one question about SHT71
tieungu13
View user's profile Send private message AIM Address ICQ Number
PostPosted: Thu Jul 08, 2010 11:26 am     Reply with quote
I used Sht71. Driver of sht71 I got on this website, and example I get on this website too. But I get value of Temp = -39.9 and hump = -4.6% all the time. Pin of sht71 PIN_1 (PC0 - clock), 2 (VCC pull 10K), 3 (Ground), 4 (Data and pull 10k -PIN C1). Like on datasheet of SHT7X. I see on the topic about SHT71 this website someone had a problem like me, but they haven't solved this problem. Help me. I'm from VietNam.
//////////////////////////////////////main C /////////////////////////
#include "C:\Users\Thanh Hai\Desktop\test71\main.h"
#fuses HS,NOWDT,PUT,NOPROTECT,NOLVP
#include <SHT71.c>
#include <lcd_lib_4bit.c>
float restemp, truehumid;
set_tris_c(0xff);
 sht_init();
  output_low(PIN_C0);///
 output_high(PIN_C1);
 restart_wdt();
sht_rd (restemp, truehumid);
 LCD_SetPosition(0);
 printf(LCD_putchar, "Temp : %3.1f C   ",restemp);
 LCD_SetPosition(40);
 printf(LCD_putchar, "\nRH   : %3.1f %%   ", truehumid);
 delay_ms(50);  //delay 500 ms between reading to prevent self heating of sensor
//////////////////////////////SHT71////////////////////////////////
// Driver file for SHT75 Temperature & Humidity Sensor                       //
// ***** To initialise SHT75 sensor upon power up *****                      //
// Function : sht_init()                                                     //
// Return   : none                                                           //
// ***** To measure and caluculate SHT75 temp & real RH *****                //
// Function : sht_rd (temp, truehumid)                                       //
// Return   : temperature & true humidity in float values                    //
#define sht_data_pin   PIN_C1
#define sht_clk_pin    PIN_C0
SHT71 Driver:
http://www.ccsinfo.com/forum/viewtopic.php?t=28564
asmallri
PostPosted: Mon Jul 12, 2010 1:09 am     Reply with quote
Sounds like you may have connected it up wrongly and then killed it. Been there, done that.
Regards, Andrew
