		| Author | Message |
		| pilar
				| The Bootloader AN1310 of Microchip work with CCS compiler? |
				|  Posted: Fri Jul 16, 2010 3:35 pm |   |
				| Hi, I want to know if some of you have been using the Bootloader AN1310 of Microchip with CCS compiler? |  |
		| pilar
				|  Posted: Fri Jul 16, 2010 5:13 pm |   |
				| Hi, I am use the bootloader AN1310 with CCS compiler, the firt time it work OK,  I can run the PC application and the Bootloader, also I can program the Pic with my application, it work OK,  but when I want to reenter the bootloader mode, I can not, the verification fails, then I lose the bootloader and communications with it fails. "No Bootloader found"
 I am using a PIC18F4550, the bootloader start in 0x00 and the remapped of my aplication starts in 0x800
 Some one can help me?
		| bkamen
				|  Posted: Fri Jul 16, 2010 9:47 pm |   |
				| The bootloader that comes with PIC-C works pretty well and is fairly easy to set up.
 Am I to understand you're using the microchip bootloader .HEX file and then trying to use the CCS SIOW to write a CCS .HEX application to the same PIC?
 -Ben
 Dazed and confused? I don't think so. Just "plain lost" will do.  :D
		| pilar
				|  Posted: Mon Jul 19, 2010 11:07 am |   |
				|  	  | Quote: |  	  | Am I to understand you're using the microchip bootloader .HEX file and then trying to use the CCS SIOW to write a CCS .HEX application to the same PIC?
 Here is a mistake, I'm not using the  CCS SIOW to program the Pic, I am use the MPLAB IDE and the CCS plug-in to to edit and build projects using the CCS C compiler.
		| bkamen
				|  Posted: Mon Jul 19, 2010 1:06 pm |   |
				|  	  | pilar wrote: |  	  | Here is a mistake, I'm not using the  CCS SIOW to program the Pic, I am use the MPLAB IDE and the CCS plug-in to to edit and build projects using the CCS C compiler.
 Well that's what I do... but what code-source are you using for the bootloader?
 If you're using SIOW with microchip source, I've not tested that...
 I've built the CCS bootloader using MPLAB w/CCS (as the plug-in) and used it with CCS's SIOW.
 -Ben
		| pilar
