denis_11
| 2 pic 1 quartz |
Posted: Sun Jul 18, 2010 12:22 pm |
Hello I connect two 12f683 to a single crystal... I have to generate two different pw... say that it works?
Franck26
Posted: Sun Jul 18, 2010 12:49 pm |
I don't understand what you are trying to do, but it sound crazy!!!
You cannot connect your quartz to 2 micro as it's done on your schematic.
Good luck
Franck. |
Humberto
Posted: Sun Jul 18, 2010 1:38 pm |
Yes you can. Connecting OSC2 from the U1 to OSC1 of U2 as shown the schematic it is perfectly legal.
Be aware that if you are driving more than -let says- 2 or 3 PICs, you will need a CMOS or TTL driver/buffer
with a bigger fan out than OSC2.
You have to set Oscillator setup (#FUSES) accordingly in each PIC.
For U1
#FUSES XT, .........
For U2
#FUSES EC_IO, .......
#use delay(clock=8000000)
Humberto
denis_11
| Franck26 wrote: | Hi,
Good luck
Franck. |
But it's you who make me laugh... you can not answer on a forum if you are not sure of what you are writing....thanks PCM programmer and Humberto:) |
Franck26
Posted: Sun Jul 18, 2010 3:58 pm |
If I answer only when I'm 100% sure, I would never answer.
At least I made you laugh!!!
You can have a look at the post #12 of this link:
http://www.microchip.com/forums/m482855.aspx
I would add that the clock input pin of the second micro is going to add some capacitance to 1 side of the quartz, which can prevent the oscillation from starting.
This is not something that I would use for a professional circuit, except of course if there is a microchip AN on this topic (and maybe there is).
Franck. |
