farouk_baya
| real time clock with 18f4550 |
Posted: Fri Aug 20, 2010 6:26 pm |
I do a real time clock with 18f4550 and I use PICKIT2 for programming of the PIC.
This is my program.
#include "18f4550.h"
#fuses XT,PUT,NOWDT,NOPROTECT,NOLVP
#use delay(clock=4M)
#define INTS_PER_SECOND 122//225 // (4000000/(4*32*256))
#include <stdlib.h>
#include "flex_lcd.c"
//declaration des varriables
int8 secon=0,minu=0,heur=0,int_count,nb=0;
int8 days=0,month=0;
int16 year=0;
int8 verif;
char debut[46]=" veuillez rectifier l'horloge ";
#define IS_LEAP(year) (year%4 == 0)
#int_rtcc // cette fonction est appéle à chaque debordement de rtcc
void RTCC_isr(void)
if(secon == 60) {minu++; secon=0;
if(minu == 60) {heur++; minu=0;
if(heur == 24) {days++; heur=0;
if ( (days == 29 && month==2 && !IS_LEAP(Year))
|| (days == 30 && month==2)
|| (days == 31 && (month==4 || month==6 || month==9 || month==11 ))
|| (days == 32)
) {month++;days=0;}
if(month == 13) {year++; month=0;}
if(--int_count==0)
++secon;
int_count=INTS_PER_SECOND;
int8 D_H,U_H,D_M,U_M,D_S,U_S,D_D,U_D,D_Mo,U_Mo,Y3;
int8 T[12];
int8 T1[8]={9,10,12,13,15,16};
int8 T2[6]={16,15,11,10,8,7};
int8 i=0;
char aux;
enable_interrupts(INT_RTCC);
setup_timer_0(RTCC_INTERNAL|RTCC_8_BIT|RTCC_DIV_32);
T[0]=D_H;
T[1]=0;
T[2]=0;
T[3]=0;
T[4]=0;
T[5]=0;
T[6]=0;
T[7]=0;
T[8]=0;
T[9]=0;
T[10]=0;
T[11]=0;
//***********************ouverture du programme*********************
lcd_init();
delay_ms(50);
lcd_gotoxy(1,1);
printf(lcd_putc," BISMI ELLEH ");
lcd_gotoxy(1,2);
printf(lcd_putc,"****************");
delay_ms(2000);
//************************intro
defilement*************************************
for(i=0;i<40;i++)
lcd_gotoxy(1,1);
printf(lcd_putc,debut);
lcd_gotoxy(1,2);
for(i=0;i<46;i++)
aux=debut[i];
debut[i]=debut[i+1];
debut[i+1]=aux;
delay_ms(200);
//***********************pour passer à la rectification*************
while (!input(PIN_B0))
lcd_gotoxy(1,1);
lcd_gotoxy(1,2);
printf(lcd_putc,"Appuier sur '+'");
for(i=0;i<46;i++)
aux=debut[i];
debut[i+1]=aux;
delay_ms(200);
lcd_gotoxy(1,1);
printf(lcd_putc,"HEURE 00:00:00");
lcd_gotoxy(1,2);
printf(lcd_putc,"DATE 00/00/2000");
//************************rectification de l'heure******************************
nb=0;
while(nb<6)
if(input(PIN_B1))
nb++;
lcd_gotoxy(1,1);
printf(lcd_putc,"HEURE %d%d:%d%d:%d%d",T[0],T[1],T[2],T[3],T[4],T[5]);
delay_ms(1);
if(input(PIN_B0))
//*********************D_H************************
if (nb==0)
if (T[nb]==2)
T[nb]=0;
while(input(PIN_B0));
T[nb]=T[nb]+1;
//*********************U_H************************
if (nb==1)
if(T[0]==2)
if (T[nb]==3)
T[nb]=0;
T[nb]=T[nb]+1;
if(T[0]==1)
if (T[nb]==9)
T[nb]=0;
T[nb]=T[nb]+1;
//*********************D_M************************
if (nb==2)
if (T[nb]==5)
T[nb]=0;
T[nb]=T[nb]+1;
//*********************U_M************************
if (nb==3)
if (T[nb]==9)
T[nb]=0;
T[nb]=T[nb]+1;
//*********************D_S************************
if (nb==4)
if (T[nb]==5)
T[nb]=0;
T[nb]=T[nb]+1;
//*********************U_S************************
if (nb==5)
if (T[nb]==9)
T[nb]=0;
T[nb]=T[nb]+1;
lcd_gotoxy(T1[nb],1);
printf(lcd_putc,"%d",T[nb]);
printf(lcd_putc,"_");
nb=0;
lcd_gotoxy(1,1);
lcd_gotoxy(1,2);
while(nb<6)
if(input(PIN_B1))
nb++;
lcd_gotoxy(1,2);
printf(lcd_putc,"DATE %d%d/%d%d/20%d%d",T[11],T[10],T[9],T[8],T[7],T[6]);
delay_ms(1);
if(input(PIN_B0))
//*********************Y4************************
if (nb==0)
if (T[nb+6]==9)
T[nb+6]=0;
T[nb+6]=T[nb+6]+1;
//*********************Y3************************
if (nb==1)
if (T[nb+6]==9)
T[nb+6]=0;
T[nb+6]=T[nb+6]+1;
//*********************calcul de l'année************************
year=2000+10*T[7]+T[6];
verif=year%4;
//*********************U_Mo************************
if (nb==2)
if (T[nb+6]==9)
T[nb+6]=0;
T[nb+6]=T[nb+6]+1;
//*********************D_Mo************************
if (nb==3)
if (T[8]<=9 && T[8]>2 )
if (T[nb+6]==0)
T[nb+6]=0;
T[nb+6]=T[nb+6]+1;
if (T[8]<=2 )
if (T[nb+6]==1)
T[nb+6]=0;
T[nb+6]=T[nb+6]+1;
//********************calcul month****************
month=T[9]*10+T[8];
//*********************U_D************************
