GPS and 2 baud rates
uni_student
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Tue May 04, 2010 3:45 am     Reply with quote
Hi, im trying out a new gps module which is using 4800 baud. Problem im having is reading time info from the RMC message and displaying onto LCD with the following format "HH:MM:SS". Old Gps module ran on 9600 baud and worked perfectly with my code. New gps module only displays seconds and "IZ" for hours and "CH" for minutes. I only seem to be reading seconds properly. So in format it looks like this "IZ:CH:32" example
Using PIC18F452, LCD using LCD117 phanderson.com kit
#use rs232(baud=9600, xmit=PIN_A5, rcv=PIN_A4, parity=N, bits=8, stream=LCD, ERRORS)
#use rs232(baud=4800, xmit=PIN_C6, rcv=PIN_C7, parity=N, bits=8, stream=GPS, ERRORS)
//code in a function
 r=message (messge, 1);
      if(r==TRUE){
         i=0;
         while(TRUE){
            z=fgetc(GPS);
            if(z==',')
            temp[i]=z;
            i++;
         if(x==1){
         fprintf(LCD, "?x06");
         fprintf(LCD, "%c%c:%c%c:%c%c\r", temp[0], temp[1], temp[2], temp[3], temp[4], temp[5]);
int message (char *mess, int x){
   int j;
   j=0;
   while(TRUE){
      z=fgetc(GPS);
      if(z=='$')
   z=fgetc(GPS);
   if(z==mess[0])
      z=fgetc(GPS);
   if(z==mess[1])
      z=fgetc(GPS);
   if(z==mess[2]){
      z=fgetc(GPS);
   if(z==mess[3])
      z=fgetc(GPS);
   if(z==mess[4])
      while(j<x){
         z=fgetc(GPS);
         if(z==',')
            j++;
      return TRUE;
   } else{
      return FALSE;
Any help appreciated
PostPosted: Tue May 04, 2010 4:08 am     Reply with quote
Seriously, I'd be looking at what the data format is from the GPS. Classic thing, would be something like the new unit, and the old using different lengths for the numbers. NMEA, allows you to send a time, with or without leading zeros for example, which is why you really need to search for the commas.
uni_student
PostPosted: Tue May 04, 2010 3:55 pm     Reply with quote
Thanx for reply.
I've had both modules on the hyperterminal and messages, commas, etc are the same. Forgot to mention the LCD is running at 9600 baud, so I am switching between 9600 and 4800 all the time...has that got any implications on anything???
Cheers
Douglas Kennedy
PostPosted: Wed May 05, 2010 2:14 am     Reply with quote
A gps squawks sentences at a rate the GPS determines. Probably you were lucky with the earlier GPS in that your code actually worked. An interrupt driven circular buffer is the only reliable way to interface with a GPS and for that matter most RS232 input. Without the interrupt approach is not that it doesn't work sometimes the issue is it only works sometimes.
bkamen
PostPosted: Sun May 09, 2010 4:05 pm     Reply with quote
I agree.
I've written routines for both the Garmin GPS16 and the DeLorme GPS2058 module (both have configurable data rates and message outputs with different config methods) both using a common IRQ driven receive buffer.... although I didn't do circular. I did a per/sentence flag and go --- just in case which ended up working out fine.
It really makes dealing with GPS's easier.
-Ben
