		| View previous topic :: View next topic   |
			Ivan Guest
				| Functions not compiling |
				 Posted: Sun Oct 14, 2001 9:59 am     |
				Hello, I just received the pcm compiler for linux version 3.046. I am trying to get a program to compile with a function that is called. When I look at the .LST file, the only assembler instruction for the function is RETLW 00. I'm new to this compiler and haven't figured out what could be causing this. Below is my code. The function that doesn't work is shift_out(char a)
Ivan
#include <16c77.h>
#include <string.h>
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
#define WIRE1 PIN_E0
#define WIRE2 PIN_E1
#define WIRE3 PIN_E2
unsigned byte ptr;
char i;
byte ex_charge;
long timetag_lo;		/* 1200 Hz clock */
long timetag_hi;		/* 1 second clock */
long timetag_top;		/* upper half on 1 second clock */
char *adr;			/* address pointer */
char shift_reg;
char shift_out(char a) {
char ip;
char temp1;
	for(ip = 0; ip< 8;ip++) {
		output_low(PIN_D5);
		temp1 = (a >> ip) & 0x01;
		if(temp1 == 1) output_high(PIN_D6);
		else output_low(PIN_D6);
		output_high(PIN_D5);
	output_low(PIN_D5);
	output_high(PIN_D7);
	output_low(PIN_D7);
	return(0);
main()
/* Configure the ports */
#use fast_io(A)			/* set A port IO */
	set_tris_a(0x3f);
#use fast_io(B)			/* set B port IO */
	set_tris_b(0x3f);
#use fast_io(C)			/* set C port IO */
	set_tris_c(0x92);
#use fast_io(D)
	set_tris_d(0x0f);
#use fast_io(E)
	set_tris_e(0x07);
	output_low(PIN_E0);
	output_low(PIN_E1);
	output_low(PIN_E2);
	adr = 0x06;
	shift_reg = 0x46;
	shift_out(shift_reg);
	if(input(PIN_B5) == 1) ex_charge = 1;
	else ex_charge = 0;
/* set timer to interrupt at 1200 Hz */
	setup_timer_1(T1_INTERNAL | T1_DIV_BY_4);
	enable_interrupts(INT_TIMER1); /* enable timer1 interrupt */
	set_timer1(65336);
	ptr = 0;
	timetag_lo = 0;
	timetag_hi = 0;
	timetag_top = 0;
	shift_reg = shift_reg | 0x03;
	for(i=0;i<200;i++) {
		shift_reg = shift_reg ^ 1;
___________________________
	Original Post ID: 656 |
			Phil
				| Re: Functions not compiling |
				 Posted: Sun Oct 14, 2001 10:23 am     |
				Could you post your list file?
Thanks,
Phil
:=Hello, I just received the pcm compiler for linux version 3.046. I am trying to get a program to compile with a function that is called. When I look at the .LST file, the only assembler instruction for the function is RETLW 00. I'm new to this compiler and haven't figured out what could be causing this. Below is my code. The function that doesn't work is shift_out(char a)
:=Ivan
:=#include <16c77.h>
:=#include <string.h>
:=#use delay(clock=4000000)
:=#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
:=#define WIRE1 PIN_E0
:=#define WIRE2 PIN_E1
:=#define WIRE3 PIN_E2
:=unsigned byte ptr;
:=char i;
:=byte ex_charge;
:=long timetag_lo;		/* 1200 Hz clock */
:=long timetag_hi;		/* 1 second clock */
:=long timetag_top;		/* upper half on 1 second clock */
:=char *adr;			/* address pointer */
:=char shift_reg;
:=char shift_out(char a) {
:=char ip;
:=char temp1;
:=	for(ip = 0; ip< 8;ip++) {
:=		output_low(PIN_D5);
:=		temp1 = (a >> ip) & 0x01;
:=		if(temp1 == 1) output_high(PIN_D6);
:=		else output_low(PIN_D6);
:=		output_high(PIN_D5);
:=	output_high(PIN_D7);
:=	output_low(PIN_D7);
:=	return(0);
:=main()
:=/* Configure the ports */
:=#use fast_io(A)			/* set A port IO */
:=	set_tris_a(0x3f);
:=#use fast_io(B)			/* set B port IO */
:=	set_tris_b(0x3f);
:=#use fast_io(C)			/* set C port IO */
:=	set_tris_c(0x92);
:=#use fast_io(D)
:=	set_tris_d(0x0f);
:=#use fast_io(E)
:=	set_tris_e(0x07);
:=	output_low(PIN_E0);
:=	output_low(PIN_E1);
:=	output_low(PIN_E2);
:=	adr = 0x06;
:=	shift_reg = 0x46;
:=	shift_out(shift_reg);
:=	if(input(PIN_B5) == 1) ex_charge = 1;
:=	else ex_charge = 0;
:=/* set timer to interrupt at 1200 Hz */
:=	setup_timer_1(T1_INTERNAL | T1_DIV_BY_4);
:=	enable_interrupts(INT_TIMER1); /* enable timer1 interrupt */
:=	set_timer1(65336);
:=	ptr = 0;
:=	timetag_lo = 0;
:=	timetag_hi = 0;
:=	timetag_top = 0;
:=	shift_reg = shift_reg | 0x03;
:=	for(i=0;i<200;i++) {
:=		delay_ms(500);
:=		shift_reg = shift_reg ^ 1;
:=	while(1);
	Original Post ID: 657 |
			Ivan Guest
				 Posted: Sun Oct 14, 2001 10:42 am     |
				:=Could you post your list file?
:=Thanks,
:=Phil
Here is the list file.
Ivan
CCS PCW C Compiler, Version 3.046, 12830
               Filename: /usr/picc/cube7.LST
               ROM used: 20 (0\%)
                         Largest free fragment is 2048
               RAM used: 18 (10\%) at main() level
                         21 (12\%) worst case
               Stack:    1 locations
0000:  MOVLW  00
0001:  MOVWF  0A
0002:  GOTO   008
0003:  NOP
....................  #include <16c77.h>
....................  //////// Standard Header file for the PIC16C77 device ////////////////
.................... #device PIC16C77
.................... #list
.................... #include <string.h>
.................... ////        (C) Copyright 1996,1997 Custom Computer Services            ////
.................... //// This source code may only be used by licensed users of the CCS C   ////
.................... //// compiler.  This source code may only be distributed to other       ////
.................... //// licensed users of the CCS C compiler.  No other use, reproduction  ////
.................... //// or distribution is permitted without written permission.           ////
.................... //// Derivative programs created using this software in object code     ////
.................... //// form are not restricted in any way.                                ////
.................... #include <ctype.h>
.................... /* standard template: char *strcat(char *s1, const char *s2) */
.................... char strcat(char *s1, char *s2)
....................    char *s;
....................    for (s = s1; *s != '\0'; s++);
....................    while ((*s = *s2) != '\0')
....................        s++;
....................        s2++;
....................    return(s1);
.................... /* standard template: char *strchr(const char *s, int c).
