FFT library
malik_123pk
FFT library
PostPosted: Sat Jul 24, 2010 6:01 am     Reply with quote
is there any FFT library for dspic 30F4013 .
bkamen
PostPosted: Sun Jul 25, 2010 8:02 am     Reply with quote
Yes.
Microchip's C30 does -- and is a free download with a 60-day (I think) Eval window with a "lite mode" thereafter that's free.
The docs mention how "some" of the library items are written in C which makes me think that most are ASM...
You can always (try) and convert the functions to CCS PCD, but I don't know what the effort required is. (probably not fun... but possibly easy for some items)
Cheers,
-Ben
malik_123pk
PostPosted: Mon Jul 26, 2010 12:47 am     Reply with quote
well it could have been easy if microchip had given the detail of C implementation , which i belive is not given .
and i think no asm code also exist , what can u do then to convert it in to CCS .
bkamen
PostPosted: Mon Jul 26, 2010 8:24 am     Reply with quote
I'd have to look deeper to see...
I know for C32 all the source is available..
But again - I only scratched the surface to see if anything DSP was available.
Good luck,
-Ben
malik_123pk
PostPosted: Tue Jul 27, 2010 5:08 am     Reply with quote
I have found the FFT asm which is this file.
(do not know how to upload file , so copying the whole file)
;                       Software License Agreement                   *
;   The software supplied herewith by Microchip Technology           *
;   Incorporated (the "Company") for its dsPIC controller            *
;   is intended and supplied to you, the Company's customer,         *
;   for use solely and exclusively on Microchip dsPIC                *
;   products. The software is owned by the Company and/or its        *
;   supplier, and is protected under applicable copyright laws. All  *
;   rights are reserved. Any use in violation of the foregoing       *
;   restrictions may subject the user to criminal sanctions under    *
;   applicable laws, as well as to civil liability for the breach of *
;   the terms and conditions of this license.                        *
;   THIS SOFTWARE IS PROVIDED IN AN "AS IS" CONDITION.  NO           *
;   WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING,    *
;   BUT NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND    *
;   FITNESS FOR A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE     *
;   COMPANY SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL,  *
;   INCIDENTAL OR CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.  *
;   (c) Copyright 2003 Microchip Technology, All rights reserved.    *
; This Complex DIF FFT implementation expects that the input data is a
; complex vector such that the magnitude of the real and imaginary parts
; of each of its elements is less than 0.5. If greater or equal to this
; value the results could produce saturation.
; Also, the program performs an implicit scaling of 1/2 for every stage
; to the intermediate values, so that the output values are scaled by a
; factor of 1/N, with N the length of the FFT.
; NOTE: input is expected in natural ordering, while output is produced
; in bit reverse ordering.
   ; Local inclusions.
   .nolist
   .include   "dspcommon.inc"      ; fractsetup,CORCON
                  ; PSVPAG, COEFFS_IN_DATA,
   .list
   .section .libdsp, code
; _FFTComplexIP: Complex (in-place) DIF FFT.
; Operation:
;   F(k) = 1/N*sum_n (f(n)*WN(kn)), WN(kn) = exp[-(j*2*pi*k*n)/N],
; n in {0, 1,... , N-1}, and
; k in {0, 1,... , N-1}, with N = 2^m.
; Input:
;   w0 = number stages in FFT (log2N)
;   w1 = ptr to complex source vector (srcCV)
;   w2 = ptr to complex twiddle factors (twidFactors)
;   w3 = COEFFS_IN_DATA, or memory program page with twiddle factors.
; Return:
;   w0 = ptr to source vector (srcCV)
; System resources usage:
;   {w0..w7}   used, not restored
;   {w8..w13}   saved, used, restored
;    AccuA      used, not restored
;    AccuB      used, not restored
;    CORCON      saved, used, restored
;    PSVPAG      saved, used, restored (if factors in P memory)
; DO and REPEAT instruction usage.
;   2 level DO intruction
;   no REPEAT intructions
; Program words (24-bit instructions):
;   60
; Cycles (including C-function call and return overheads):
;   transform   factors      factors
;      size      in X-mem   in P-mem
;    32-point      1664         1827
;    64-point      3802         4189
;   128-point      8612         9511
;   256-point     19310        21361
;   512-point     42872       47483
   ; Local equates.
   ; Commented to avoid IAR assembler problems...
;   .equ   oTwidd,w3
;   .equ   pTwidd,w8
;   .equ   nGrps,w9
;   .equ   pUpper,w10
;   .equ   pLower,w11
;   .equ   groupCntr,w12
;   .equ   buttCntr,w13
   ; The symbols have been replaced in the code by the corresponding
   ; working registers; the comments maintain the symbols for clarity.
   .global   _FFTComplexIP   ; export
_FFTComplexIP:
   ; Save working registers.
   push.d   w8            ; {w8,w9} to TOS
   push.d   w10            ; {w10,w11} to TOS
   push.d   w12            ; {w12,w13} to TOS
   ; Prepare CORCON for fractional computation.
   push   CORCON
   fractsetup   w7
   ; Prepare CORCON and PSVPAG for possible access of data
   ; located in program memory, using the PSV.
   push   PSVPAG
   mov   #COEFFS_IN_DATA,w7      ; w7 = COEFFS_IN_DATA
   cp   w7,w3            ; w7 - w3
   bra   z,_noPSV         ; if w3 = COEFFS_IN_DATA
                  ; no PSV management
                  ; else
   psvaccess   w7         ; enable PSV bit in CORCON
   mov   w3,PSVPAG         ; load PSVPAG with program
                  ; space page offset
_noPSV:
   push   w1            ; save return value (srcCV)
   ; FFT proper.
   mov   #0x1,w9            ; to be shifted...
   sl   w9,w0,w9         ; w9 = N (1<<log2N)
   mov   #0x1,w3            ; initialize twidds offset,
                  ; also used as num butterflies
   mov   w2,w8            ; w8-> WN(0) (real part)
   ; Preform all k stages, k = 1:log2N.
