Why CCS generates large code
FFT
PostPosted: Wed Jul 07, 2010 3:19 pm     Reply with quote
I have a question that I could not find any answer.
I add the code part and its assembly output. How can I force CCS to compile smaller code? PIC is 12F675 and v4.107
#use delay(clock=4M,RESTART_WDT)
#byte gpio = getenv("SFR:GPIO")
#bit  STX  = gpio.5
#use fast_io(A)
int8  i;
int32 TheData=0xAA55;
   for(i=0;i<18;i++)
      if(bit_test(TheData,i))
         STX=1;
         STX=0;
      delay_us(100);
      STX=1;
      delay_us(50);
      STX=0;
      delay_us(50);
....................    for(i=0;i<18;i++)
01D2:  CLRF   2E
01D3:  MOVF   2E,W
01D4:  SUBLW  11
01D5:  BTFSS  03.0
01D6:  GOTO   203
....................       if(bit_test(TheData,i))
01D7:  MOVF   36,W
01D8:  MOVWF  23
01D9:  MOVF   35,W
01DA:  MOVWF  22
01DB:  MOVF   34,W
01DC:  MOVWF  21
01DD:  MOVF   33,W
01DE:  MOVWF  20
01DF:  MOVF   2E,W
01E0:  MOVWF  37
01E1:  BTFSC  03.2
01E2:  GOTO   1EA
01E3:  BCF    03.0
01E4:  RRF    23,F
01E5:  RRF    22,F
01E6:  RRF    21,F
01E7:  RRF    20,F
01E8:  DECFSZ 37,F
01E9:  GOTO   1E3
01EA:  BTFSS  20.0
01EB:  GOTO   1EE
....................          STX=1;
01EC:  BSF    05.5
....................       else
01ED:  GOTO   1EF
....................          STX=0;
01EE:  BCF    05.5
....................       delay_us(100);
01EF:  CLRWDT
01F0:  MOVLW  20
01F1:  MOVWF  20
01F2:  DECFSZ 20,F
01F3:  GOTO   1F2
01F4:  GOTO   1F5
01F5:  BSF    05.5
....................      delay_us(50);
01F6:  CLRWDT
01F7:  MOVLW  10
01F8:  MOVWF  20
01F9:  DECFSZ 20,F
01FA:  GOTO   1F9
01FB:  BCF    05.5
01FC:  CLRWDT
01FD:  MOVLW  10
01FE:  MOVWF  20
01FF:  DECFSZ 20,F
0200:  GOTO   1FF
0201:  INCF   2E,F
0202:  GOTO   1D3
bkamen
PostPosted: Wed Jul 07, 2010 3:23 pm     Reply with quote
HA! you should see the output of some other compilers...
That looks pretty decent although others might have some suggestions -- most likely you'll have to write your own assembly..
But that looks pretty good.
-Ben
rnielsen
PostPosted: Wed Jul 07, 2010 5:00 pm     Reply with quote
You need to remember that the device is an 8bit MCU and you are manipulating a 32bit variable. Just in the bit_test() routine, nine extra instructions are needed to manipulate this. Change it to an 8bit variable and you will get nine fewer instructions for that command.
Ronald
PostPosted: Wed Jul 07, 2010 5:42 pm     Reply with quote
Here is a version where you can keep the int32 and shave of 10 instructions:
   for(i=0;i<18;i++)
      STX = shift_right(&TheData, sizeof(TheData), 1);
      delay_us(100);
      STX=1;
      delay_us(50);
      STX=0;
      delay_us(50);
....................       STX = shift_right(&TheData, sizeof(TheData), 1);
004E:  BCF    PMDATH.5
004F:  BSF    STATUS.C
0050:  RRF    TheData+3,F
0051:  RRF    TheData+2,F
0052:  RRF    TheData+1,F
0053:  RRF    TheData,F
0054:  BTFSC  STATUS.C
0055:  BSF    PMDATH.5
It modifies the contents of TheData, but for many applications this is no problem.
And because you are only using 18 of the 32 bits, it can be reduced by 1 more instruction when you shift only 3 bytes (24 bits) instead of 4 bytes (32 bits).:
      STX = shift_right( ((int8*) &TheData) + 1, 3, 1);
FFT
PostPosted: Wed Jul 07, 2010 5:47 pm     Reply with quote
@rnielsen, yeah, I understand, but I have to have 18 bit data :(
@ckielstra,
But I'm sending first 18 bit of TheData and it's problem to be modified, right?
PostPosted: Wed Jul 07, 2010 5:58 pm     Reply with quote
From the small code fragment you have posted we can not see if this is a problem or not. It all depends on what you are doing with TheData variable after you have transmitted the contents. Most likely you are going to read new data from your sensor and then it doesn't matter.
