measuring pulse frequency using timer0
hayee
PostPosted: Sat Aug 07, 2010 12:02 am     Reply with quote
I want to measure pulses frequency using timer0. Pulses frequency is from 0 Hz to 2kHz. Can anyone tell me how to do that? Give me a sample program.
I am using CCS compiler version 4.093 and pic 18f252.
hayee
PostPosted: Sun Aug 08, 2010 11:38 pm     Reply with quote
Guys any solution or hints
Geps
PostPosted: Mon Aug 09, 2010 6:10 am     Reply with quote
You could use the RB interrupt and record the time differences.
bkamen
PostPosted: Mon Aug 09, 2010 7:23 am     Reply with quote
You have the CCP module which will be a much more hardware accurate method.
Using timer0 is prone to interrupt service handling latency...
Use the CCP module and you'll be better off. Read the datasheet as most PIC's have this built in.
-Ben
hayee
PostPosted: Wed Aug 18, 2010 12:09 am     Reply with quote
What I am doing right now is that pulses is feed to the INT0/B0 pin, and I am counting the pulses using rising edge trigger. Now I also want to measure the pulses width or frequency.
If I use the CCP module as bkamen said then,
1st - I have to change my circuit.
2nd - Can I also count the pulses as i am doing right now ?
3rd - Is CCP module able to capture frequency of 1 --> 2kHz ?
hayee
PostPosted: Fri Sep 03, 2010 12:14 am     Reply with quote
I have written the following code to measure the frequency, but there is no accuracy. How I make more efficient code.
My theme for routine is this
>I have to measure the frequency of the signal from 2KHz to 10Hz.
>Frequency is coming at the int0 pin of 18f252 controller.
>In the code i select the value of prescaler so that the timer will not overflow until the ext interrupt (edge triggered) comes.
>when the ext int comes,the value of timer0 will be saved in a variable and then reset the timer.
>display the value on the PC using serial communtication.
#include <18f252.h>
#fuses HS,NOWDT,NOLVP,PUT,NOBROWNOUT
#use rs232(xmit=PIN_C6, rcv=PIN_C7, baud=9600)
long a;
#int_TIMER0
void timer0_interrupt(void)
 set_timer0(0);//if the timer overflows it reset the timer0
 clear_interrupt(int_TIMER0);
 enable_interrupts(int_TIMER0);
 output_toggle(PIN_C1);//if the timer overflows the led toggles.
#int_EXT
void EXT_isr(void)
 a=get_timer0();//when ext interrupt comes,then the value of timer is stored in variable
 set_timer0(0);//and then reset the timer,
 printf(" %lu \r\n",a);//print that value on PC
 output_toggle(PIN_C2);//toggle led2
 setup_timer_0(RTCC_INTERNAL | RTCC_DIV_8);//timer is in 16-bit mode,prescaler is 8
 set_timer0(0);//initially value of timer is 0
 enable_interrupts(INT_TIMER0);//enable timer0
 ext_int_edge(0,L_TO_H);//when interrupt goes low to high (rising edge)
 enable_interrupts(INT_EXT);//enable int0
 enable_interrupts(Global); //enable global interrupts
Any suggestion for improving the accuracy.
