PIC16f690 Timer1 not working properly
lokeshbhatt
PostPosted: Wed Apr 21, 2010 11:51 pm     Reply with quote
What is the maximum clock can I get using internal oscillator? What is
that noclear in ISR? Is this Timer code right?
#include <16f690.h>
//#inlcude "stdio.h"
//#fuses NOWDT,NOPROTECT,CPD,NOMCLR,NOIESO,NOFCMEN  // preprocessor directive that defines fuses for the chip
#fuses INTRC_IO,NOWDT,NOPROTECT,CPD,NOMCLR,NOIESO,NOFCMEN
#use delay(clock=8000000)
#priority timer1//#use rs232(baud=9600, xmit=PIN_B7, rcv=PIN_B5) // preprocessor directive that includes the rs232 libraries
#define Square_Pulse PIN_B4
#define LED_Blink    PIN_B5
#define test       PIN_B6
unsigned char fStartOfPolling;
**************  TIMER ISR FUNCTION   *****************
#INT_TIMER1  noclear
void my_timer()
static int tCountFor20msec,tCountFor1sec,fFor12Sec,CountForLEDBlink;
//      disable_interrupts(GLOBAL);
//   clear_interrupt(INT_TIMER1);
//SET_TIMER1(25536);
   //   OUTPUT_TOGGLE(test);
      if(   tCountFor20msec++ == 50 )
            //   output_toggle( Square_Pulse);
               if( CountForLEDBlink == 0)
                  output_toggle(LED_Blink);
               else if (CountForLEDBlink == 5)
                  OUTPUT_LOW(LED_Blink);
               if( tCountFor1sec++ == 12)
                     fStartOfPolling  = 1;
                      tCountFor1sec    = 0;
                      CountForLEDBlink = 5;
            tCountFor20msec=0;
      //   puts("micro");
//enable_interrupts(GLOBAL);
int InputPortValue = 0;
SET_TRIS_C(0b00000000);   // 3 OUTPUT
SET_TRIS_A(0b11111111);   // 4 INPUT
SET_TRIS_B(0b00000000);   // FOR SQUARE WAVE, LED BLINK
//setup_oscillator(OSC_INTRC);
setup_adc_ports(NO_ANALOGS | VSS_VDD);
setup_adc(ADC_OFF);
//setup_adc_ports(sAN8 | VSS_VDD);
      // for 20msec 40000 count required
//disable_interrupts(INT_TIMER1);
//SET_TIMER1(0);
//clear_interrupt(INT_TIMER1);
SET_TIMER1(25536);
SETUP_TIMER_1(T1_INTERNAL | T1_DIV_BY_1 );
/************ LOW-HIGH-LOW PULSE ON PWRKEY PIN OF GSM */
OUTPUT_C(0x00);
OUTPUT_LOW(Square_Pulse);
OUTPUT_HIGH(LED_Blink);
OUTPUT_HIGH(test);
      if( fStartOfPolling  == 1)
         InputPortValue = INPUT_A();
         InputPortValue = (InputPortValue & 0x0F );
         if(InputPortValue == 0x08 )   // INPUT 1 IS HIGH
         OUTPUT_C(0x04);
         else if(InputPortValue  == 0x0C )
         OUTPUT_C(0x02);
         else if(InputPortValue  == 0x0E )
         OUTPUT_C(0x06);
         else if(InputPortValue  == 0x0F )
         OUTPUT_C(0x01);
Thanx in anticipation
Lokesh
Thanks & Regards
Lokesh Bhatt
dyeatman
PostPosted: Thu Apr 22, 2010 5:39 am     Reply with quote
Answers to your questions:
1. See the data sheet page 48 for the max oscillator speed.
2. See page 116 of the current manual for the meaning of noclear
3. no
Google and Forum Search are some of your best tools
PostPosted: Thu Apr 22, 2010 9:33 am     Reply with quote
And, because noclear is used, the code as posted cannot work. It'll hang forever in the timer1 interrupt...
