msa
| #byte and #bit |
Posted: Sat Apr 10, 2010 10:07 am |
Dear all
I have 18f2550. I need to use #byte and #bit to name my pins.
My code :
#include <18F2550.h>
#use delay(clock=8000000)
#FUSES INTRC_IO //Internal RC Osc
#FUSES NOLVP //No low voltage prgming, B3(PIC16)
#FUSES NOMCLR //Master Clear pin disabled
#byte PORTA=0xF80
#bit led1=PORTA.0
#bit led2=PRATA.1
#bit led3=PORTA.2
void main(void){
setup_oscillator(OSC_8MHZ);
for(;;){
output_high(led1);
output_high(led2);
output_high(led3);
output_low(led1);
output_low(led2);
output_low(led3);
but this code not working.
thanks |
taner_73
Posted: Sat Apr 10, 2010 10:45 am |
first this is wrong:
and should be:
and second this code block:
| Code: | output_high(led1);
output_high(led2);
output_high(led3); |
should be:
| Code: | led1=1;
led2=1;
led3=1; |
and this:
| Code: | output_low(led1);
output_low(led2);
output_low(led3); |
should be:
led1=0;
led2=0;
led3=0;
Best regards,
Taner
| Ttelmah |
Posted: Sat Apr 10, 2010 12:53 pm |
Add, third, if you are talking directly to the pins, then _you_ have to control the TRIS.
msa
Posted: Sat Apr 10, 2010 12:56 pm |
Hi taner_73
Hi Ttelmah
Thanks for your answers.
It is now working.
My code after update:
#FUSES NOLVP //No low voltage prgming, B3(PIC16) or
#byte PORTA=0xF80
#bit led1=PORTA.0 // bit 0
#bit led2=PORTA.1 // bit 1
#bit led3=PORTA.2 // bit 2
void main(void){
SET_TRIS_A(0xF8); // 1111 1000
output_a(0);
for(;;){
led1=1;delay_ms(500);led1=0;
led2=1;delay_ms(500);led2=0;
led3=1;delay_ms(500);led3=0;
thiam
Posted: Sat Apr 10, 2010 8:59 pm |
| What is difference between #bit and #byte ? |
