neverlog
| Capacitor value for 18F4520's 40Mhz Crystal value |
Posted: Sat Jul 10, 2010 7:23 am |
Dear All,
Is the 18F4520 support 40Mhz?
if yes, what is the capacitor value for 40Mhz crystal?
Please help me. Thanks!
I am trying to search the datasheet, but it only give capacitor value for 25Mhz. |
bungee-
Posted: Sat Jul 10, 2010 7:49 am |
I usually put 12pF capacitors there. But It should be tested for yor application.
On other hand, you could use resonator or oscillator for more precision for your application. |
mkuang
Posted: Sat Jul 10, 2010 10:35 am |
| There were previous posts about how you will have stability issues using a 40Mhz crystal. A better option might be to use a 10Mhz and PLL it up to 40 Mhz. |
Posted: Sat Jul 10, 2010 12:08 pm |
| Quote: | Is the 18F4520 support 40Mhz?
Look in this section of the 18F4520 data sheet:
| Quote: | TABLE 26-6: EXTERNAL CLOCK TIMING REQUIREMENTS
It says the highest frequency for HS mode is 25 MHz. So you can't use
a 40 MHz crystal. You have to use 10 MHz and 4x PLL as explained in a
previous post.
You can use an external 40 MHz oscillator, but it's cheaper to use the
10 MHz crystal and PLL. |
neverlog
Posted: Mon Jul 12, 2010 7:56 pm |
| Thank you for all the reply and the advice! |
neverlog
Posted: Mon Jul 12, 2010 7:59 pm |
Can any one have any good reference for how to use 10 MHz and 4x PLL ?
Thanks in advance! |
neverlog
Posted: Mon Jul 12, 2010 10:25 pm |
Thanks for the help!! |
