18f4331 PWM Dead time
lokeshbhatt
PostPosted: Mon Jul 19, 2010 6:19 am     Reply with quote
In 18f4331 how to generate 3phase ac signal? Below is the program
but it is not showing dead time in between complementary output & now we know 3phase AC require 3 different waves so how can we get...
#include<18f4431.h>
//#device PIC18f4331*=8 ADC=8 ICD=TRUE
//#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#int_PWMTB
void PWMTB_isr()
    setup_power_pwm_pins(PWM_COMPLEMENTARY,PWM_COMPLEMENTARY,PWM_COMPLEMENTARY,PWM_OFF);
   set_power_pwm2_duty(100);
   set_power_pwm4_duty(100);
   clear_interrupt(int_PWMTB);
   ******   This Program to generate PWM outputs and what are all registers need to
   ******   be set for that are as follows.......
   1.
      Parameters :
   1. PTCON0 (Timer Control Reg)
      Parameters : freerunning, Prescaling 1:1, Postscaling 1:1
   2. PTCON1 (Timer Control Reg) 0xC0
      Parameters : Count Up,TimeBase ON
   3. PWMON0 (PWM ON )
      Parameters :PWM ON 0 & 1, Complementary
   4. PWMCON1 ()
      Parameters :
   5. PTPER (Time Period )
      Parameters :
   enable_interrupts(INT_PWMTB);
   set_power_pwm0_duty(PWM_UPDATE_ENABLE);
   set_power_pwm_override(1, true, 1);
    setup_power_pwm_pins(PWM_COMPLEMENTARY,PWM_OFF,PWM_OFF,PWM_OFF);
      //PPWM channels 0 and 1 are both on and always opposite values
   setup_power_pwm(PWM_CLOCK_DIV_4|PWM_FREE_RUN|PWM_DEAD_CLOCK_DIV_4,400,0,500,0,1,200);
      //add dead time for reactive loads
   set_power_pwm0_duty(400);
   set_power_pwm2_duty(400);
   set_power_pwm4_duty(400);
   while(TRUE);
Thanks & Regards
Lokesh Bhatt
