tahirmaqsood
| digital code lock with 3310 lcd |
Posted: Fri Aug 13, 2010 4:59 am |
hi
i whant attach 3310 lcd with this code
SAFE_COMBO_02.C
PIC 16F628 Combination Lock
- resets to first expected digit two seconds after last key is pressed
- uses PWM to reduce current to coil after initial pulse
+5 --14-|VCC B0|-17-----|C1 |
| B1|-18-----|C2 |
Gnd ---5-| B2|-1------|C3 |
6MHz XTAL --16-| B4|-2------|R1 KBD |
XTAL --15-| B5|-6------|R2 |
| B6|-7------|R3 |
| B7|-8------|R4 |
| 16F628 | ----------
| B3|-6--- LOCK SOLENOID
| A1|-18-- LED
| 1 2 3 | R0
| 4 5 6 | R1
| 7 8 9 | R2
| * 0 # | R3
C0 C1 C2
Keyboard connector is (backside): C2 C1 C0 R3 R2 R1 R0
Oscillator = 6MHz crystal
Jon Fick 03/09/07
#include <16F628A.h>
#include
// Set configuration bits in the PIC processor
#fuses HS, NOPROTECT, NOWDT, PUT, BROWNOUT, NOMCLR, NOLVP
#define COMBO_1 '1'
#define COMBO_2 '2'
#define COMBO_3 '3'
#define COMBO_4 '4'
#define COMBO_5 '5'
#define COMBO_6 '6'
#define KBD_C1 PIN_B0
#define KBD_C2 PIN_B1
#define KBD_C3 PIN_B2
#define KBD_R1 PIN_B4
#define KBD_R2 PIN_B5
#define KBD_R3 PIN_B6
#define KBD_R4 PIN_B7
#define LOCK_OUT PIN_B3
#define LED PIN_A1
#define NOKEY 0xFF
#define RESET_KBD_COUNT 46 // at 23 counts/second
#define LOCK_HIGH 255 // full PWM duty cycle
#define LOCK_HIGH_TIME 30 // mS at full coil current
#define LOCK_MED 20 // partial PWM duty cycle
#define LOCK_MED_TIME 1450 // mS at partial coil current
#define LOCK_OFF 0 // no PWM current
#use delay ( clock = 6000000 ) // sets appropriate compiler constants
#use standard_io ( A )
#use standard_io ( B )
char GetKey ( void ); // prototypes
static char cKbdTimeoutFlag, cLedCount;
#int_rtcc
void TimerInterrupt ( void ) // 43mS tic, 23/second
if ( cKbdTimeoutFlag != 0 )
cKbdTimeoutFlag--; // count down to zero
if ( cLedCount++ > 12 )
cLedCount = 0;
if ( cLedCount > 6 )
output_high ( LED );
output_low ( LED );
void main ( void )
delay_ms ( 100 ); // power up delay
output_low ( LOCK_OUT ); // turn off lock solenoid */
output_low ( LED );
port_b_pullups ( TRUE ); /* enable pullups */
setup_counters ( RTCC_INTERNAL, RTCC_DIV_256 );
cLedCount = 0;
// PWM is for relay current control
setup_ccp1 ( CCP_PWM ); // set for PWM mode
//The cycle time will be ( 1 / clock ) * 4 * t2div * ( period + 1 )
// 1/6000000 * 4 * 1 * 64 = 42uS = 23KHz
setup_timer_2 ( T2_DIV_BY_1, 64, 1 ); // set PWM period
// duty cycle = value * ( 1 / clock ) * t2div
// val * 1/6000000 * 1 = 1.2uS
set_pwm1_duty ( LOCK_OFF ); // set output off
enable_interrupts ( INT_RTCC ); /* turn on timer interrupt */
enable_interrupts ( GLOBAL ); /* enable interrupts */
while ( TRUE )
while ( TRUE )
if ( GetKey() != COMBO_1 )
if ( GetKey() != COMBO_2 )
if ( GetKey() != COMBO_3 )
if ( GetKey() != COMBO_4 )
if ( GetKey() != COMBO_5 )
if ( GetKey() != COMBO_6 )
set_pwm1_duty ( LOCK_HIGH ); // set output high current
delay_ms ( LOCK_HIGH_TIME );
set_pwm1_duty ( LOCK_MED ); // set output medium current
delay_ms ( LOCK_MED_TIME );
char cKey;
