Help-ex_fat.
kideltn
Help-ex_fat.
PostPosted: Tue Jun 08, 2010 9:05 pm     Reply with quote
I simulated in Proteus but not with success.
I am trying this problem very much but have not solved it.
Here is my schematic Proteus:
Virtual sd card has formated FAT16
In main.c (I just modifed ex_fat.c in fuse to fit my simulation), fuses:
#include <18F6722.h>
#device PASS_STRINGS = IN_RAM
#fuses NOWDT, HS, NOPROTECT,NOMCLR,NODEBUG
#use delay(clock=10M)
#use rs232(baud=9600,parity=N,xmit=PIN_D0,rcv=PIN_D1,bits=8)
#include <stdlib.h> // for atoi32
#use fast_io(c)
#define MMCSD_PIN_SCL     PIN_C3 //o
#define MMCSD_PIN_SDI     PIN_C4 //i
#define MMCSD_PIN_SDO     PIN_C5 //o
#define MMCSD_PIN_SELECT  PIN_C2 //o
#include <mmcsd.c>
#include <fat.c>
In fat.c, I defined FAT16.
When I run simulation, TERMINAL (in Proteus) show: ERROR INITIALIZING FAT
Please help me solve it !
Thanks alot !
PostPosted: Tue Jun 08, 2010 9:14 pm     Reply with quote
The data lines (SDO and SDI) are connected incorrectly. You have them
swapped. Look at the schematic in this thread to see the correct way:
http://pic-c.ccsinfo.com/forum/viewtopic.php?p=76808
kideltn
PostPosted: Thu Jun 10, 2010 9:30 am     Reply with quote
Thank a lot !
But still not working.
Detail, when I swapped the pin, then run the simulation, the command
line appear (mean fat_init() success), however, when I type any
command to operate with Virtual SD card all fail.
Example: type "mkdir abc" on VirtualTerminal, the message appear:
"Making directory '/abc' :"(if success,words "OK" will show) and the
simulation stop working.
I spend alot time in reseaching but not ok. Please help me!
Thanks you very much !
My simulation:
http://www.mediafire.com/file/jutwwztmde4/CCSMassStorage.rar
PostPosted: Thu Jun 10, 2010 12:33 pm     Reply with quote
I don't have Proteus so I can't help any more on this.
kideltn
PostPosted: Thu Jun 10, 2010 12:54 pm     Reply with quote
Excuse!
Do you think with above code, when I make a real circuit it will work ?
Thanks alot !
asmallri
PostPosted: Thu Jun 10, 2010 5:42 pm     Reply with quote
kideltn wrote:
Excuse!
Thanks alot !
No. It will destroy the SD/MMC card. These cards run from 2.7 to 3.3 volts and the PIC you are using runs from +5V nominal. You need a regulator for the 3.3volt supply that is capable of delivering 100mA peak currents (very small duration) to the card and you need level conversion logic between the PIC and the card. You also need to put power supply filtering and power supply decoupling capacitors for the 3.3 volt supply as close to the SD socket as practical.
The design would be simpler if you used a 3.3 volt PIC but for most 18F series PIC this would imply you would not be running the PIC at maximum frequency. You could move to a PIC24 (3.3 volts).
You can find several reference designs on my site on the project page demonstrating ways of integrating these cards with +5V PICs.
Regards, Andrew
