Desperately Need assistance
Sage_EE
PostPosted: Fri Apr 23, 2010 5:50 pm     Reply with quote
I have been reading all of the links and suggestions associated with the following error and I have had absolutely no luck in compiling my code. I need this code to work for my senior design project and I do not have adequate skills to debug this code. I originally had registers.c included in the source code but I was using an extern function when I read that wouldn't work. So I simply added all of my registers to the TRTLfinalCode.c file.
//TRTLfinalCode.c
#device .*=16 adc=10 ICD=TRUE
#include <18F14K50.H>            //Identify Microcontroller
//#include<registers.c>            //include registers file
// Set up Config Bits ex. WDT,JTAG...
#fuses HS,NOWDT,NOPROTECT,NOLVP,MCLR
// Use HS Oscillator (startup)
// No Watchdog Timer
// No Code Protect
// Use MCLR Pin as Reset..
//Enable Master Clear=MCLR
#include <math.h>
#use delay(clock=2000000)         //Setup C-Code Oscillator Value
//#use fast_io(d)               //Leave the State of Port-D (all bits)
                           //the same until changed, again
#use I2C(master, SCL=PIN_RB6, SDA=PIN_RB4)
#define captured   1
#define ON      1
#define OFF      0
#define true   1
#define reedSW1   PIN_RA0 // input1 to reed switch on door 1
#define reedSW2 PIN_RA1   // input2 to reed switch on door 2
#define LED1   PIN_RA4   //output pin  1
#define LED2   PIN_RA5 //output pin  2
#define LED3   PIN_RC6 //output pin  3
#define LED4   PIN_RC7 //output pin  4
#define C12OUT   PIN_RC4 //Battery alert output pin to redLED (output of comparator)
// TrapNum in EEPROM of RTC
// NOP(); == Preform No Operation for one instruction Cycle
//RA0 and RA1 are configured using 00000011 (convert to hex) and they do not need a TRISA register bit
//RA4, if used for output needs a LATA bit and maybe a TRISA bit
void blinkLED(void);
void SetTime(void);
void Checktime(void);
// make suer you have all functions listed/defined here
// VARIABLES USED
int GotIt;
int RTCHour;   //16-Bit Word Variable
   TRISA = 0b00000000;      //configure output for pins RA4 & RA5
   TRISB = 0b00101000;      //used for clock
   TRISC = 0b00000000;      //configure out for battery monitor for pins RC7, RC6 and RC4, TRISC must be cleared for comparator operation
   // PORTx and LATx writes to the whole port at once, making the value written highs or lows on the respective pins
   WPUA = 0b00000000;      // no weak pull up
   IOCA = 0b00110011;      // interupt on change RA0,RA1,RA4
//insert registers here
   ANSEL = 0b00000000;      // disables digital input buffer for analog comparator input
   REFCON0 = 0b11100000;
   CM1CON0 = 0b11100101;   //inverts polarity, low power, use comparator1,
   CM2CON0 = 0b00000000;   //disabled
   CM2CON1 = 0b00100010;   //MC1OUT( mirror copy of C1OUT), FVR routed to C12REF input, no hysteresis, output synchronus to rising edge of TMR1 clock
   T1CON = 0b01001001;      //Timer1 register
   OSCCON = 0b11000110;   //Oscillator Control Register, Device is running from the internal oscillator (HFINTOSC or LFINTOSC)
   OSCCON2 = 0b00000111;
   OSCTUNE = 0b01000000;
         // initalize all registers
   SetTime();            // if RTC not set, Set it
//   setup_comparator(mode)   //Enables and sets the analog comparator module.
                     //The options vary depending on the chip, please refer to the header file for details.
//Relevant Interrupts:
//   INT_COMP            //Interrupt fires on comparator detect. Some chips have more than one comparator unit, and hence more interrupts.
Begin:
   CheckBatt();
      while(reedSW1 == captured || reedSW2 == captured)         // If animal Captured
         //TrapNum = getenv(ID);      // Returns the device ID (set by #ID)
         //printf("Animal in Trap: ", TrapNum, "/n/r")
         // if True is defined as true, it needs to stsy the same.
         // the compiler is case sensitive...
         GotIt = True;
         CheckBatt();
         Checktime();   // Reads RTC, If night, Stay there till day then return
         blinkLED();
      }//while animal in cage
   goto Begin;
}//main loop
 //never Exit
void CheckBatt(void)
   if (C12OUT)
      blinkLED();
}//end CeckBatt
void blinkLED(void) //set up output pins     which pins can we use???
   // if you wee to use an LED driver such as an LF412 as a buffer you only need to use one output pin to go to the "+" terminal of the opamp.
   //LED1
   Output_high(LED1);
   Output_high(LED2);
   Output_high(LED3);
   Output_high(LED4);
   //LEDs = ON;
   Output_low(LED1);
   Output_low(LED2);
   Output_low(LED3);
   Output_low(LED4);
   //LED = OFF;
   delay_ms(2000);
}//end blinkLED
void SetTime(void)
   //This code sets proper status register 1 values
   I2C_START();      //Start communication
   I2C_WRITE(0x60);   //Write to status 1 register on the RTC.  Info about this register on page 12 & 9, RTC datasheet.
   I2C_WRITE(0xC0);   //Initiate RTC and set to military time
   I2C_STOP();         //End communication
   //This code sets proper status register 2 values
   I2C_WRITE(0x62);   //Write to status 2 register on the RTC.  Info about this register on page 13 & 9, RTC datasheet.
   I2C_WRITE(0x00);   //Initialize TEST pin.  No interrupts on interrupts 1 and 2.
