wael_007
| problem with returning to main program |
Posted: Sun May 30, 2010 12:10 pm |
Well I did this code but when I see that it stays in the function (affichage()) doing it from the first and don't return to main to continue.
#include <16F877.h>
#device adc=8
#include <math.h>
#include <string.h>
#include <lcd1.c>
#include<clavier16T.c>
#define Bouton1 PIN_C3 //declaration de bouton 1
#define BOUTON2 PIN_C4
#define use_portd_kbd;#endif
byte value ;
byte a ;
long int r;void affichage(int n)
char value1000;
char value100;
char value10;
char value1,v[10];
char position[10];
int k;int c;int *g;
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_timer_0(RTCC_INTERNAL|RT CC_DIV_1);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED,0,1) ;
port_b_pullups(true);
lcd_init();
kbd_init();
lcd_gotoxy(1,1);
lcd_putc("\fbienvenue ...\n");
lcd_putc("enterez positions");
delay_ms(2000);
start:;
printf(lcd_putc,"\fposition n:%d",n,'\n');
DO
value1000=kbd_getc();
} while(value1000==0 );
lcd_putc('\f');
lcd_gotoxy(1,1);
if (value1000=='*' || value1000=='+' || value1000=='-'||value1000=='c'||value1000== '/'||value1000=='='||value1000== '9'||value1000=='8') goto start;
lcd_putc(value1000);
do
value100=kbd_getc();
} while(value100==0);
lcd_gotoxy(2,1);
if (value100=='*' || value100=='+' || value100=='-'||value100=='c'||value100=='/'||value100=='=') goto start;
else lcd_putc(value100); do
value10=kbd_getc();
} while(value10==0);
lcd_gotoxy(3,1);
if (value10=='*' || value10=='+' || value10=='-'||value10=='c'||value10=='/'||value10=='=') goto start;
else lcd_putc(value10); do
value1=kbd_getc();
} while(value1==0);
lcd_gotoxy(4,1);
if (value1=='*' || value1=='+' || value1=='-'||value1=='c'||value1=='/'||value1=='=') goto start;
else lcd_putc(value1);
lcd_putc("enregistrer ou effacer");
do
{ k=kbd_getc();
}while(k==0);
if(k=='*')
{n=n+1;goto start;}
else if(k=='+') {goto start;}}
if(k=='-') lcd_putc('\f'); lcd_putc(n); while(true);
byte s,a,h;
int k;
long int r;
char v[10];
r=500;a=1; // initialisation de r et a
output_c(0xF8); // le port RC
set_tris_c(0xF8); // configuration do PORT C (1111 1000) ==> RC7,RC6,RC5,RC4,RC3:entrées RC2,RC1,RC0: sorties
setup_adc_ports(NO_ANALOGS); // configuration du convertisseur analogique numérique de PIC : il n ya aucune entrée analogique
setup_adc(ADC_OFF); // mettre en arret le convertisseur analogique numérique de PIC
setup_spi(FALSE); // mettre à l'arret l'interface de communication série du PIC
setup_timer_0(RTCC_INTERNAL|RT CC_DIV_1); // configuration de l'horloge interne du timer0 du PIC sur la fréquence RTCC_DIV_1 , c'est à dire 4MHZ divisé par 1
setup_timer_2(T2_DIV_BY_16, 127, 1); // configuration de l'horloge interne du timer2 du PIC : regarde la formule dans le help de picc
//initialisation du lcd
do {h=1;
affichage(h);
k=kbd_getc();}while(k==0);
if(k=='-')
lcd_putc("enter speed");
if (input(bouton1) ==0) { s=1; lcd_gotoxy(7,2);a=0; // si le bouton 1 est appuyé alors aller aux cordonnées (x=7,y=2), c'est à dire deuxiéme ligne, septiéme case de lcd
printf(lcd_putc,"sens avant");delay_ms(500);} // et afficher "sens avant"
if (input(bouton2) ==0) { s=0;lcd_gotoxy(7,2);a=0; // si le bouton 2 est appuyé alors aller aux cordonnées (x=7,y=2), c'est à dire deuxiéme ligne, septiéme case de lcd
printf(lcd_putc,"sens ariere");delay_ms(500);
Posted: Sun May 30, 2010 1:25 pm |
| Quote: | | I see that it stays in the function affichage() |
Yes, it's exactly written this way. If the code flow possibly overcomes all gotos and reaches the function's end, it's caught for ever by a while(true) statement. Unfortunately, I can't guess, what you are trying to achieve here. |
wael_007
Posted: Mon May 31, 2010 7:19 am |
Well I want to enter 4 numbers between 0 and 8000 by a 16*16 keypad and display them and save them in eeprom as binary numbers, and a not string in order to compare them after with other numbers.
My problem here is that I added a simple instruction in main just after the function (affichage()) but it doesn't work.
plizz help me |
Posted: Mon May 31, 2010 10:08 am |
| Code: | if (input(bouton2) ==0) { s=0;lcd_gotoxy(7,2);a=0; // si le bouton 2 est appuyé alors aller aux cordonnées (x=7,y=2), c'est à dire deuxiéme ligne, septiéme case de lcd
printf(lcd_putc,"sens ariere");delay_ms(500); | First thing to do is clean up your code layout. The fragment above is giving me headaches and is the worst example of 'how not to write code' I've ever seen.
A few guidelines are:
- Only one command on a line
- use indentation
- Split long comments over lines
Applying these to the code makes it look like: | Code: | if (input(bouton2) ==0)
s=0;
lcd_gotoxy(7,2);
// c'est à dire deuxiéme ligne, septiéme case de lcd
The code below is there two times, but slightly different:
| Code: | setup_psp(PSP_DISABLED);
setup_spi(FALSE);
| This is confusing and can lead to errors. Only initialize the hardware one time. Preferably at start of main() or in an init() function.
| Code: | | if(k=='-') lcd_putc('\f'); lcd_putc(n); while(true); | The 'while(true);' will cause problems as it will wait forever. Looks like a copy/paste error as this line is missing from the end of main().
| Code: | | #define use_portd_kbd;#endif | Where is the '#if' that belongs to the '#endif'? I assume it is in one of the #include files? This is wrong coding practice. Keep the #if and #endif close together.
| Code: | do
lcd_gotoxy(2,1);
if (value100=='*'
|| value100=='+'
|| value100=='-'
|| value100=='c'
|| value100=='/'
|| value100=='=')
goto start;
lcd_putc(value100);
| Four times the same sequence... A waste of memory and makes your program harder to read and maintain.
Create a function for this.
| Code: | | printf(lcd_putc,"\fposition n:%d",n,'\n'); | I haven't tried, maybe the CCS compiler accepts it, but standard C wants it as: | Code: | | printf(lcd_putc,"\fposition n:%d\n",n); |
And I'm sure there are more issues. |
wael_007
Posted: Tue Jun 01, 2010 10:57 am |
Thank you soooo much.
And so sorry if I wasted your time. I'm so happy to be in this forum. Congratulations and good continuation.
I'll try to correct my code and I'll post it. |
