Glen Singletary Guest
Converting Byte String to Float |
Posted: Wed Aug 21, 2002 2:41 pm |
I am having difficulty casting a string to float. I am using PCW Compiler PCM version 3.033 and MPLAB IDE for win/16 version 5.50.0.
Consider this test program and the results I get when stepping through:
#include <16F877.h>
#device ICD=TRUE
#include <stdlib.h>
#fuses HS,NOWDT
#zero_ram
float ftemp;
int8 temp[4];
temp[0]=0x7f;
temp[1]=0x0;
temp[2]=0x0;
temp[3]=0x0;
ftemp = 1.0;
// RAM at temp = 7F 00 00 00
// RAM at ftemp = 7F 00 00 00
// Watch windows shows 1.000+00 for ftemp
ftemp = (float)*temp;
// RAM at ftemp = 85 7E 00 00
// Watch window shows 1.270+02 for ftemp
ftemp = *temp;
// same results...
Any ideas on why I am getting this result and how I can fix it?
thanks
___________________________
Original Post ID: 6494 |
R.J.Hamlett Guest
Re: Converting Byte String to Float |
Posted: Wed Aug 21, 2002 3:12 pm |
:=I am having difficulty casting a string to float. I am using PCW Compiler PCM version 3.033 and MPLAB IDE for win/16 version 5.50.0.
:=Consider this test program and the results I get when stepping through:
:=#include <16F877.h>
:=#device ICD=TRUE
:=#include <stdlib.h>
:=#fuses HS,NOWDT
:=#zero_ram
:=float ftemp;
:=int8 temp[4];
:=void main(void)
:= temp[0]=0x7f;
:= temp[1]=0x0;
:= temp[2]=0x0;
:= temp[3]=0x0;
:= ftemp = 1.0;
:= // RAM at temp = 7F 00 00 00
:= // RAM at ftemp = 7F 00 00 00
:= // Watch windows shows 1.000+00 for ftemp
:= ftemp = (float)*temp;
At this point, 'temp' contains the numeric sequence 7F00..., and you are now using this as a pointer!. You need to cast the _address_ of temp, to be a pointer to a float.
:= // RAM at ftemp = 85 7E 00 00
:= // Watch window shows 1.270+02 for ftemp
:= ftemp = *temp;
:= // same results...
:=Any ideas on why I am getting this result and how I can fix it?
:=thanks
You need to be more careful in dealing with pointers. The '&' character gets the address of temp (which you want), and this address, is then used with the '*' character as a pointer. Hence the 'full' expansion would be :
ftemp=*((float *)&temp);
which takes the address of 'temp', and converts this to a pointer to a float, and then uses this pointer to retrieve the value.
You can also use a union to get the same effect.
union {
int8 temp[4];
float ftemp;
} cstore;
cstore.temp[0]=0x7F;
cstore.temp[1]=cstore.temp[2]=cstore.temp[3]=0x00;
Now cstore.ftemp is the floating point value.
Original Post ID: 6497 |
Posted: Thu Aug 22, 2002 9:06 am |
:=:=I am having difficulty casting a string to float. I am using PCW Compiler PCM version 3.033 and MPLAB IDE for win/16 version 5.50.0.
:=:=Consider this test program and the results I get when stepping through:
:=:=#include <16F877.h>
:=:=#device ICD=TRUE
:=:=#include <stdlib.h>
:=:=#fuses HS,NOWDT
:=:=#zero_ram
:=:=float ftemp;
:=:=int8 temp[4];
:=:=void main(void)
:=:= temp[0]=0x7f;
:=:= temp[1]=0x0;
:=:= temp[2]=0x0;
:=:= temp[3]=0x0;
:=:= ftemp = 1.0;
:=:= // RAM at temp = 7F 00 00 00
:=:= // RAM at ftemp = 7F 00 00 00
:=:= // Watch windows shows 1.000+00 for ftemp
:=:= ftemp = (float)*temp;
:=At this point, 'temp' contains the numeric sequence 7F00..., and you are now using this as a pointer!. You need to cast the _address_ of temp, to be a pointer to a float.
:=:= // RAM at ftemp = 85 7E 00 00
:=:= // Watch window shows 1.270+02 for ftemp
:=:= ftemp = *temp;
:=:= // same results...
:=:=Any ideas on why I am getting this result and how I can fix it?
:=:=thanks
:=You need to be more careful in dealing with pointers. The '&' character gets the address of temp (which you want), and this address, is then used with the '*' character as a pointer. Hence the 'full' expansion would be :
:=ftemp=*((float *)&temp);
Using this expression gave me an "Expecting and Identifier" error because temp was declared as a string. Modifying this slightly to:
ftemp=*((float *)&temp[0]);
or
ftemp=*((float *)temp);
gave the correct results.
:=which takes the address of 'temp', and converts this to a pointer to a float, and then uses this pointer to retrieve the value.
:=You can also use a union to get the same effect.
:=union {
:= int8 temp[4];
:= float ftemp;
:=} cstore;
:=cstore.temp[0]=0x7F;
:=cstore.temp[1]=cstore.temp[2]=cstore.temp[3]=0x00;
:=Now cstore.ftemp is the floating point value.
:=Best Wishes
Thanks for the help.
Original Post ID: 6518 |
R.J.Hamlett Guest
Posted: Thu Aug 22, 2002 9:24 am |
:=<snipped>
:=:=ftemp=*((float *)&temp);
:=Using this expression gave me an "Expecting and Identifier" error because temp was declared as a string. Modifying this slightly to:
:=ftemp=*((float *)&temp[0]);
:=or
:=ftemp=*((float *)temp);
:=gave the correct results.
At least you saw 'where I was coming from', in that you need the address of the variable, not the contents. :-)
I tend to 'under proofread' what I type at times, so this sort of error is common....
Original Post ID: 6519 |