....................    Finds first occurrence of c in s1 */
.................... char strchr(char *s, int c)
....................    for (; *s != c; s++)
....................       if (*s == '\0')
....................          return(0);
....................    return(s);
.................... /* standard template: char *strrchr(const char *s, int c).
....................    Finds last occurrence of c in s1 */
.................... char strrchr(char *s, int c)
....................    char *p;
....................    for (p = 0; ; s++)
....................       if (*s == c)
....................          p = s;
....................          return(p);
.................... /* standard template: int strcmp(const char *s1, const char *s2).
....................    Compares s1 & s2; returns -1 if s1<s2, 0 if s1=s2, 1 if s1>s2 */
.................... signed int strcmp(char *s1, char *s2)
....................    for (; *s1 == *s2; s1++, s2++)
....................       if (*s1 == '\0')
....................    return((*s1 < *s2) ? -1: 1);
....................    int strncmp(const char *s1, const char *s2, size_t n).
....................    Compares max of n characters (not following 0) from s1 to s2;
....................    returns same as strcmp */
.................... signed int strncmp(char *s1, char *s2, int n)
....................    for (; n > 0; s1++, s2++, n--)
....................       if (*s1 != *s2)
....................          return((*s1 <*s2) ? -1: 1);
....................       else if (*s1 == '\0')
.................... /* standard template: size_t stricmp(const char *s1, const char *s2).
....................    Compares s1 to s2 ignoring case (upper vs. lower) */
.................... signed int stricmp(char *s1, char *s2)
....................  for(; *s1==*s2||(isalpha(*s1)&&isalpha(*s2)&&(*s1==*s2+32||*s2==*s1+32));
....................     s1++, s2++)
.................... /* compiler ignored the name 'strcpy()'; perhaps, it's reserved?
....................    Standard template: char *strcpy(char *s1, const char *s2) */
.................... char strcopy(char *s1, char *s2)
....................   for (s = s1; *s2 != 0; s++, s2++)
.................... 	  *s = *s2;
....................    char *strncpy(char *s1, const char *s2, size_t n).
....................    Copies max of n characters (not following ending '\0')
....................    from s2 in s1; if s2 has less than n characters, appends 0 */
.................... char strncpy(char *s1, char *s2, int n)
....................   for (s = s1; n > 0 && *s2 != '\0'; n--)
....................      *s++ = *s2++;
....................   for (; n > 0; n--)
....................      *s++ = '\0';
....................    size_t strcspn(const char *s1, const char *s2).
....................    Computes length of max initial segment of s1 that
....................    consists entirely of characters NOT from s2*/
.................... int strcspn(char *s1, char *s2)
....................    char *sc1, *sc2;
....................    for (sc1 = s1; *sc1 != 0; sc1++)
....................       for (sc2 = s2; *sc2 != 0; sc2++)
....................          if (*sc1 == *sc2)
....................             return(sc1 - s1);
.................... /* computes length of max initial segment of s1 consisting
....................    entirely of characters from s2 */
.................... int strspn(char *s1, char *s2)
....................       for (sc2 = s2; ; sc2++)
.................... 	 if (*sc2 == '\0')
....................          else if (*sc1 == *sc2)
....................             break;
.................... /* standard template: size_t strlen(const char *s).
....................    Computes length of s1 (preceding terminating 0) */
.................... int strlen(char *s)
....................    char *sc;
....................    for (sc = s; *sc != 0; sc++);
....................    return(sc - s);
.................... /* standard template: char *strlwr(char *s).
....................    Replaces uppercase letters by lowercase;
....................    returns pointer to new string s */
.................... char strlwr(char *s)
....................    for (p = s; *p != '\0'; p++)
....................       if (*p >= 'A' && *p <='Z')
....................          *p += 'a' - 'A';
....................    char *strpbrk(const char *s1, const char *s2).
....................    Locates first occurence of any character from s2 in s1;
....................    returns s1 if s2 is empty string */
.................... char strpbrk(char *s1, char *s2)
....................             return(sc1);
....................    char *strstr(const char *s1, const char *s2);
....................    Locates first occurence of character sequence s2 in s1;
....................    returns 0 if s2 is empty string */
.................... char strstr(char *s1, char *s2)
....................    if (*s2 == 0)
....................    for (; s1 = strchr(s1, *s2); s1++)
....................       for (sc1 = s1, sc2 = s2; ; sc1++, sc2++)
....................          if (*sc2 == 0)
....................          else if (*sc1 != *sc2)
.................... /* standard template: char *strtok(char *s1, const char *s2).
....................    Finds next token in s1 delimited by a character from separator
....................    string s2 (which can be different from call to call).  First call
....................    starts at beginning of s1 searching for first character NOT
....................    contained in s2; returns 0 if none is found.
....................    If one is found, it is the start of first token (return value).
....................    Function then searches from there for a character contained in s2.
....................    If none is found, current token extends to end of s1, and subsequent
....................    searches for a token will return 0.  If one is found, it is
....................    overwritten by '\0', which terminates current token.  Function saves
....................    pointer to following character from which next search will start.
