Trying to find a chip similar to DS1631?
lecutus
PostPosted: Tue Jul 20, 2010 1:20 pm     Reply with quote
Trying to find a chip similar to DS1631? But I need for the recommended chip to accommodate temperatures up to 2000 degree F. I like the setup of the DS1631, software and otherwise.
I'm measuring temp at the exhaust manifold. I'm thinking about using K type thermal couples.
So my problem is to take the signal coming from the thermal couples, translating into temperature, then to some readable form, to be read/stored in a computer for display at later time.
thanks L.
PostPosted: Tue Jul 20, 2010 3:30 pm     Reply with quote
Microchip Temperature Sensor Design Guide:
http://ww1.microchip.com/downloads/en/AppNotes/21895d.pdf
bkamen
PostPosted: Tue Jul 20, 2010 8:31 pm     Reply with quote
Maxim has this neato IC,
http://www.maxim-ic.com/datasheet/index.mvp/id/3149
Too bad they don't have one that covers a larger range....
-Ben