cKbdTimeoutFlag = RESET_KBD_COUNT;
cKey = NOKEY; /* default is invalidated key */
output_low ( KBD_R1 ); /* make all four rows low */
output_low ( KBD_R2 );
output_low ( KBD_R3 );
output_low ( KBD_R4 );
delay_ms ( 5 ); /* wait for row lines to settle */
// wait until a button is pressed
while ( ( input ( KBD_C1 ) == HIGH ) && ( input ( KBD_C2 ) == HIGH ) && ( input ( KBD_C3 ) == HIGH ) )
if ( cKbdTimeoutFlag == 0 ) // if counted down to zero
return ( cKey ); // timed out, return NOKEY
while ( TRUE )
output_low ( KBD_R1 ); // try Row 1
output_high ( KBD_R2 );
output_high ( KBD_R3 );
output_high ( KBD_R4 );
delay_ms ( 1 );
if ( input ( KBD_C1 ) == LOW )
cKey = '1';
if ( input ( KBD_C2 ) == LOW )
cKey = '2';
if ( input ( KBD_C3 ) == LOW )
cKey = '3';
output_high ( KBD_R1 ); // try Row 2
delay_ms ( 1 );
cKey = '4';
cKey = '5';
cKey = '6';
output_high ( KBD_R1 ); // try Row 3
delay_ms ( 1 );
cKey = '7';
cKey = '8';
cKey = '9';
output_high ( KBD_R1 ); // try Row 4
delay_ms ( 1 );
cKey = '*';
cKey = '0';
cKey = '#';
break; // break anyway to ensure no endless loop
delay_ms ( 5 );
// wait until all buttons are up
while ( ( input ( KBD_C1 ) == LOW ) || ( input ( KBD_C2 ) == LOW ) || ( input ( KBD_C3 ) == LOW ) );
// make all four rows high
return ( cKey );
3310 lcd driver
Graphic LCD Nokia 3310 (LPH7779) routines v3
CCS compiler
by Michel Bavin 2004 --- bavin@skynet.be --- http://users.skynet.be/bk317494/ ---
august 29, 2004
// ex:
// nokia_init();
// nokia_gotoxy(0,0);
// printf(nokia_printchar,"test???");
#define nok_sclk PIN_D4
#define nok_sda PIN_D3
#define nok_dc PIN_D2
#define nok_cs PIN_D1
#define nok_res PIN_D0
char char_row,charsel,charpos,chardata; // for nokia_3310 lcd
int16 ddram;
char plot_value;
int32 plot_value32;
int32 plot_umsb,plot_lmsb,plot_ulsb,plot_llsb;
BYTE const TABLE5[240]= {0x00,0x00,0x00,0x00,0x00, // 20 space ASCII table for NOKIA LCD: 96 rows * 5 bytes= 480 bytes
0x00,0x00,0x5f,0x00,0x00, // 21 !
0x00,0x07,0x00,0x07,0x00, // 22 "
0x14,0x7f,0x14,0x7f,0x14, // 23 #
0x24,0x2a,0x7f,0x2a,0x12, // 24 $
0x23,0x13,0x08,0x64,0x62, // 25 %
0x36,0x49,0x55,0x22,0x50, // 26 &
0x00,0x05,0x03,0x00,0x00, // 27 '
0x00,0x1c,0x22,0x41,0x00, // 28 (
0x00,0x41,0x22,0x1c,0x00, // 29 )
0x14,0x08,0x3e,0x08,0x14, // 2a *
0x08,0x08,0x3e,0x08,0x08, // 2b +
0x00,0x50,0x30,0x00,0x00, // 2c ,
0x08,0x08,0x08,0x08,0x08, // 2d -
0x00,0x60,0x60,0x00,0x00, // 2e .
0x20,0x10,0x08,0x04,0x02, // 2f /
0x3e,0x51,0x49,0x45,0x3e, // 30 0
0x00,0x42,0x7f,0x40,0x00, // 31 1
0x42,0x61,0x51,0x49,0x46, // 32 2
0x21,0x41,0x45,0x4b,0x31, // 33 3
0x18,0x14,0x12,0x7f,0x10, // 34 4
0x27,0x45,0x45,0x45,0x39, // 35 5
0x3c,0x4a,0x49,0x49,0x30, // 36 6
0x01,0x71,0x09,0x05,0x03, // 37 7
0x36,0x49,0x49,0x49,0x36, // 38 8
0x06,0x49,0x49,0x29,0x1e, // 39 9
0x00,0x36,0x36,0x00,0x00, // 3a :
0x00,0x56,0x36,0x00,0x00, // 3b ;
0x08,0x14,0x22,0x41,0x00, // 3c <
0x14,0x14,0x14,0x14,0x14, // 3d =
0x00,0x41,0x22,0x14,0x08, // 3e >
0x02,0x01,0x51,0x09,0x06, // 3f ?