....................    Each subsequent call, with 0 as first argument, starts searching
....................    from saved pointer */
.................... char strtok(char *s1, char *s2)
....................    char *beg, *end;
....................    static char *save;
....................    beg = (s1)? s1: save;
....................    beg += strspn(beg, s2);
....................    if (*beg == '\0')
....................       *save = ' ';
....................    end = strpbrk(beg, s2);
....................    if (*end != '\0')
....................       *end = '\0';
....................       end++;
....................    save = end;
....................    return(beg);
.................... #use delay(clock=4000000)
0005:  BCF    0A.3
0006:  BCF    0A.4
0007:  GOTO   010 (RETURN)
.................... #use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
.................... #define WIRE1 PIN_E0
.................... #define WIRE2 PIN_E1
.................... #define WIRE3 PIN_E2
.................... unsigned byte ptr;
.................... char i;
.................... byte ex_charge;
.................... long timetag_lo;		/* 1200 Hz clock */
.................... long timetag_hi;		/* 1 second clock */
.................... long timetag_top;		/* upper half on 1 second clock */
.................... char *adr;			/* address pointer */
.................... char shift_reg;
.................... char shift_out(char a) {
.................... char ip;
.................... char temp1;
.................... 	for(ip = 0; ip< 8;ip++) {
.................... 		output_low(PIN_D5);
.................... 		temp1 = (a >> ip) & 0x01;
.................... 		if(temp1 == 1) output_high(PIN_D6);
.................... 		else output_low(PIN_D6);
.................... 		output_high(PIN_D5);
.................... 	output_high(PIN_D7);
.................... 	output_low(PIN_D7);
0004:  RETLW  00
.................... main()
.................... /* Configure the ports */
.................... #use fast_io(A)			/* set A port IO */
.................... 	set_tris_a(0x3f);
.................... #use fast_io(B)			/* set B port IO */
.................... 	set_tris_b(0x3f);
.................... #use fast_io(C)			/* set C port IO */
.................... 	set_tris_c(0x92);
.................... #use fast_io(D)
.................... 	set_tris_d(0x0f);
.................... #use fast_io(E)
.................... 	set_tris_e(0x07);
.................... 	output_low(PIN_E0);
.................... 	output_low(PIN_E1);
.................... 	output_low(PIN_E2);
.................... 	adr = 0x06;
.................... 	shift_reg = 0x46;
.................... 	shift_out(shift_reg);
0008:  MOVF   2B,W
0009:  MOVWF  2C
000A:  CALL   004
.................... 	if(input(PIN_B5) == 1) ex_charge = 1;
.................... 	else ex_charge = 0;
.................... /* set timer to interrupt at 1200 Hz */
.................... 	setup_timer_1(T1_INTERNAL | T1_DIV_BY_4);
.................... 	enable_interrupts(INT_TIMER1); /* enable timer1 interrupt */
.................... 	set_timer1(65336);
.................... 	ptr = 0;
.................... 	timetag_lo = 0;
.................... 	timetag_hi = 0;
.................... 	timetag_top = 0;
.................... 	shift_reg = shift_reg | 0x03;
000B:  MOVF   2B,W
000C:  MOVWF  2C
000D:  CALL   004
.................... 	for(i=0;i<200;i++) {
.................... 		delay_ms(500);
000E:  CLRF   2D
000F:  GOTO   005
.................... 		shift_reg = shift_reg ^ 1;
0010:  MOVF   2B,W
0011:  MOVWF  2C
0012:  CALL   004
.................... 	while(1);
0013:  SLEEP
	Original Post ID: 658 |
			Phil
				 Posted: Sun Oct 14, 2001 1:26 pm     |
				Well, I see that your line2 of your C file contains #include, but no file.  After removing this line, I compile your code using CCS v3.050 and receive the following list.  It seems to me like your compilation should work.  If installing the updated version doesn't work for you, you should contact CCS about this:
CCS PCW C Compiler, Version 3.050, 12733
               Filename: c:\temp\test.LST
               ROM used: 169 (2\%)
               RAM used: 17 (10\%) at main() level
                         20 (11\%) worst case
               Stack:    1 locations
0000:  MOVLW  00
0001:  MOVWF  0A
0002:  GOTO   051
0003:  NOP
.................... //#include
003A:  MOVLW  2C
003B:  MOVWF  04
003C:  MOVF   00,W
003D:  BTFSC  03.2
003E:  GOTO   04E
003F:  MOVLW  01
0040:  MOVWF  78
0041:  CLRF   77
0042:  DECFSZ 77,F
0043:  GOTO   042
0044:  DECFSZ 78,F
0045:  GOTO   041
0046:  MOVLW  4A
0047:  MOVWF  77
0048:  DECFSZ 77,F
0049:  GOTO   048
004A:  NOP
004B:  NOP
004C:  DECFSZ 00,F
004D:  GOTO   03F
004E:  BCF    0A.3
004F:  BCF    0A.4
0050:  GOTO   09E (RETURN)
0004:  CLRF   2C
0005:  MOVF   2C,W
0006:  SUBLW  07
0007:  BTFSS  03.0
0008:  GOTO   02B
0009:  BSF    03.5
000A:  BCF    08.5
000B:  BCF    03.5
000C:  BCF    08.5
000D:  MOVF   2B,W
000E:  MOVWF  77
000F:  MOVF   2C,W
0010:  MOVWF  78
0011:  BTFSC  03.2
0012:  GOTO   017
0013:  BCF    03.0
0014:  RRF    77,F
0015:  DECFSZ 78,F
0016:  GOTO   013
0017:  MOVF   77,W
0018:  ANDLW  01
0019:  MOVWF  2D
001A:  DECFSZ 2D,W
001B:  GOTO   021
001C:  BSF    03.5
001D:  BCF    08.6
001E:  BCF    03.5
001F:  BSF    08.6
0020:  GOTO   025
0021:  BSF    03.5
0022:  BCF    08.6
0023:  BCF    03.5
0024:  BCF    08.6
0025:  BSF    03.5
0026:  BCF    08.5
0027:  BCF    03.5
0028:  BSF    08.5
0029:  INCF   2C,F
002A:  GOTO   005
002B:  BSF    03.5
002C:  BCF    08.5
002D:  BCF    03.5
002E:  BCF    08.5
002F:  BSF    03.5
0030:  BCF    08.7
0031:  BCF    03.5
0032:  BSF    08.7
0033:  BSF    03.5
0034:  BCF    08.7
0035:  BCF    03.5
0036:  BCF    08.7
0037:  MOVLW  00
0038:  MOVWF  78
0039:  RETLW  00
0051:  CLRF   04
0052:  MOVLW  1F
0053:  ANDWF  03,F
0054:  MOVLW  9F
0055:  MOVWF  04
0056:  MOVLW  07
0057:  MOVWF  00
0058:  MOVLW  19
0059:  BSF    03.5
005A:  MOVWF  19
005B:  MOVLW  26
005C:  MOVWF  18
005D:  MOVLW  90
005E:  BCF    03.5
005F:  MOVWF  18
0060:  MOVLW  3F
0061:  TRIS   5
0062:  TRIS   6
0063:  MOVLW  92
0064:  TRIS   7
0065:  MOVLW  0F
0066:  TRIS   7
0067:  MOVLW  07
0068:  BSF    03.5
0069:  MOVWF  07
006A:  BCF    03.5
006B:  BCF    09.0
006C:  BCF    09.1
006D:  BCF    09.2
006E:  MOVLW  06
006F:  MOVWF  29
0070:  MOVLW  46
0071:  MOVWF  2A
0072:  MOVF   2A,W
0073:  MOVWF  2B
0074:  CALL   004
0075:  MOVLW  00
0076:  BTFSC  06.5
0077:  MOVLW  01
0078:  SUBLW  01
0079:  BTFSS  03.2
007A:  GOTO   07E
007B:  MOVLW  01
007C:  MOVWF  22
007D:  GOTO   07F
007E:  CLRF   22
007F:  MOVLW  A5
0080:  MOVWF  10
0081:  BSF    03.5
0082:  BSF    0C.0
0083:  MOVLW  FF
0084:  BCF    03.5
0085:  MOVWF  0F
0086:  MOVLW  38
0087:  MOVWF  0E
0088:  CLRF   20
0089:  CLRF   24
008A:  CLRF   23
008B:  CLRF   26
008C:  CLRF   25
008D:  CLRF   28
008E:  CLRF   27
008F:  MOVLW  03
0090:  IORWF  2A,F
0091:  MOVF   2A,W
0092:  MOVWF  2B
0093:  CALL   004
0094:  CLRF   21
0095:  MOVF   21,W
0096:  SUBLW  C7
0097:  BTFSS  03.0
0098:  GOTO   0A7
0099:  MOVLW  02
009A:  MOVWF  2B
009B:  MOVLW  FA
009C:  MOVWF  2C
009D:  GOTO   03A
009E:  DECFSZ 2B,F
009F:  GOTO   09B
00A0:  MOVLW  01
00A1:  XORWF  2A,F
00A2:  MOVF   2A,W
00A3:  MOVWF  2B
00A4:  CALL   004
00A5:  INCF   21,F
00A6:  GOTO   095
00A7:  GOTO   0A7
00A8:  SLEEP
:=:=Could you post your list file?
