peterl
18F2525 ADC problem |
Posted: Mon Jun 07, 2010 5:02 am |
Hi guys,
I am trying to do ADC with this microcontroller: 18F2525 and my code:
#include <18F2525.h>
#device adc=10
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#include "D:\.......\Fuel\main.h"
float adc_values;
setup_adc(ADC_CLOCK_DIV_4);
setup_adc_ports(AN0|VSS_VDD);
set_adc_channel(AN0);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
for(;;)
adc_values=read_adc();
printf("\f%3.0f",adc_values);
delay_ms(300);
The problem is that "adc value" is not correct. I use AN0 (PIN 2). When I change voltage on AN0, adc value not change and adc value stay ~30. When I touch with my finger other ANALOG PORTS the value rise up at >700~800, but when I power others ANALOG PORTS value is again ~30. I made everything what I know.
Sorry for my bad english.
Thanks |
Posted: Mon Jun 07, 2010 11:21 am |
Try a more simple program that will display ADC values from 0 to 1023
based on the input voltage. Also, make sure you have a ground
connection between the device that supplies the ADC input voltage and
the PIC board's ground. You can't just have the input signal wire to
pin A0. There must also be a ground wire between the two devices,
connected to the ground on each device (or board).
#device adc=10
#fuses INTRC_IO, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
int16 adc_value;
setup_adc_ports(AN0);
set_adc_channel(0);
delay_us(20);
adc_value = read_adc();
printf("%lu", adc_value);
peterl
re: PIC18F2525 ADC |
Posted: Tue Jun 08, 2010 1:12 am |
The problem was here:
set_adc_channel(AN0); is not correct, correct is set_adc_channel(0);
10X  |
