blackdragon
rs232 communication between two pic microcontroller |
Posted: Wed Jun 02, 2010 5:27 am |
Hi folks,
I want to make rf temperature with using rs232 communication. I've already tried some code pieces but I didn't succeed. Any idea or help would be more than welcome.
Btw, microcontroller model isn't important for me.
::::::::::::::::::::::::: Transceiver :::::::::::::::::::::::::::::::
// mikrodenetleyici baþlýk dosyasý
#include <18F4550.h>
// gerekli register ayarlarý
#FUSES NOPROTECT, NOPUT, NOWDT, NOBROWNOUT, NOLVP, NOCPD, NOWRT, NOMCLR, XT
// 10bitlik analog çýkýþ
#device ADC=10
// saat çarpan hýzý 4mHZ
// Seri iletiþim(USART) için gerekli ayarlar. Bu bildirim ile seri çýkýþ birimi seri porta
// yönlendirilmiþtir.
// Bant hýzý 9.6kbps, verici pini C6, alýcý pini C7, pariti biti yok, 8bitlik iletiþim
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, parity=N, bits=8)
// B portunu LCD için tahsis et
#define USE_PORTB_LCD TRUE
#include <lcd.c>
#include "ds18b20.c"
#include "mpx4115.c"
#define T_BUFFER_SIZE 64
byte t_buffer[T_BUFFER_SIZE];
byte t_next_in = 0;
byte t_next_out = 0;
#int_tbe
void serial_isr() {
if(t_next_in!=t_next_out)
putc(t_buffer[t_next_out]);
t_next_out=(t_next_out+1) % T_BUFFER_SIZE;
disable_interrupts(int_tbe);
void bputc(char c) {
short restart;
int ni;
restart=t_next_in==t_next_out;
t_buffer[t_next_in]=c;
ni=(t_next_in+1) % T_BUFFER_SIZE;
while(ni==t_next_out);
t_next_in=ni;
if(restart)
enable_interrupts(int_tbe);
float temperature, pressure; // global deðiþkenlerin tanýmlanmasý
setup_adc_ports(AN0); // PortA'nýn 0.pinini analog olarak ayarla
setup_adc(ADC_CLOCK_DIV_4); //
set_adc_channel(0);
do
temperature = ds1820_read(); // ýsý deðerini sensörden oku
pressure = mpx4115a_read(); // basýnç deðerini sensörden oku
delay_ms(2000);
printf(bputc,"%3.1fC\r\n",temperature);
while (TRUE)
::::::::::::::::::::::::: Receiver ::::::::::::::::::::::::::::
#device ADC=10
#include <lcd.c>
//char const msg_default[] = "Booting..";
//char str[20];
//char tmpStr[20];
//long strSize;
//int i;
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_rda
void serial_isr() {
int t;
buffer[next_in]=getc();
t=next_in;
if(next_in==next_out)
next_in=t; // Buffer full !!
BYTE bgetc() {
BYTE c;
while(!bkbhit) ;
c=buffer[next_out];
return(c);
lcd_init(); //lcd'yi çalýþtýr
printf(lcd_putc,"STARTING"); //lcd ekrana yazý yazdýr
printf(lcd_putc,"\f2010 SUMMER"); // lcd ekrana yazý yazdýr
lcd_gotoxy(1,1); // birinci satýr
printf(lcd_putc,"\f*************"); // lcd ekrana yazý yazdýr
lcd_gotoxy(2,1); //ikinci satýr
printf(lcd_putc,"\n**************");
enable_interrupts(INT_RDA);
enable_interrupts(global);
do {
printf("\r\nBuffered data => ");
while(bkbhit)
putc( bgetc() );
} while (TRUE);
Posted: Wed Jun 02, 2010 11:25 am |
Explain the serial port connections. Is one PIC connected to a PC,
at least for the transmitting ? Explain or post a diagram of the
Also, add the ERRORS parameter to the #use rs232() statement in
both programs. This will prevent a lockup of the UART receiver if one
PIC is receiving characters, but the code is not ready to accept them.
Quote: |
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS) |
blackdragon
Posted: Wed Jun 02, 2010 3:37 pm |
Hi PCM programmer,
I have two pic for communication each other. One of them receiver, other one transceiver. You can see my connection as below;
U1 is a transceiver pic, it captures two information from temp and pressure sensor and sends to RCV receiver pic via rs232 but I have some issue with communication and sources.
Thanks for your help. |
Posted: Wed Jun 02, 2010 4:57 pm |
Quote: | I've already tried some code pieces but I didn't succeed.
I have some issue with communication and sources. |
Explain your problem in detail. Tell the result that you want to get,
and tell the result that you are getting now. |
blackdragon
Posted: Thu Jun 03, 2010 6:25 am |
Hi again,
Actually I want to send couple of data (temperature and pressure) one pic microcontroller to other one with using rs232. I used code as above but I only see nothing.
I've seen lcd put messages, I think my rs232 communication doesnt work well. So if anyone give me any indication I would be more than welcome.
Thanks |
jbmiller
Joined: 07 Oct 2006 Posts: 73 Location: Greensville,Ontario
Posted: Thu Jun 03, 2010 7:27 am |
I'd add proper RS232 level translators(MAX232,etc.) to each PIC.
At least that way you could transmit data to a PC running a 'terminal' program to verify that PIC is running right.
Then you can send data from the PC to the 2nd PIC to verify that PIC is running right.
One step at a time,best to get each PIC running on it's own. |