   ; NOTE: for first stage, 1 butterfly per twiddle factor (w3 = 1)
   ; and N/2 groups  (w9 = N/2) for factors WN(0), WN(1), ..., WN(N/2-1).
   mov   w0,w13            ; w13= num stages
                  ; w0 available for reuse
_doStage:
   ; Perform all butterflies in each stage, grouped per twiddle factor.
   ; Update counter for groups.
   lsr   w9,w9            ; w9 = N/(2^k)
   sl   w9,#2,w12         ; w12= lower offset
                  ; nGrps+sizeof(fractcomplex)
                  ; *2 bytes per element
   ; Set pointers to upper "leg" of butterfly:
   mov   w1,w10            ; w10-> srcCV (upper leg)
   ; Perform all the butterflies in each stage.
   dec   w3,w4            ; w4 = butterflies per group
   do   w4,_endBflies      ; {   ; do 2^(k-1) butterflies
   ; Set pointer to lower "leg" of butterfly.
   add   w12,w10,w11         ; w11-> srcCV + lower offset
                  ; (lower leg)
   ; Prepare offset for twiddle factors.
   sl   w3,#2,w0         ; oTwidd*sizeof(fractcomplex)
   ; Perform each group of butterflies, one for each twiddle factor.
   dec   w9,w4            ; w4 = nGrps-1
   do   w4,_endGroup      ; {   ; do (nGrps-1)+1 times
                  ; no more nested do's...
.ifdef YMEM_ERRATA
    nop
.endif
   ; Butterfly proper.
   clr   a,[w8]+=2,w6,[w10]+=2,w4   ; a  = 0 (for dual fetch only)
                  ; w6 = Wr
                  ; pTwidd-> Wi
                  ; w4 = Ar
                  ; pUpper-> Ai (=Ci)
   sub   w4,[w11++],w4         ; w4 = Ar - Br
                  ; pLower-> Bi (=Di)
   mpy   w4*w6,a,[w8]-=2,w7,[w10]-=2,w5   ; a  = (Ar - Br)*Wr
                  ; w7 = Wi
                  ; pTwidd-> Wr
                  ; w5 = Ai
                  ; pUpper-> Ar (=Cr)
   ; Update twiddle pointer.
   add   w0,w8,w8         ; pTwidd-> for next group
   mpy   w4*w7,b            ; b  = (Ar - Br)*Wi
   sub   w5,[w11--],w5         ; w5 = Ai - Bi
                  ; pLower-> Br (=Dr)
   msc   w5*w7,a,[w11]+=2,w7      ; a  = (Ar - Br)*Wr
                  ;    - (Ai - Bi)*Wi = Dr
                  ; w7 = Br
                  ; pLower-> Bi (=Di)
   mac   w5*w6,b,[w11]-=2,w5      ; b  = (Ar - Br)*Wi
                  ;    + (Ai - Bi)*Wr = Di
                  ; w5 = Bi
                  ; pLower-> Br (=Dr)
   sac.r   a,#1,[w11++]         ; save 1/2*Dr
                  ; pLower-> Bi (=Di)
   sac.r   b,#1,[w11++]         ; save 1/2*Di
                  ; pLower-> Br (next)
   lac   [w10++],a         ; a  = Ar
                  ; pUpper-> Ai (=Ci)
   lac   [w10--],b         ; b  = Ai
                  ; pUpper-> Cr
   add   w7,a            ; a  = Ar + Br
   add   w5,b            ; b  = Ai + Bi
   sac.r   a,#1,[w10++]         ; save 1/2*Cr
                  ; pUpper-> Ci
_endGroup:
   sac.r   b,#1,[w10++]         ; save 1/2*Ci
                  ; pUpper-> Ar (next)
   add   w12,w10,w10         ; w10-> upper leg (next set)
_endBflies:
   mov   w2,w8            ; rewind twiddle pointer
   ; Update offset to factors.
   sl   w3,w3            ; oTwidd *= 2
   ; Find out whether to perform another stage...
   dec   w13,w13            ; w13= log2N - k -1
   bra   gt,_doStage         ; if W13 > 0, do next stage
_endStages:               ; else, no more stages...
   pop   w0            ; restore return value
   ; Restore PSVPAG and CORCON.
   pop   PSVPAG
   pop   CORCON
   ; Restore working registers.
   pop.d   w12            ; {w12,w13} from TOS
   pop.d   w10            ; {w10,w11} from TOS
   pop.d   w8            ; {w8,w9} from TOS
   return
   .end
; OEF
I have to work hard if I have to put port it into CCS.
Implementing FIR filter on CCS was easy but it seems so difficult.
malik_123pk
PostPosted: Mon Aug 02, 2010 11:18 pm     Reply with quote
Can you guys imagine CCS provides the fft routine in it compiler.
I request the CCS administration to highlight this fact. I spent about three weeks in understating and implementing the FFT on MATLAB, I was all set to convert the algo into the Dspic assembly when I found accidentally that FFT function do exist for the CCS compiler.
How good it would have been if this was highlighted in the CCS already, under DSP section.
I request CCS administration that please add a separate DSP section in the content section of CCS HELP.