:=:=Thanks,
:=:=Phil
:=Here is the list file.
:=Ivan
:=CCS PCW C Compiler, Version 3.046, 12830
:=               Filename: /usr/picc/cube7.LST
:=               ROM used: 20 (0\%)
:=                         Largest free fragment is 2048
:=               RAM used: 18 (10\%) at main() level
:=                         21 (12\%) worst case
:=               Stack:    1 locations
:=0000:  MOVLW  00
:=0001:  MOVWF  0A
:=0002:  GOTO   008
:=0003:  NOP
:=....................  #include <16c77.h>
:=....................  //////// Standard Header file for the PIC16C77 device ////////////////
:=.................... #device PIC16C77
:=.................... #list
:=.................... #include <string.h>
:=.................... ////        (C) Copyright 1996,1997 Custom Computer Services            ////
:=.................... //// This source code may only be used by licensed users of the CCS C   ////
:=.................... //// compiler.  This source code may only be distributed to other       ////
:=.................... //// licensed users of the CCS C compiler.  No other use, reproduction  ////
:=.................... //// or distribution is permitted without written permission.           ////
:=.................... //// Derivative programs created using this software in object code     ////
:=.................... //// form are not restricted in any way.                                ////
:=.................... #include <ctype.h>
:=.................... /* standard template: char *strcat(char *s1, const char *s2) */
:=.................... char strcat(char *s1, char *s2)
:=....................    char *s;
:=....................    for (s = s1; *s != '\0'; s++);
:=....................    while ((*s = *s2) != '\0')
:=....................        s++;
:=....................        s2++;
:=....................    return(s1);
:=.................... /* standard template: char *strchr(const char *s, int c).
:=....................    Finds first occurrence of c in s1 */
:=.................... char strchr(char *s, int c)
:=....................    for (; *s != c; s++)
:=....................       if (*s == '\0')
:=....................          return(0);
:=....................    return(s);
:=.................... /* standard template: char *strrchr(const char *s, int c).
:=....................    Finds last occurrence of c in s1 */
:=.................... char strrchr(char *s, int c)
:=....................    char *p;
:=....................    for (p = 0; ; s++)
:=....................       if (*s == c)
:=....................          p = s;
:=....................          return(p);
:=.................... /* standard template: int strcmp(const char *s1, const char *s2).
:=....................    Compares s1 & s2; returns -1 if s1<s2, 0 if s1=s2, 1 if s1>s2 */
:=.................... signed int strcmp(char *s1, char *s2)
:=....................    for (; *s1 == *s2; s1++, s2++)
:=....................       if (*s1 == '\0')
:=....................    return((*s1 < *s2) ? -1: 1);
:=....................    int strncmp(const char *s1, const char *s2, size_t n).
:=....................    Compares max of n characters (not following 0) from s1 to s2;
:=....................    returns same as strcmp */
:=.................... signed int strncmp(char *s1, char *s2, int n)
:=....................    for (; n > 0; s1++, s2++, n--)
:=....................       if (*s1 != *s2)
:=....................          return((*s1 <*s2) ? -1: 1);
:=....................       else if (*s1 == '\0')
:=.................... /* standard template: size_t stricmp(const char *s1, const char *s2).
:=....................    Compares s1 to s2 ignoring case (upper vs. lower) */
:=.................... signed int stricmp(char *s1, char *s2)
:=....................  for(; *s1==*s2||(isalpha(*s1)&&isalpha(*s2)&&(*s1==*s2+32||*s2==*s1+32));
:=....................     s1++, s2++)
:=.................... /* compiler ignored the name 'strcpy()'; perhaps, it's reserved?
:=....................    Standard template: char *strcpy(char *s1, const char *s2) */
:=.................... char strcopy(char *s1, char *s2)
:=....................   for (s = s1; *s2 != 0; s++, s2++)
:=.................... 	  *s = *s2;
:=....................    char *strncpy(char *s1, const char *s2, size_t n).
:=....................    Copies max of n characters (not following ending '\0')
:=....................    from s2 in s1; if s2 has less than n characters, appends 0 */
:=.................... char strncpy(char *s1, char *s2, int n)
:=....................   for (s = s1; n > 0 && *s2 != '\0'; n--)
:=....................      *s++ = *s2++;
:=....................   for (; n > 0; n--)
:=....................      *s++ = '\0';
:=....................    size_t strcspn(const char *s1, const char *s2).
:=....................    Computes length of max initial segment of s1 that
:=....................    consists entirely of characters NOT from s2*/
:=.................... int strcspn(char *s1, char *s2)
:=....................    char *sc1, *sc2;
:=....................    for (sc1 = s1; *sc1 != 0; sc1++)
:=....................       for (sc2 = s2; *sc2 != 0; sc2++)
:=....................          if (*sc1 == *sc2)
:=....................             return(sc1 - s1);
:=.................... /* computes length of max initial segment of s1 consisting
:=....................    entirely of characters from s2 */
:=.................... int strspn(char *s1, char *s2)
:=....................       for (sc2 = s2; ; sc2++)
:=.................... 	 if (*sc2 == '\0')
:=....................          else if (*sc1 == *sc2)
:=....................             break;
:=.................... /* standard template: size_t strlen(const char *s).
