falonsos
| 16F877A LCD at 20 MHz |
Posted: Sat May 01, 2010 6:09 pm |
Hello.
I have been working very hard trying to make a 16x2 LCD work. But I just couldn't make it...
I hope somebody can help me with this. The code I'm using is:
#include <16F877A.h>
#FUSES RC //Resistor/Capacitor Osc with CLKOUT
#FUSES HS
#include <lcd.c>
lcd_init();
printf(lcd_putc,"/fhello world");//lcd_putc("hello");
Thanks a lot!! |
Humberto
Posted: Sat May 01, 2010 6:55 pm |
| Quote: |
#FUSES HS
You have a redundant pre-processor directive, the compiler always validate the last option:
HS in this case, wich assume that you have a crystal in the oscillator module.
Regards,
Humberto |
falonsos
Posted: Sat May 01, 2010 7:03 pm |
Thanks! I will delete that line right away!
But, I'm using a crystal in the oscillator module of 20 MHz. So I don't think that's the problem. |
bkamen
Joined: 07 Jan 2004 Posts: 1619 Location: Central Illinois, USA
Posted: Sat May 01, 2010 8:55 pm |
Did you write the driver for the LCD yourself or are you using something included with CCS PIC-C?
Most of the time, the common mistakes are:
PIN Assignments
Timing Issues
PORT settings (TRIS)
I see you're include LCD.C, but no where have you defined where the LCD is hooked up (what port, pins, etc)
