted: Wed Aug 25, 2010 1:54 am     Reply with quote
the \ is the escape char in C, if you escape a " e.g. "\"" then the compiler should ignore this as a start/end of string qualifier and just use it as a quote char.
printf ("Here is the \"problem\" I have");
Should work, if it does not then there is an error in the compiler.
To actually display a \ you would
printf("\\");
Gabriel
PostPosted: Wed Aug 25, 2010 7:40 am     Reply with quote
This is what I used in my code:
printf("AT+CPMS=\"ME\",\"ME\",\"ME\"");
CCS PCM 5.078 & CCS PCH 5.093