:=....................    Computes length of s1 (preceding terminating 0) */
:=.................... int strlen(char *s)
:=....................    char *sc;
:=....................    for (sc = s; *sc != 0; sc++);
:=....................    return(sc - s);
:=.................... /* standard template: char *strlwr(char *s).
:=....................    Replaces uppercase letters by lowercase;
:=....................    returns pointer to new string s */
:=.................... char strlwr(char *s)
:=....................    for (p = s; *p != '\0'; p++)
:=....................       if (*p >= 'A' && *p <='Z')
:=....................          *p += 'a' - 'A';
:=....................    char *strpbrk(const char *s1, const char *s2).
:=....................    Locates first occurence of any character from s2 in s1;
:=....................    returns s1 if s2 is empty string */
:=.................... char strpbrk(char *s1, char *s2)
:=....................             return(sc1);
:=....................    char *strstr(const char *s1, const char *s2);
:=....................    Locates first occurence of character sequence s2 in s1;
:=....................    returns 0 if s2 is empty string */
:=.................... char strstr(char *s1, char *s2)
:=....................    if (*s2 == 0)
:=....................    for (; s1 = strchr(s1, *s2); s1++)
:=....................       for (sc1 = s1, sc2 = s2; ; sc1++, sc2++)
:=....................          if (*sc2 == 0)
:=....................          else if (*sc1 != *sc2)
:=.................... /* standard template: char *strtok(char *s1, const char *s2).
:=....................    Finds next token in s1 delimited by a character from separator
:=....................    string s2 (which can be different from call to call).  First call
:=....................    starts at beginning of s1 searching for first character NOT
:=....................    contained in s2; returns 0 if none is found.
:=....................    If one is found, it is the start of first token (return value).
:=....................    Function then searches from there for a character contained in s2.
:=....................    If none is found, current token extends to end of s1, and subsequent
:=....................    searches for a token will return 0.  If one is found, it is
:=....................    overwritten by '\0', which terminates current token.  Function saves
:=....................    pointer to following character from which next search will start.
:=....................    Each subsequent call, with 0 as first argument, starts searching
:=....................    from saved pointer */
:=.................... char strtok(char *s1, char *s2)
:=....................    char *beg, *end;
:=....................    static char *save;
:=....................    beg = (s1)? s1: save;
:=....................    beg += strspn(beg, s2);
:=....................    if (*beg == '\0')
:=....................       *save = ' ';
:=....................    end = strpbrk(beg, s2);
:=....................    if (*end != '\0')
:=....................       *end = '\0';
:=....................       end++;
:=....................    save = end;
:=....................    return(beg);
:=.................... #use delay(clock=4000000)
:=0005:  BCF    0A.3
:=0006:  BCF    0A.4
:=0007:  GOTO   010 (RETURN)
:=.................... #use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
:=.................... #define WIRE1 PIN_E0
:=.................... #define WIRE2 PIN_E1
:=.................... #define WIRE3 PIN_E2
:=.................... unsigned byte ptr;
:=.................... char i;
:=.................... byte ex_charge;
:=.................... long timetag_lo;		/* 1200 Hz clock */
:=.................... long timetag_hi;		/* 1 second clock */
:=.................... long timetag_top;		/* upper half on 1 second clock */
:=.................... char *adr;			/* address pointer */
:=.................... char shift_reg;
:=.................... char shift_out(char a) {
:=.................... char ip;
:=.................... char temp1;
:=.................... 	for(ip = 0; ip< 8;ip++) {
:=.................... 		output_low(PIN_D5);
:=.................... 		temp1 = (a >> ip) & 0x01;
:=.................... 		if(temp1 == 1) output_high(PIN_D6);
:=.................... 		else output_low(PIN_D6);
:=.................... 		output_high(PIN_D5);
:=.................... 	output_high(PIN_D7);
:=.................... 	output_low(PIN_D7);
:=0004:  RETLW  00
:=.................... main()
:=.................... /* Configure the ports */
:=.................... #use fast_io(A)			/* set A port IO */
:=.................... 	set_tris_a(0x3f);
:=.................... #use fast_io(B)			/* set B port IO */
:=.................... 	set_tris_b(0x3f);
:=.................... #use fast_io(C)			/* set C port IO */
:=.................... 	set_tris_c(0x92);
:=.................... #use fast_io(D)
:=.................... 	set_tris_d(0x0f);
:=.................... #use fast_io(E)
:=.................... 	set_tris_e(0x07);
:=.................... 	output_low(PIN_E0);
:=.................... 	output_low(PIN_E1);
:=.................... 	output_low(PIN_E2);
:=.................... 	adr = 0x06;
:=.................... 	shift_reg = 0x46;
:=.................... 	shift_out(shift_reg);
:=0008:  MOVF   2B,W
:=0009:  MOVWF  2C
:=000A:  CALL   004
:=.................... 	if(input(PIN_B5) == 1) ex_charge = 1;
:=.................... 	else ex_charge = 0;
:=.................... /* set timer to interrupt at 1200 Hz */
:=.................... 	setup_timer_1(T1_INTERNAL | T1_DIV_BY_4);
:=.................... 	enable_interrupts(INT_TIMER1); /* enable timer1 interrupt */
:=.................... 	set_timer1(65336);
:=.................... 	ptr = 0;
:=.................... 	timetag_lo = 0;
:=.................... 	timetag_hi = 0;
:=.................... 	timetag_top = 0;
:=.................... 	shift_reg = shift_reg | 0x03;
:=000B:  MOVF   2B,W
:=000C:  MOVWF  2C
:=000D:  CALL   004
:=.................... 	for(i=0;i<200;i++) {
:=.................... 		delay_ms(500);
:=000E:  CLRF   2D
:=000F:  GOTO   005
:=.................... 		shift_reg = shift_reg ^ 1;
:=0010:  MOVF   2B,W
:=0011:  MOVWF  2C
:=0012:  CALL   004
:=.................... 	while(1);
:=0013:  SLEEP
	Original Post ID: 659 |
			Phil
				| Re:Also note the following bug |
				 Posted: Sun Oct 14, 2001 1:32 pm     |
				<font face="Courier New" size=-1>Also note 3.050 contains a bug resulting in the following:
0063: MOVLW 92
0064: TRIS 7
0065: MOVLW 0F
0066: TRIS 7
As you see tris_d (and tris_e) point to the incorrect register.
