Generating pwm
adalucio
Generating pwm
PostPosted: Thu Aug 05, 2010 6:56 am     Reply with quote
Hi all
I have a pic16f877a and I need to generate a pwm with frequency 153600 and duty 50%.
I have
I know I have to set timer2 and pwm1_duty. but I cannot find correct values.
for example I have tried
setup_timer_2(T2_DIV_BY_1, 31, 1);
set_pwm1_duty(66);
but it doesn't work
someone can help me?
thanks
PostPosted: Thu Aug 05, 2010 7:22 am     Reply with quote
Change the set_pwm_duty line, to:
set_pwm_duty(64L);
You need the 'L' to tell the compiler to treat the constant value as a 'long' integer. Look at the manual entry for the pwm_duty function to see why this is needed.