0x32,0x49,0x79,0x41,0x3e, // 40 @
0x7e,0x11,0x11,0x11,0x7e, // 41 A
0x7f,0x49,0x49,0x49,0x36, // 42 B
0x3e,0x41,0x41,0x41,0x22, // 43 C
0x7f,0x41,0x41,0x22,0x1c, // 44 D
0x7f,0x49,0x49,0x49,0x41, // 45 E
0x7f,0x09,0x09,0x09,0x01, // 46 F
0x3e,0x41,0x49,0x49,0x7a, // 47 G
0x7f,0x08,0x08,0x08,0x7f, // 48 H
0x00,0x41,0x7f,0x41,0x00, // 49 I
0x20,0x40,0x41,0x3f,0x01, // 4a J
0x7f,0x08,0x14,0x22,0x41, // 4b K
0x7f,0x40,0x40,0x40,0x40, // 4c L
0x7f,0x02,0x0c,0x02,0x7f, // 4d M
0x7f,0x04,0x08,0x10,0x7f, // 4e N
0x3e,0x41,0x41,0x41,0x3e // 4f O
BYTE const TABLE6[240]= {0x7f,0x09,0x09,0x09,0x06, // 50 P
0x3e,0x41,0x51,0x21,0x5e, // 51 Q
0x7f,0x09,0x19,0x29,0x46, // 52 R
0x46,0x49,0x49,0x49,0x31, // 53 S
0x01,0x01,0x7f,0x01,0x01, // 54 T
0x3f,0x40,0x40,0x40,0x3f, // 55 U
0x1f,0x20,0x40,0x20,0x1f, // 56 V
0x3f,0x40,0x38,0x40,0x3f, // 57 W
0x63,0x14,0x08,0x14,0x63, // 58 X
0x07,0x08,0x70,0x08,0x07, // 59 Y
0x61,0x51,0x49,0x45,0x43, // 5a Z
0x00,0x7f,0x41,0x41,0x00, // 5b [
0x02,0x04,0x08,0x10,0x20, // 5c
0x00,0x41,0x41,0x7f,0x00, // 5d
0x04,0x02,0x01,0x02,0x04, // 5e
0x40,0x40,0x40,0x40,0x40, // 5f
0x00,0x01,0x02,0x04,0x00, // 60
0x20,0x54,0x54,0x54,0x78, // 61 a
0x7f,0x48,0x44,0x44,0x38, // 62 b
0x38,0x44,0x44,0x44,0x20, // 63 c
0x38,0x44,0x44,0x48,0x7f, // 64 d
0x38,0x54,0x54,0x54,0x18, // 65 e
0x08,0x7e,0x09,0x01,0x02, // 66 f
0x0c,0x52,0x52,0x52,0x3e, // 67 g
0x7f,0x08,0x04,0x04,0x78, // 68 h
0x00,0x44,0x7d,0x40,0x00, // 69 i
0x20,0x40,0x44,0x3d,0x00, // 6a j
0x7f,0x10,0x28,0x44,0x00, // 6b k
0x00,0x41,0x7f,0x40,0x00, // 6c l
0x7c,0x04,0x18,0x04,0x78, // 6d m
0x7c,0x08,0x04,0x04,0x78, // 6e n
0x38,0x44,0x44,0x44,0x38, // 6f o
0x7c,0x14,0x14,0x14,0x08, // 70 p
0x08,0x14,0x14,0x18,0x7c, // 71 q
0x7c,0x08,0x04,0x04,0x08, // 72 r
0x48,0x54,0x54,0x54,0x20, // 73 s
0x04,0x3f,0x44,0x40,0x20, // 74 t
0x3c,0x40,0x40,0x20,0x7c, // 75 u
0x1c,0x20,0x40,0x20,0x1c, // 76 v
0x3c,0x40,0x30,0x40,0x3c, // 77 w
0x44,0x28,0x10,0x28,0x44, // 78 x
0x0c,0x50,0x50,0x50,0x3c, // 79 y
0x44,0x64,0x54,0x4c,0x44, // 7a z
0x00,0x08,0x36,0x41,0x00, // 7b
0x00,0x00,0x7f,0x00,0x00, // 7c
0x00,0x41,0x36,0x08,0x00, // 7d
0x10,0x08,0x08,0x10,0x08, // 7e
0x78,0x46,0x41,0x46,0x78 // 7f
void nokia_init(void);
void nokia_write_command(char bytefornokia_command);
void nokia_write_data(char bytefornokia_data);
void nokia_write_dorc(char bytefornokia);
void nokia_gotoxy(int8 xnokia, int8 ynokia);
void nokia_erase_y(int8 ynokia);
void nokia_erase_x(int8 xnokia);
void nokia_printchar(int8 cvar);
void nokia_clean_ddram(void);
void table_to_nokialcd(void);
void nokia_plot(int8 xnokia,int8 plot_value8);
void nokia_write_data_inv(char bytefornokia_data_inv);
void nokia_clear_screen(void);
void nokia_clear_xy(int8 xnokia, int8 ynokia);
void nokia_print_uparrow(void);
void nokia_print_downarrow(void);
void nokia_print_leftarrow(void);
void nokia_print_rightarrow(void);
void nokia_print_degree(void);
void nokia_print_lowbatdegree(void);
output_high(nok_dc); // bytes are stored in the display data ram, address counter, incremented automatically
output_high(nok_cs); // chip disabled
output_low(nok_res); // reset chip during 250ms
delay_ms(10); // works with less.....