Phil
:=Well, I see that your line2 of your C file contains #include, but no file.  After removing this line, I compile your code using CCS v3.050 and receive the following list.  It seems to me like your compilation should work.  If installing the updated version doesn't work for you, you should contact CCS about this:
:=CCS PCW C Compiler, Version 3.050, 12733
:=               Filename: c:\temp\test.LST
:=               ROM used: 169 (2\%)
:=               RAM used: 17 (10\%) at main() level
:=                         20 (11\%) worst case
:=0000:  MOVLW  00
:=0001:  MOVWF  0A
:=0002:  GOTO   051
:=0003:  NOP
:=.................... //#include
:=003A:  MOVLW  2C
:=003B:  MOVWF  04
:=003C:  MOVF   00,W
:=003D:  BTFSC  03.2
:=003E:  GOTO   04E
:=003F:  MOVLW  01
:=0040:  MOVWF  78
:=0041:  CLRF   77
:=0042:  DECFSZ 77,F
:=0043:  GOTO   042
:=0044:  DECFSZ 78,F
:=0045:  GOTO   041
:=0046:  MOVLW  4A
:=0047:  MOVWF  77
:=0048:  DECFSZ 77,F
:=0049:  GOTO   048
:=004A:  NOP
:=004B:  NOP
:=004C:  DECFSZ 00,F
:=004D:  GOTO   03F
:=004E:  BCF    0A.3
:=004F:  BCF    0A.4
:=0050:  GOTO   09E (RETURN)
:=0004:  CLRF   2C
:=0005:  MOVF   2C,W
:=0006:  SUBLW  07
:=0007:  BTFSS  03.0
:=0008:  GOTO   02B
:=0009:  BSF    03.5
:=000A:  BCF    08.5
:=000B:  BCF    03.5
:=000C:  BCF    08.5
:=000D:  MOVF   2B,W
:=000E:  MOVWF  77
:=000F:  MOVF   2C,W
:=0010:  MOVWF  78
:=0011:  BTFSC  03.2
:=0012:  GOTO   017
:=0013:  BCF    03.0
:=0014:  RRF    77,F
:=0015:  DECFSZ 78,F
:=0016:  GOTO   013
:=0017:  MOVF   77,W
:=0018:  ANDLW  01
:=0019:  MOVWF  2D
:=001A:  DECFSZ 2D,W
:=001B:  GOTO   021
:=001C:  BSF    03.5
:=001D:  BCF    08.6
:=001E:  BCF    03.5
:=001F:  BSF    08.6
:=0020:  GOTO   025
:=0021:  BSF    03.5
:=0022:  BCF    08.6
:=0023:  BCF    03.5
:=0024:  BCF    08.6
:=0025:  BSF    03.5
:=0026:  BCF    08.5
:=0027:  BCF    03.5
:=0028:  BSF    08.5
:=0029:  INCF   2C,F
:=002A:  GOTO   005
:=002B:  BSF    03.5
:=002C:  BCF    08.5
:=002D:  BCF    03.5
:=002E:  BCF    08.5
:=002F:  BSF    03.5
:=0030:  BCF    08.7
:=0031:  BCF    03.5
:=0032:  BSF    08.7
:=0033:  BSF    03.5
:=0034:  BCF    08.7
:=0035:  BCF    03.5
:=0036:  BCF    08.7
:=0037:  MOVLW  00
:=0038:  MOVWF  78
:=0039:  RETLW  00
:=0051:  CLRF   04
:=0052:  MOVLW  1F
:=0053:  ANDWF  03,F
:=0054:  MOVLW  9F
:=0055:  MOVWF  04
:=0056:  MOVLW  07
:=0057:  MOVWF  00
:=0058:  MOVLW  19
:=0059:  BSF    03.5
:=005A:  MOVWF  19
:=005B:  MOVLW  26
:=005C:  MOVWF  18
:=005D:  MOVLW  90
:=005E:  BCF    03.5
:=005F:  MOVWF  18
:=0060:  MOVLW  3F
:=0061:  TRIS   5
:=0062:  TRIS   6
:=0063:  MOVLW  92
:=0064:  TRIS   7
:=0065:  MOVLW  0F
:=0066:  TRIS   7
:=0067:  MOVLW  07
:=0068:  BSF    03.5
:=0069:  MOVWF  07
:=006A:  BCF    03.5
:=006B:  BCF    09.0
:=006C:  BCF    09.1
:=006D:  BCF    09.2
:=006E:  MOVLW  06
:=006F:  MOVWF  29
:=0070:  MOVLW  46
:=0071:  MOVWF  2A
:=0072:  MOVF   2A,W
:=0073:  MOVWF  2B
:=0074:  CALL   004
:=0075:  MOVLW  00
:=0076:  BTFSC  06.5
:=0077:  MOVLW  01
:=0078:  SUBLW  01
:=0079:  BTFSS  03.2
:=007A:  GOTO   07E
:=007B:  MOVLW  01
:=007C:  MOVWF  22
:=007D:  GOTO   07F
:=007E:  CLRF   22
:=007F:  MOVLW  A5
:=0080:  MOVWF  10
:=0081:  BSF    03.5
:=0082:  BSF    0C.0
:=0083:  MOVLW  FF
:=0084:  BCF    03.5
:=0085:  MOVWF  0F
:=0086:  MOVLW  38
:=0087:  MOVWF  0E
:=0088:  CLRF   20
:=0089:  CLRF   24
:=008A:  CLRF   23
:=008B:  CLRF   26
:=008C:  CLRF   25
:=008D:  CLRF   28
:=008E:  CLRF   27
:=008F:  MOVLW  03
:=0090:  IORWF  2A,F
:=0091:  MOVF   2A,W
:=0092:  MOVWF  2B
:=0093:  CALL   004
:=0094:  CLRF   21
:=0095:  MOVF   21,W
:=0096:  SUBLW  C7
:=0097:  BTFSS  03.0
:=0098:  GOTO   0A7
:=0099:  MOVLW  02
:=009A:  MOVWF  2B
:=009B:  MOVLW  FA
:=009C:  MOVWF  2C
:=009D:  GOTO   03A
:=009E:  DECFSZ 2B,F
:=009F:  GOTO   09B
:=00A0:  MOVLW  01
:=00A1:  XORWF  2A,F
:=00A2:  MOVF   2A,W
:=00A3:  MOVWF  2B
:=00A4:  CALL   004
:=00A5:  INCF   21,F
:=00A6:  GOTO   095
:=00A7:  GOTO   0A7
:=00A8:  SLEEP
:=:=:=Could you post your list file?
:=:=:=Thanks,
:=:=:=Phil
:=:=Here is the list file.
