shifting bits
Linuxbuilders
shifting bits
PostPosted: Mon Aug 02, 2010 7:40 am     Reply with quote
is there anyone who could explain to me why this is not the some thing?
PCH 4.107
data1dec_h = data1dec/0x100;
data1dec_l = (data1dec-(data1dec_h*0x100));
above works
data1dec_h = data1dec>>8;
data1dec_l = (data1dec-(data1dec_h<<8));
above does not work
thnx
Help "d" others and then you shell receive some help from "d" others.
Wayne_
PostPosted: Mon Aug 02, 2010 7:56 am     Reply with quote
What values do you get from each ?
How do you monitor those values ?
Linuxbuilders
PostPosted: Mon Aug 02, 2010 8:12 am     Reply with quote
int8 each joined into one int16, it does not compute to the some value, will post some examples tomorrow. Thnx
Wayne_
PostPosted: Mon Aug 02, 2010 8:24 am     Reply with quote
If your intention is to split a 16 bit value in to 2 8 bit values then the 2 options you have presented are not the best. If you are lucky the compiler will optimise it but the standard C way would be :-
int16 data1dec;
int8 data1dec_h, data1dec_l;
data1dec_h = data1dec >> 8;
data1dec_l = data1dec;  // Should automatically take the lower 8 bits
Or to be more specific
data1dec_l = data1dec & 0xFF;
Or to use CCS which most likely will provide the most efficient way
data1dec_h = make8(data1dec, 1);
data1dec_l = make8(data1dec, 0);
PostPosted: Mon Aug 02, 2010 9:06 am     Reply with quote
As for why it doesn't work, sizes....
If you take a 8bit value, and shift it left 8bits, you have nothing. It is an eight bit value, and everything disappears out the 'top'.
However if you take an 8bit value, and multiply it by 0x100, you get the byte in the top 8bits of a sixteen bit value.
The 'reason', is that 0x100, is inherently a 16bit integer. Hence when this is seen, the arithmetic is immediately switched to using 16bit operations.
Wayne_
PostPosted: Mon Aug 02, 2010 9:32 am     Reply with quote
Well spotted Smile
Linuxbuilders
PostPosted: Tue Aug 03, 2010 5:15 am     Reply with quote
cool bananas, thank you, now I understand...
by the way I did say wrong, I split one int16 value into 2x int8.
so it is like this:
int16 x;
int8 x_h, x_l;
x_h = x/0x100;
x_l = x-(x_h*0x100);
Linuxbuilders
PostPosted: Tue Aug 03, 2010 6:24 am     Reply with quote
so it is like this:
int16 x;
int8 x_h, x_l;
x_h = x/0x100;
This works:
int b, c, d;
long int a, aa, bb;
a = 0xAA;
b = 0xBB;
bb = a<<8;
aa = (bb)+b;
c = aa>>8;
d = aa;