if (nb==4)
if (T[nb+6]==9)
T[nb+6]=0;
T[nb+6]=T[nb+6]+1;
//*********************D_D************************
if (nb==5)
if (T[10]<=9 && T[10]>1 )
if (T[nb+6]==2)
T[nb+6]=0;
T[nb+6]=T[nb+6]+1;
if (T[10]<=1 )
if (T[nb+6]==3)
T[nb+6]=0;
T[nb+6]=T[nb+6]+1;
lcd_gotoxy(T2[nb],2);
printf(lcd_putc,"%d",T[nb+6]);
secon=T[4]*10+T[5];
minu=T[2]*10+T[3];
heur=T[0]*10+T[1];
days=T[11]*10+T[10];
//**********************fin rectification de l'heure****************************
while(true)
D_H=heur/10;
U_H=heur-10*D_H;
D_M=minu/10;
U_M=minu-10*D_M;
D_S=secon/10;
U_S=secon-10*D_S;
D_D=days/10;
U_D=days-10*D_D;
D_Mo=month/10;
U_Mo=month-10*D_Mo;
Y3=(year-2000);
lcd_gotoxy(1,1);
printf(lcd_putc,"HEURE %d%d:%d%d:%d%d",D_H,U_H,D_M,U_M,D_S,U_S);
lcd_gotoxy(1,2);
printf(lcd_putc,"DATE %d%d/%d%d/20%02d",D_D,U_D,D_Mo,U_Mo,Y3);
When I simulate this program with ISIS it works fine but when I try it,
it doesn't work correctly.
I have no idea and its very urgent.
I upload all my files here:
http://www.mediafire.com/?zrrcprvmu4cret3
Thanks.
[/code] |
Posted: Sat Aug 21, 2010 4:35 am |
Obvious things to look at if code runs in the simulator, but not for real, are:
1) Your clock. Have you actually got a 4MHz crystal attached, have you got the right loading capacitors for this, etc. etc.?. How long are the wires to the crystal. Any chance they could be picking up other signals, etc.
2) Your supply. Nicely smoothed 5v, with a small decoupling capacitor close to the PIC.
3) How is MCLR connected?.
Have you proved the processor runs, and runs at the right frequency, with a simple 'display hello', then display a counter, type program?.
farouk_baya
Posted: Sat Aug 21, 2010 9:56 am |
The problem is not that the program doesn't work in the board but that the frequency of running at the right frequency.
If you see the file that I uploaded you can see that I try it with 16f877a and it run very well in reality. But when I use the 18f4550 in the same circuit it run but not in the same frequency.
So help please.
Also if you have remarks for the program I wish that I ameliorate my program.
THANKS. |
farouk_baya
Posted: Sat Aug 21, 2010 3:00 pm |
The PLL division ration is not a problem.
You have the XT fuse selected, which doesn't _use_ the PLL for the CPU clock.
The bits are set to '1' by default, hence the maximum PLL value is selected.
What I don't see is the CPUDIV1 fuse. Also you have the USB voltage regulator enabled (again default), which you should really turn off, if you are not using the USB.
farouk_baya
Posted: Sat Aug 21, 2010 8:13 pm |
Thanks a lot. I have added "#FUSES CPUDIV1 , NOVREGEN " to my code and it runs at the right frequency.
I want to learn more about fuses if you can give me an URL or some thing to read which is useful.
Thanks again, and if you can give me advices to ameliorate my code if it's possible.
THANKS. |
Posted: Sun Aug 22, 2010 4:12 am |
No URL.
With the compiler, there is a 'fuses.txt' file, that gives descriptions for the CCS names.
Then the processor data sheet is 'God'....
If (for example), you look at the oscillator diagram, you will see that the external clock comes in, and routes in three possible directions. When 'XT, HS, EC, or EC_IO' are selected (the last two needing an external oscillator), the clock goes directly to the CPUDIV multiplexor, and then on to the processor, without involving the PLL.
farouk_baya
Posted: Sun Aug 22, 2010 9:49 am |
THANKS A LOT
But what about ameliorating my code?? |
Humberto
Posted: Sun Aug 22, 2010 12:45 pm |
Your code its too large and require extra hardware to test it, hence it would be improbable to get some help from somebody.
Try to implement some basic procedure like an RS232 mssge monitoring, some bliking LEDs, etc in order to debug your
project in real time.
Regarding the FUSES, I hope that this would help you:
http://www.ccsinfo.com/forum/viewtopic.php?t=24336&highlight=fuses
Humberto |
farouk_baya
Posted: Sun Aug 22, 2010 5:05 pm |
I tried this program in the board and it works fine.
But I think it is so long, so how can I enhance it ?
THANKS |