:=:=Ivan
:=:=CCS PCW C Compiler, Version 3.046, 12830
:=:=               Filename: /usr/picc/cube7.LST
:=:=               ROM used: 20 (0\%)
:=:=                         Largest free fragment is 2048
:=:=               RAM used: 18 (10\%) at main() level
:=:=                         21 (12\%) worst case
:=:=               Stack:    1 locations
:=:=0000:  MOVLW  00
:=:=0001:  MOVWF  0A
:=:=0002:  GOTO   008
:=:=0003:  NOP
:=:=....................  #include <16c77.h>
:=:=....................  //////// Standard Header file for the PIC16C77 device ////////////////
:=:=.................... #device PIC16C77
:=:=.................... #list
:=:=.................... #include <string.h>
:=:=.................... ////        (C) Copyright 1996,1997 Custom Computer Services            ////
:=:=.................... //// This source code may only be used by licensed users of the CCS C   ////
:=:=.................... //// compiler.  This source code may only be distributed to other       ////
:=:=.................... //// licensed users of the CCS C compiler.  No other use, reproduction  ////
:=:=.................... //// or distribution is permitted without written permission.           ////
:=:=.................... //// Derivative programs created using this software in object code     ////
:=:=.................... //// form are not restricted in any way.                                ////
:=:=.................... #include <ctype.h>
:=:=.................... /* standard template: char *strcat(char *s1, const char *s2) */
:=:=.................... char strcat(char *s1, char *s2)
:=:=....................    char *s;
:=:=....................    for (s = s1; *s != '\0'; s++);
:=:=....................    while ((*s = *s2) != '\0')
:=:=....................        s++;
:=:=....................        s2++;
:=:=....................    return(s1);
:=:=.................... /* standard template: char *strchr(const char *s, int c).
:=:=....................    Finds first occurrence of c in s1 */
:=:=.................... char strchr(char *s, int c)
:=:=....................    for (; *s != c; s++)
:=:=....................       if (*s == '\0')
:=:=....................          return(0);
:=:=....................    return(s);
:=:=.................... /* standard template: char *strrchr(const char *s, int c).
:=:=....................    Finds last occurrence of c in s1 */
:=:=.................... char strrchr(char *s, int c)
:=:=....................    char *p;
:=:=....................    for (p = 0; ; s++)
:=:=....................       if (*s == c)
:=:=....................          p = s;
:=:=....................          return(p);
:=:=.................... /* standard template: int strcmp(const char *s1, const char *s2).
:=:=....................    Compares s1 & s2; returns -1 if s1<s2, 0 if s1=s2, 1 if s1>s2 */
:=:=.................... signed int strcmp(char *s1, char *s2)
:=:=....................    for (; *s1 == *s2; s1++, s2++)
:=:=....................       if (*s1 == '\0')
:=:=....................    return((*s1 < *s2) ? -1: 1);
:=:=....................    int strncmp(const char *s1, const char *s2, size_t n).
:=:=....................    Compares max of n characters (not following 0) from s1 to s2;
:=:=....................    returns same as strcmp */
:=:=.................... signed int strncmp(char *s1, char *s2, int n)
:=:=....................    for (; n > 0; s1++, s2++, n--)
:=:=....................       if (*s1 != *s2)
:=:=....................          return((*s1 <*s2) ? -1: 1);
:=:=....................       else if (*s1 == '\0')
:=:=.................... /* standard template: size_t stricmp(const char *s1, const char *s2).
:=:=....................    Compares s1 to s2 ignoring case (upper vs. lower) */
:=:=.................... signed int stricmp(char *s1, char *s2)
:=:=....................  for(; *s1==*s2||(isalpha(*s1)&&isalpha(*s2)&&(*s1==*s2+32||*s2==*s1+32));
:=:=....................     s1++, s2++)
:=:=.................... /* compiler ignored the name 'strcpy()'; perhaps, it's reserved?
:=:=....................    Standard template: char *strcpy(char *s1, const char *s2) */
:=:=.................... char strcopy(char *s1, char *s2)
:=:=....................   for (s = s1; *s2 != 0; s++, s2++)
:=:=.................... 	  *s = *s2;
:=:=....................    char *strncpy(char *s1, const char *s2, size_t n).
:=:=....................    Copies max of n characters (not following ending '\0')
:=:=....................    from s2 in s1; if s2 has less than n characters, appends 0 */
:=:=.................... char strncpy(char *s1, char *s2, int n)
:=:=....................   for (s = s1; n > 0 && *s2 != '\0'; n--)
:=:=....................      *s++ = *s2++;
:=:=....................   for (; n > 0; n--)
:=:=....................      *s++ = '\0';
:=:=....................    size_t strcspn(const char *s1, const char *s2).
:=:=....................    Computes length of max initial segment of s1 that
:=:=....................    consists entirely of characters NOT from s2*/
:=:=.................... int strcspn(char *s1, char *s2)
:=:=....................    char *sc1, *sc2;
:=:=....................    for (sc1 = s1; *sc1 != 0; sc1++)
:=:=....................       for (sc2 = s2; *sc2 != 0; sc2++)
:=:=....................          if (*sc1 == *sc2)
:=:=....................             return(sc1 - s1);
:=:=.................... /* computes length of max initial segment of s1 consisting
:=:=....................    entirely of characters from s2 */
:=:=.................... int strspn(char *s1, char *s2)
:=:=....................       for (sc2 = s2; ; sc2++)
:=:=.................... 	 if (*sc2 == '\0')
:=:=....................          else if (*sc1 == *sc2)
:=:=....................             break;
:=:=.................... /* standard template: size_t strlen(const char *s).
:=:=....................    Computes length of s1 (preceding terminating 0) */
:=:=.................... int strlen(char *s)
:=:=....................    char *sc;
:=:=....................    for (sc = s; *sc != 0; sc++);
:=:=....................    return(sc - s);
:=:=.................... /* standard template: char *strlwr(char *s).
:=:=....................    Replaces uppercase letters by lowercase;
:=:=....................    returns pointer to new string s */
:=:=.................... char strlwr(char *s)
:=:=....................    for (p = s; *p != '\0'; p++)
:=:=....................       if (*p >= 'A' && *p <='Z')
:=:=....................          *p += 'a' - 'A';
:=:=....................    char *strpbrk(const char *s1, const char *s2).
