link555
Joined: 29 Jul 2010 Posts: 14 Location: North Vancouver
| Simulation code works, however when I download ... boom |
Posted: Thu Jul 29, 2010 10:08 am |
So here is some ultra simple code that reads four switches on the Analog DSP eval kit board...
all I am doing is reading the 4 pb switches and outputing a LCD message.
In the CCS sim, I can run the program push any button and the message apears, and stays until the next button is pressed.
However when I download the code into the chip the push button B3 code automatically comes up, like the button was being held down, yet its not.
int pressed=0;
int written_flag = 0;
SET_TRIS_B( GET_TRIS_B() | 0x1E );
if(!input(PUSH_BUTTON_2))
pressed = 2;
else if(!input(PUSH_BUTTON_3))
pressed= 3;
else if(!input(PUSH_BUTTON_4))
pressed= 4;
else if(!input(PUSH_BUTTON_5))
pressed= 5;
pressed = 0;
if(pressed == 0)
if( written_flag != 0)
//do nothing
written_flag = 0;
if(pressed == 2)
if( written_flag != 2)
printf(LCD_PUTC, "\fWhat are you ?");
written_flag = 2;
if(pressed == 3)
if( written_flag != 3)
printf(LCD_PUTC, "\i'M mELTiNg ?");
written_flag = 3;
if(pressed == 4)
if( written_flag != 4)
printf(LCD_PUTC, "\fOh Man... ?");
written_flag = 4;
if(pressed == 5)
if( written_flag != 5)
printf(LCD_PUTC, "\fYou bugs me..");
written_flag = 5;
Its not clean but its simple to follow.... |
jbmiller
Joined: 07 Oct 2006 Posts: 73 Location: Greensville,Ontario
Posted: Thu Jul 29, 2010 10:33 am |
Welcome to the 'real world', simulations are not REAL.
I can see (actually NOT see) areas of concern.
need more info...
like processor type..
version of PCM (PCH,PC???)
Port/pin assignments for the 'push_button_s' (defines ?)
Setup routines (disabling onboard peripherals that conflict with I/O pins)
Code for functions you created..
jes trying to help |
Posted: Thu Jul 29, 2010 10:57 am |
Post your #fuses. It's very common for a simulator to ignore the
effects of certain fuses that are critical in real hardware (LVP/NOLVP for
example).
And what is the "CCS simulator" ? I'm not aware that they have one.
There's MPLAB simulator. There's Proteus. And maybe some others.
Also, I don't see any debounce code for your pushbuttons. I suggest
that you use the 'button' code here. It does debouncing:
http://www.ccsinfo.com/forum/viewtopic.php?t=23837 |
link555
Posted: Thu Jul 29, 2010 2:32 pm |
Thanks guys!
here is the code with headers, I am using the CCS debug mode and it runs.
#include <33fj128gp706.h>
#device ICD=TRUE
#fuses HS,NOWDT,NOCOE,PR
#use delay(clock=12M)
#define GREEN_LED PIN_C14
#define YELLOW_LED PIN_G9
#define RED_LED PIN_C2
#define LCD_RS_PIN PIN_D1
#define LCD_RW_PIN PIN_D2
#define LCD_ENABLE_PIN PIN_D3
#define PUSH_BUTTON_2 PIN_B2
#define PUSH_BUTTON_3 PIN_B3
#define PUSH_BUTTON_4 PIN_B4
#define PUSH_BUTTON_5 PIN_B5
#include <lcd.c>
#define BOTTOM_POT_PORT sAN9
#define BOTTOM_POT_CHANNEL 9
#define TOP_POT_PORT sAN8
#define TOP_POT_CHANNEL 8
typedef enum{GREEN =0, YELLOW, RED}colors;
#include <protoalone.h>
#include <TLV320AIC23B.c>
#INCLUDE <stdlib.h>
int pressed=0;
pressed = 2;
pressed= 3;
pressed= 4;
pressed= 5;
pressed = 0;
if(pressed == 0)
//not done yet
written_flag = 0;
if(pressed == 2)
written_flag = 2;
if(pressed == 3)
written_flag = 3;
if(pressed == 4)
written_flag = 4;
if(pressed == 5)
written_flag = 5;
jbmiller
Posted: Thu Jul 29, 2010 3:59 pm |
I see that ICD=TRUE..so...
any chance that the ICD is clobbering you ? |
link555
Posted: Thu Jul 29, 2010 4:26 pm |
| I comment that out when I download to the chip, thanks! |
asmallri
Joined: 12 Aug 2004 Posts: 1666 Location: Perth, Australia
Posted: Thu Jul 29, 2010 7:16 pm |
If you are setting TRIS manually the you need to include
#use FAST_IO(B) _________________ Regards, Andrew
SherpaDoug
Posted: Fri Jul 30, 2010 5:43 am |
With the default IO setting, #USE_STANDARD_IO, the compiler takes care of the TRIS registers automatically and will ignore your SET_TRIS_B. If you really need to handle the TRIS differently then you need to use fast IO, #USE_FAST_IO for your SET_TRIS_B to have any effect.
Most applications stay with the default and let the compiler handle the TRIS itself. _________________ The search for better is endless. Instead simply find very good and get the job done. |
link555
Posted: Fri Jul 30, 2010 6:44 am |
Thanks so much guys, I will delete that set the tris bit line. But unfortunately this does not solve the original problem.
I finally broke out the multimeter- I know... should have done a while ago....
So that push button of the CCS eval board has a 4.7k resistor connected to 3.3VDC the other side is tied to digital common. All other push button show close to the 3.3V when not pushed, this on PB3, shows 0.47VDC. the resistor is connected and tested ok with the omhmeter. The push button tested ok too.
But my real question now is why would the debug mode work at all with push button?
FvM
Posted: Fri Jul 30, 2010 7:08 am |
| From the Analog DSP Dev Kit PCB layout, I don't see any pull-up resistors for the push-button inputs. (I don't have a schematic). In this case, you need to enable the internal dsPIC pull-up resistors. |
link555
Posted: Fri Jul 30, 2010 7:24 am |
| Sorry FvM just saw your post yes it has 4.7K pull up resistors to 3.3Vdc. |
Humberto
Posted: Fri Jul 30, 2010 9:33 am |
Did you check that the MCU is running? I mean, did you do a basic test: a Led attached to PIN_xx and watch if it
blink at the expected rate.
do
{ output_toggle(PIN_xx);
} while(1);
Also, be aware that all the pins that is shared with an analog input, after reset is configured as an analog input in
this device and in all that have 2 AD modules.
Humberto
link555
Posted: Fri Jul 30, 2010 10:01 am |
| Thanks yes the LCD works for PB2 and PB3 however anything after PB3 does not. I now believe the push button 3 hardware has a issue as the' not depressed' voltage is 0.47Vdc not 3.3Vdc |
FvM
Posted: Fri Jul 30, 2010 10:02 am |
| Quote: | | Did you check that the MCU is running? |
Well, a working LCD display suggests it's running, isnt it?
Are you sure, that the code not shown in your post (e.g. lcd.c) doesn't modify the settings of the push-button pins? Generally, I would trace the code execution with a debugger and check the state before the push-button test.
P.S.: I assume, you checked for conflicting hardware connections of PIN_B3 in the Dev-Kit schematic. |
Humberto
Posted: Fri Jul 30, 2010 10:34 am |
| Quote: |
NOP. He did not mention that the LCD is running in the real world, he mentioned an CCS sim that do
not exist, at least we are not updated that CCS released such development tool.
Humberto |
