kw
Bootloader: #device statements not amenable to #org position |
Posted: Mon Apr 26, 2010 7:29 am |
I am trying to create a bootloader and I cannot use something off the shelf due to the way information is received.
I need to obtain precise code positioning.
I managed to use 'default' as an option to the #org directives to map out pieces of code created by "#use" (such as "#use delay").
However, a #device directive generates code that cannot be positioned (#org statements before #device generate an error).
The problem is that without precise positioning of #device generated code, this code is liable to being overwritten by the bootloader - evidently this "#device" code includes general use stuff because my bootloader code jumps to it. When it's overwritten - kaboom.
Is there a way to tell the compiler to put #device generated code at a particular location? |
kw
Re: Bootloader: #device statements not amenable to #org posi |
Posted: Mon Apr 26, 2010 8:18 am |
By the way I am exploring further and see that erase_program_eprom calls a subroutine inside the generated code for #device.
Code: | .................... erase_program_eeprom(rompos);
0F2C: MOVF 55,W
0F2D: BSF 03.6
0F2E: MOVWF 0D
0F2F: BCF 03.6
0F30: MOVF 56,W
0F31: BSF 03.6
0F32: MOVWF 0F
0F33: BSF 03.5
0F34: BSF 0C.7
0F35: BSF 0C.4
0F36: BSF 0C.2
0F37: BCF 0A.3
0F38: BCF 03.5
0F39: BCF 03.6
0F3A: GOTO 12D
0F3B: BSF 0A.3
0F3C: BSF 03.5
0F3D: BSF 03.6
0F3E: BCF 0C.4
0F3F: BCF 03.5
0F40: BCF 03.6 |
Check that 12d... here's what #device spits out.
Code: | .................... #device PIC16F88
012D: MOVF 0B,W
012E: MOVWF 78
012F: BCF 0B.7
0130: BSF 03.5
0131: BSF 03.6
0132: MOVLW 55
0133: MOVWF 0D
0134: MOVLW AA
0135: MOVWF 0D
0136: BSF 0C.1
0137: GOTO 138
0138: BTFSC 0C.1
0139: GOTO 138
013A: BCF 0C.2
013B: MOVF 78,W
013C: BCF 03.5
013D: BCF 03.6
013E: IORWF 0B,F
013F: BSF 0A.3
0140: GOTO 73B (RETURN)
0141: MOVF 0B,W
0142: MOVWF 04
0143: BCF 0B.7
0144: MOVLW FC
0145: BSF 03.6
0146: ANDWF 0D,F
0147: BSF 03.5
0148: BSF 0C.7
0149: BSF 0C.2
014A: MOVLW 04
014B: MOVWF 77
014C: BCF 03.5
014D: MOVF 0D,W
014E: SUBWF 7A,W
014F: BTFSC 03.2
0150: GOTO 156
0151: BSF 03.5
0152: BSF 0C.0
0153: GOTO 154
0154: GOTO 15B
0155: BCF 03.5
0156: MOVF 78,W
0157: MOVWF 0C
0158: MOVF 79,W
0159: MOVWF 0E
015A: BSF 03.5
015B: MOVLW 55
015C: MOVWF 0D
015D: MOVLW AA
015E: MOVWF 0D
015F: BSF 0C.1
0160: GOTO 161
0161: GOTO 162
0162: BCF 03.5
0163: INCF 0D,F
0164: DECFSZ 77,F
0165: GOTO 14D
0166: BSF 03.5
0167: BTFSC 0C.1
0168: GOTO 167
0169: BCF 0C.2
016A: MOVF 04,W
016B: BCF 03.5
016C: BCF 03.6
016D: IORWF 0B,F
016E: BSF 0A.3
016F: GOTO 778 (RETURN)
018A: CLRF 78
018B: CLRF 79
018C: CLRF 77
018D: CLRF 7A
018E: MOVF 64,W
018F: BTFSS 03.2
0190: GOTO 194
0191: MOVF 63,W
0192: BTFSC 03.2
0193: GOTO 1AE
0194: MOVLW 10
0195: MOVWF 65
0196: BCF 03.0
0197: RLF 61,F
0198: RLF 62,F
0199: RLF 77,F
019A: RLF 7A,F
019B: MOVF 64,W
019C: SUBWF 7A,W
019D: BTFSS 03.2
019E: GOTO 1A1
019F: MOVF 63,W
01A0: SUBWF 77,W
01A1: BTFSS 03.0
01A2: GOTO 1AA
01A3: MOVF 63,W
01A4: SUBWF 77,F
01A5: BTFSS 03.0
01A6: DECF 7A,F
01A7: MOVF 64,W
01A8: SUBWF 7A,F
01A9: BSF 03.0
01AA: RLF 78,F
01AB: RLF 79,F
01AC: DECFSZ 65,F
01AD: GOTO 196
01AE: BCF 0A.3
01AF: GOTO 1E8 (RETURN)
0218: MOVLW 10
0219: BSF 03.5
021A: MOVWF 2C
021B: CLRF 77
021C: CLRF 7A
021D: RRF 29,F
021E: RRF 28,F
021F: BTFSS 03.0
0220: GOTO 227
0221: MOVF 2A,W
0222: ADDWF 77,F
0223: BTFSC 03.0
0224: INCF 7A,F
0225: MOVF 2B,W
0226: ADDWF 7A,F
0227: RRF 7A,F
0228: RRF 77,F
0229: RRF 79,F
022A: RRF 78,F
022B: DECFSZ 2C,F
022C: GOTO 21D
022D: BCF 03.5
022E: RETLW 00 |
Posted: Mon Apr 26, 2010 12:29 pm |
Make a very short (just a few lines) test program that is compilable,
and that demonstrates the problem. For example, just call the
erase_program_eeprom() function in your code, and explain where
the CCS library code is put (ie., the address), and where you would
like it to be.
In other words, your main() will consist of just the call to that function,
and a while(1); line at the end. But the program should have the
#include for the PIC, #fuses, and #use delay(), #org statements, and
any minimal bootloader code that is required.
The more simple you make the test program, the easier it will be to
give you an answer. |