   //This code will program the correct time into the clock.  Values have to be entered in real time.
   //Translation of current time into values is in on page 11 of RTC datasheet.
   I2C_WRITE(0x66);   //Write to RTC2 register on the RTC.  Info about this register on page page 10 & 9, RTC datasheet.
   I2C_WRITE(0x48);   //Hour 12
   I2C_WRITE(0x00);   //minute 00
   I2C_WRITE(0x00);   //second 00
   I2C_STOP();
}//end SetTime
   // You Didn't Do this still...
   //define RTCHour, RTCMin, RTCSec
   I2C_START();      //start communication
   I2C_WRITE(0x67);   //access (read) register RTC 2
   RTCHour=I2C_READ();
   I2C_STOP();         //end communication
   if((RTCHour=0x10 || RTCHour=0x90 || RTCHour=0x50 || RTCHour=0x88 || RTCHour=0x48 || RTCHour=0xC8 || RTCHour=0x28 || RTCHour=0xA8 || RTCHour=0x68 || RTCHour=0xE8 || RTCHour=0x18 || RTCHour=0x98) && GotIt != 1)      // if day and no animal
      NOP();
   else if((RTCHour=0x10 || RTCHour=0x90 || RTCHour=0x50 || RTCHour=0x88 || RTCHour=0x48 || RTCHour=0xC8 || RTCHour=0x28 || RTCHour=0xA8 || RTCHour=0x68 || RTCHour=0xE8 || RTCHour=0x18 || RTCHour=0x98)&& GotIt == 1)   // if day and animal
      blinkLED();
}//end CheckTime
The Error Message is as follows:
Executing: "C:\Program Files (x86)\PICC\Ccsc.exe" +FH "TRTLfinalCode.c" +DF +LN +T +A +M -Z +Y=9 +EA
*** Error 128 "TRTLfinalCode.c" Line 2(25,46): A #DEVICE required before this line
1 Errors, 0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Fri Apr 23 19:27:50 2010
Please help, I am very lost...
PostPosted: Fri Apr 23, 2010 6:47 pm     Reply with quote
Move #include <18F14K50.H> up to the first line.
Sage_EE
Not quite
PostPosted: Fri Apr 23, 2010 7:19 pm     Reply with quote
When I do that I get a new slew of errors that I avoided before by moving the #device line to the top of the code. I have a feeling that the PIC18F14K50 file is somehow missing from the program files but I can't figure out how to put them in there. I ran the project wizard and everything says it is supported and compatible. I am also using MPLAB and the ICD2 device to debug.
Sage_EE
ERROR
the error is:
*** Error 18 "TRTLfinalCode.c" Line 2(26,38): File can not be opened
Not in "C:\PROGRA~2\PICC\devices\18F14K50.H"
Not in "C:\PROGRA~2\PICC\drivers\18F14K50.H"
Not in local "C:\Users\yoo\Desktop\TRTL_CODE_FINAL\18F14K50.H"
--- Info 300 "TRTLfinalCode.c" Line 3(46,52): More info: Device database: "C:\Program Files (x86)\PICC\devices4.dat"
*** Error 24 "TRTLfinalCode.c" Line 3(46,78): Unknown device type "PIC18F14K50"
*** "TRTLfinalCode.c" Line 3: Error #24: Unknown device type -- Try
*** "TRTLfinalCode.c" Line 3: Error #128: A #DEVICE required before this line
*** "TRTLfinalCode.c" Line 5: Error #18: File can not be opened
Not in "C:\PROGRA~2\PICC\devices\18F145K0.c"
Not in "C:\PROGRA~2\PICC\drivers\18F145K0.c"
Not in local "C:\Users\yoo\Desktop\TRTL_CODE_FINAL\18F145K0.c"
*** "TRTLfinalCode.c" Line 11: Error #111: Unknown keyword in #FUSES "MCLR"
*** "C:\PROGRA~2\PICC\drivers\math.h" Line 36: Error #128: A #DEVICE required before this line
PostPosted: Fri Apr 23, 2010 7:32 pm     Reply with quote
The simplest way to fix the error is to add the full path with the file name to fix the error
(i.e. #include <c:\dir1\dir2\18F14K50.H> ) or change the line to
#include "18F14K50.H" and put the header file in the same directory
as the main source file.
Sage_EE
Almost
PostPosted: Fri Apr 23, 2010 8:25 pm     Reply with quote
Thanks, I found the correct compiler and associated library online at: http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en010014&redirects=c18
Then I added the file <p18f14k50.h> to my header directory and it got rid of the original error!
Now I have a syntax error for the #device line...it seems that the commands #fuses, #use and #device are causing syntax errors... is there a library that I should be including as well?
 //TRTLfinalCode.c
#include <p18f14k50.h>//Identify Microcontroller
#device *=16 adc=10 ICD=TRUE
any suggestions?
P.S. You've no idea how much you are helping us all out!
PostPosted: Fri Apr 23, 2010 9:37 pm     Reply with quote
At this point, no one knows if you are using the Microchip C18 compiler
or the CCS compiler. They are not compatible. The code written for each
compiler is not compatible with the other. Each compiler has its own
functions and extensions.
This forum is for the CCS compiler.
The C18 compiler forum is here:
http://www.microchip.com/forums/tt.aspx?forumid=3
Sage_EE
c18
PostPosted: Fri Apr 23, 2010 10:25 pm     Reply with quote
While searching for a compiler that contained the library for the PIC18F14k50 I was led to use the c18 compiler in order to obtain compatible files. I am now trying to convert the CCS code that I have into c18. It appears that the majority of the code is still compatible but the commands, fuses, use, and device.
I will check out that forum and see what I can do.
