How to use both HW SPI & SW SPI at the same time?
zephyrtr
PostPosted: Fri May 07, 2010 1:08 pm     Reply with quote
I tried to connect two SPI devices(digital compass and optical mouse) to PIC16f877. I reserved the HW pins for digital compass and want to use SW SPI for the optical mouse. I had a confusion with the SPI functions in CCS. There is setup_spi() function and #use spi directive. Can I use both of them in the same program, one for HW one for SW? Question
PostPosted: Fri May 07, 2010 1:13 pm     Reply with quote
I think it should work. Use setup_spi(), spi_write() and spi_read()
for the hardware SPI.
For the software SPI, invoke #use spi() with some other i/o pins.
Then use spi_xfer() to do the transfers.
You didn't give your compiler version. In some earlier versions, it's
possible that #use spi() is a little buggy. Here's an example which
uses hardware SPI, and software SPI, but the software SPI is done
with code, rather than the #use spi() library:
http://www.ccsinfo.com/forum/viewtopic.php?t=26888
You can do that if necessary.
bkamen
PostPosted: Fri May 07, 2010 5:40 pm     Reply with quote
PCM,
I've done a mix of #use SPI for hardware and software and then just name my streams..
I will concur that success is version sensitive and should be taken with a grain of salt.
-Ben
andrewg
PostPosted: Fri May 07, 2010 8:08 pm     Reply with quote
The usual thing (to me anyway) would be to use just one SPI bus (typically the hardware one) and then separate CS lines to each device. I presume there must be a reason for wanting separate SPI buses?
Andrew
bkamen
PostPosted: Fri May 07, 2010 8:20 pm     Reply with quote
Only in situations where you might want both buses to run at the same time, but if they don't need to, a single bus with mulitple nCS lines is just dandy too.
-Ben
zephyrtr
PostPosted: Mon May 10, 2010 9:31 am     Reply with quote
How can I write
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_16)
with #use spi directive?
PostPosted: Mon May 10, 2010 11:19 am     Reply with quote
I think this will work:
#use spi(MASTER, SPI1, BITS=8, MODE=1, MSB_FIRST, BAUD=1000000, ENABLE=PIN_C0)
This uses the hardware SPI module as an SPI master.
Note that I've picked Pin C0 as the SPI chip select pin, going from the
PIC (the master) to the slave.
I'm also assuming that your PIC runs at 20 MHz, and that with your
divide-by-16 divisor, you want an SPI clock of about 1 MHz.
andrewg
PostPosted: Tue May 11, 2010 6:32 am     Reply with quote
When I've used #use spi, I've not specified the enable pin in the directive, but managed it myself. Otherwise, spi_xfer() becomes complicated to use with multi-byte transfers.
Andrew
bkamen
PostPosted: Wed May 12, 2010 12:41 pm     Reply with quote
I've done multi-byte regularly without any real issues (except when PCD came out and still had some bugs which I've seen are not gone)
Depends on if the ENABLE is specified to control the nCS pin.
If I'm doing multiple devices or multiple bytes, I control the nCS pin and off I go.
-Ben