:=:=....................    Locates first occurence of any character from s2 in s1;
:=:=....................    returns s1 if s2 is empty string */
:=:=.................... char strpbrk(char *s1, char *s2)
:=:=....................             return(sc1);
:=:=....................    char *strstr(const char *s1, const char *s2);
:=:=....................    Locates first occurence of character sequence s2 in s1;
:=:=....................    returns 0 if s2 is empty string */
:=:=.................... char strstr(char *s1, char *s2)
:=:=....................    if (*s2 == 0)
:=:=....................    for (; s1 = strchr(s1, *s2); s1++)
:=:=....................       for (sc1 = s1, sc2 = s2; ; sc1++, sc2++)
:=:=....................          if (*sc2 == 0)
:=:=....................          else if (*sc1 != *sc2)
:=:=.................... /* standard template: char *strtok(char *s1, const char *s2).
:=:=....................    Finds next token in s1 delimited by a character from separator
:=:=....................    string s2 (which can be different from call to call).  First call
:=:=....................    starts at beginning of s1 searching for first character NOT
:=:=....................    contained in s2; returns 0 if none is found.
:=:=....................    If one is found, it is the start of first token (return value).
:=:=....................    Function then searches from there for a character contained in s2.
:=:=....................    If none is found, current token extends to end of s1, and subsequent
:=:=....................    searches for a token will return 0.  If one is found, it is
:=:=....................    overwritten by '\0', which terminates current token.  Function saves
:=:=....................    pointer to following character from which next search will start.
:=:=....................    Each subsequent call, with 0 as first argument, starts searching
:=:=....................    from saved pointer */
:=:=.................... char strtok(char *s1, char *s2)
:=:=....................    char *beg, *end;
:=:=....................    static char *save;
:=:=....................    beg = (s1)? s1: save;
:=:=....................    beg += strspn(beg, s2);
:=:=....................    if (*beg == '\0')
:=:=....................       *save = ' ';
:=:=....................    end = strpbrk(beg, s2);
:=:=....................    if (*end != '\0')
:=:=....................       *end = '\0';
:=:=....................       end++;
:=:=....................    save = end;
:=:=....................    return(beg);
:=:=.................... #use delay(clock=4000000)
:=:=0005:  BCF    0A.3
:=:=0006:  BCF    0A.4
:=:=0007:  GOTO   010 (RETURN)
:=:=.................... #use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
:=:=.................... #define WIRE1 PIN_E0
:=:=.................... #define WIRE2 PIN_E1
:=:=.................... #define WIRE3 PIN_E2
:=:=.................... unsigned byte ptr;
:=:=.................... char i;
:=:=.................... byte ex_charge;
:=:=.................... long timetag_lo;		/* 1200 Hz clock */
:=:=.................... long timetag_hi;		/* 1 second clock */
:=:=.................... long timetag_top;		/* upper half on 1 second clock */
:=:=.................... char *adr;			/* address pointer */
:=:=.................... char shift_reg;
:=:=.................... char shift_out(char a) {
:=:=.................... char ip;
:=:=.................... char temp1;
:=:=.................... 	for(ip = 0; ip< 8;ip++) {
:=:=.................... 		output_low(PIN_D5);
:=:=.................... 		temp1 = (a >> ip) & 0x01;
:=:=.................... 		if(temp1 == 1) output_high(PIN_D6);
:=:=.................... 		else output_low(PIN_D6);
:=:=.................... 		output_high(PIN_D5);
:=:=.................... 	output_high(PIN_D7);
:=:=.................... 	output_low(PIN_D7);
:=:=0004:  RETLW  00
:=:=.................... main()
:=:=.................... /* Configure the ports */
:=:=.................... #use fast_io(A)			/* set A port IO */
:=:=.................... 	set_tris_a(0x3f);
:=:=.................... #use fast_io(B)			/* set B port IO */
:=:=.................... 	set_tris_b(0x3f);
:=:=.................... #use fast_io(C)			/* set C port IO */
:=:=.................... 	set_tris_c(0x92);
:=:=.................... #use fast_io(D)
:=:=.................... 	set_tris_d(0x0f);
:=:=.................... #use fast_io(E)
:=:=.................... 	set_tris_e(0x07);
:=:=.................... 	output_low(PIN_E0);
:=:=.................... 	output_low(PIN_E1);
:=:=.................... 	output_low(PIN_E2);
:=:=.................... 	adr = 0x06;
:=:=.................... 	shift_reg = 0x46;
:=:=.................... 	shift_out(shift_reg);
:=:=0008:  MOVF   2B,W
:=:=0009:  MOVWF  2C
:=:=000A:  CALL   004
:=:=.................... 	if(input(PIN_B5) == 1) ex_charge = 1;
:=:=.................... 	else ex_charge = 0;
:=:=.................... /* set timer to interrupt at 1200 Hz */
:=:=.................... 	setup_timer_1(T1_INTERNAL | T1_DIV_BY_4);
:=:=.................... 	enable_interrupts(INT_TIMER1); /* enable timer1 interrupt */
:=:=.................... 	set_timer1(65336);
:=:=.................... 	ptr = 0;
:=:=.................... 	timetag_lo = 0;
:=:=.................... 	timetag_hi = 0;
:=:=.................... 	timetag_top = 0;
:=:=.................... 	shift_reg = shift_reg | 0x03;
:=:=000B:  MOVF   2B,W
:=:=000C:  MOVWF  2C
:=:=000D:  CALL   004
:=:=.................... 	for(i=0;i<200;i++) {
:=:=.................... 		delay_ms(500);
:=:=000E:  CLRF   2D
:=:=000F:  GOTO   005
:=:=.................... 		shift_reg = shift_reg ^ 1;
:=:=0010:  MOVF   2B,W
:=:=0011:  MOVWF  2C
:=:=0012:  CALL   004
:=:=.................... 	while(1);
:=:=0013:  SLEEP
	Original Post ID: 660 |
			Ivan Guest
				 Posted: Sun Oct 14, 2001 1:43 pm     |
				That include statement was to by #include <string.h> It didn't copy for some reason. I took that out and got the same results when I compiled. Are there any flags  I should be setting for the compiler?
Ivan
	Original Post ID: 661 |
			Phil
				 Posted: Sun Oct 14, 2001 9:58 pm     |
				No flags.  It really should be compiling properly.  My only advice would be to re-install your compiler, ensure your using the correct compiler (PCM), and try to re-compile.  If that doesn't work, I think the support@ccsinfo.com is your only solution.
Phil
:=That include statement was to by #include <string.h> It didn't copy for some reason. I took that out and got the same results when I compiled. Are there any flags  I should be setting for the compiler?
:=Ivan
:=:=Well, I see that your line2 of your C file contains #include, but no file.  After removing this line, I compile your code using CCS v3.050 and receive the following list.  It seems to me like your compilation should work.  If installing the updated version doesn't work for you, you should contact CCS about this:
	Original Post ID: 664 |