output_high(nok_res);
nokia_write_command(0x21); // set extins extended instruction set
nokia_write_command(0xc2); // Vop v1: 0xc8 (for 3V)// v2: 0xa0 (for 3V) // v3: 0xc2 (2v6-5v) ********************************************************************************************************************
nokia_write_command(0x13); // bias
nokia_write_command(0x20); // horizontal mode from left to right, X axe are incremented automatically , 0x22 for vertical addressing ,back on normal instruction set too
nokia_write_command(0x09); // all on
nokia_clean_ddram(); // reset DDRAM, otherwise the lcd is blurred with random pixels
nokia_write_command(0x08); // mod control blank change (all off)
nokia_write_command(0x0c); // mod control normal change
nokia_gotoxy(0,0); // 84*6=504 clear LCD
for (ddram=504;ddram>0;ddram--){nokia_write_data(0x00);}
output_low(nok_dc); // byte is a command it is read with the eight SCLK pulse
output_low(nok_cs); // chip enabled
nokia_write_dorc(bytefornokia_command);
nokia_write_dorc(bytefornokia_data);
void nokia_write_dorc(char bytefornokia) // serial write data or command subroutine
char caa;
for (caa=8;caa>0;caa--) {
output_low(nok_sclk);
// delay_us(2);
if ((bytefornokia&0x80)==0){output_low(nok_sda);}
else {output_high(nok_sda);}
output_high(nok_sclk);
bytefornokia=bytefornokia<<1;
void nokia_gotoxy(int8 xnokia, int8 ynokia) // Nokia LCD 3310 Position cursor
nokia_write_command(0x40|(ynokia&0x07)); // Y axe initialisation: 0100 0yyy
nokia_write_command(0x80|(xnokia&0x7f)); // X axe initialisation: 1xxx xxxx
nokia_gotoxy(0,ynokia);
printf(nokia_printchar," ");
char column;
for (column=0;column!=6;column++){
nokia_gotoxy(xnokia,column);
void nokia_printchar(int8 cvar) // Write 1 character to LCD
charsel=cvar;
table_to_nokialcd();
void table_to_nokialcd(void) // extract ascii from tables & write to LCD
if (charsel<0x20)return;
if (charsel>0x7f)return;
for (char_row=0;char_row<5;char_row++) { // 5 bytes
if (charsel<0x50){charpos=(((charsel&0xff)-0x20)*5);chardata=TABLE5[(charpos+char_row)];} // use TABLE5
else if (charsel>0x4f){charpos=(((charsel&0xff)-0x50)*5);chardata=TABLE6[(charpos+char_row)];} // use TABLE6
nokia_write_data(chardata); // send data to nokia
nokia_write_data(0x00); // 1 byte (always blank)
char i;
plot_value32=0;
// plot_value32|=1; // unremark this if you want dotgraph instead of bargraph
for (i=0;i!=plot_value8;i++){
plot_value32|=1; // remark this if you want dotgraph instead of bargraph
plot_value32<<=1;
plot_value32|=2; // bottom line is always filled
plot_llsb=(plot_value32&0xff);
plot_ulsb=((plot_value32>>8)&0xff);
plot_lmsb=((plot_value32>>16)&0xff);
plot_umsb=((plot_value32>>24)&0xff);
nokia_gotoxy(xnokia,1);
nokia_write_data_inv(plot_umsb);
nokia_gotoxy(xnokia,2);
nokia_write_data_inv(plot_lmsb);
nokia_gotoxy(xnokia,3);
nokia_write_data_inv(plot_ulsb);
nokia_gotoxy(xnokia,4);
nokia_write_data_inv(plot_llsb);
char caa;
delay_us(2);
if ((bytefornokia_data_inv&0x01)==0){output_low(nok_sda);}
bytefornokia_data_inv=bytefornokia_data_inv>>1;
nokia_erase_y(0);
nokia_erase_y(1);
nokia_erase_y(2);
nokia_erase_y(3);
nokia_erase_y(4);
nokia_erase_y(5);
nokia_gotoxy(xnokia,ynokia);
nokia_printchar(" ");
nokia_write_data(0x04);
nokia_write_data(0x02);
nokia_write_data(0x7f);
nokia_write_data(0x10);
nokia_write_data(0x20);
nokia_write_data(0x08);
nokia_write_data(0x1c);
nokia_write_data(0x2a);
nokia_write_data(0xf8);
nokia_write_data(0x06);
nokia_write_data(0x09);
// nokia_printchar(" ");
nokia_write_data(0x0f);
