ELCouz
Posted: Fri Jan 22, 2010 11:52 am |
Make you code to ignore the value next to your WDT call.
Something like that:
call wdt
then put a flag like wdtcalled = 1
and before displaying the value look for the flag (if 1 then skip or display the last value)and after that reset it.
It's a dirty trick but it will work ;)
Regards,
Laurent |
Macas
Posted: Sat Jan 23, 2010 9:49 am |
Thanks for your reply ELCouz by i already tried that and didnt work.
Here's my code:
| Code: | #include <18F2580.H>
#include <can-18xxx8.c>
#fuses HS, WDT1024
#priority CANRX0, CCP1, TIMER1, TIMER2
#define BytePtr(var, offset) (CHAR *)((char*)&var + offset)
#define pi 3.1415927
#define no1_id 140
struct rx_stat rxstat;
int32 rx_id;
int rx_len;
int buffer1[8];
int1 flag_serial=0;
int8 per=0;
int8 perflag=0;
int8 velocidade=0;
#byte PIR1 = 0xF9E
#bit TMR1IF = PIR1.0
int8 gc_timer1_extension = 0;
int8 gc_capture_flag = FALSE;
int8 flagflanco = FALSE;
int32 g32_ccp_delta;
int16 flag=0;
int16 flag1=0;
int buffer[8];
int16 fdigital(int16 sample)
static int16 x=0,z=0,y=0;
x=sample;
z=x-y+z;
y=z>>4;
return y;
#INT_timer2
void timer2_isr()
flag++;
#INT_timer1
void timer1_isr(VOID)
gc_timer1_extension++;
#INT_ccp1
void ccp1_isr(VOID)
CHAR timer_ext_copy;
INT32 current_ccp;
STATIC int32 old_ccp = 0;
gc_capture_flag = TRUE;
flagflanco=TRUE;
current_ccp = (INT32)CCP_1;
// Get local copy of the timer ext.
timer_ext_copy = gc_timer1_extension;
IF(TMR1IF) //Interrupcao do Timer1
IF ( * BytePtr (current_ccp, 1) < 2) // Was CCP captured after Timer1 wrapped?
timer_ext_copy++; // IF so, inc the copy of the timer ext.
// Since we know a timer interrupt is pending, let's just
// handle it here and now. That saves a little load off
// the processor.
gc_timer1_extension++; // Increment the real timer extension
TMR1IF = 0; // Then clear the Timer1 interrupt
// Insert the timer extension into the proper place in the 32-bit
// CCP value.
// ie., Insert it into location "EE" as follows: 0x00EEnnnn
// (nnnn = the CCP).
*BytePtr(current_ccp, 2) = timer_ext_copy;
g32_ccp_delta = (current_ccp > old_ccp) ? current_ccp - old_ccp : current_ccp + (0x1000000 - old_ccp);
// Save the current ccp value FOR next time.
old_ccp = current_ccp;
flagflanco = FALSE;
#int_CANRX0
void isr_can()
if(can_getd(rx_id, buffer1, rx_len, rxstat))
if(rx_id == 150)
perflag=buffer1[0];
flag_serial=1;
float frequencia;
INT32 current_ccp_delta;
per=read_eeprom(0x00);
set_timer1(0);
setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
setup_timer_2(T2_DIV_BY_4, 124, 10); // (1/20M)*4*4*125*10 = 1ms interrupt
set_timer2(0);
setup_ccp1(CCP_CAPTURE_RE);
can_init();
setup_WDT(WDT_ON);
// Enable interrupts.
clear_interrupt(INT_TIMER1);
clear_interrupt(INT_CCP1);
enable_interrupts(INT_CCP1);
clear_interrupt(INT_TIMER2);
enable_interrupts(INT_CANRX0);
WHILE(TRUE)
disable_interrupts (GLOBAL) ;
current_ccp_delta = g32_ccp_delta;
enable_interrupts (GLOBAL) ;
if ( flag_serial == 1 )
write_eeprom(0x00,perflag);
per=perflag;
flag_serial=0;
IF (gc_capture_flag == TRUE)
frequencia = (5000000L / (float)current_ccp_delta);
velocidade = ((float)per / (1/frequencia)) * 0.036;
velocidade = fdigital( velocidade );
buffer[0]=velocidade;
IF(flag == 100)
can_putd(no1_id,buffer,1,1,1,0);
flag = 0;
ELCouz
Posted: Sat Jan 23, 2010 2:32 pm |
There's a problem with your code...
You want to use the watch dog timer BUT you don't use restart_wdt() function which tell reset the WDT. If you don't put this in your code loop every 1024ms your code the pic will reboot. That's why you got an erroneous value.
Please search the forum for proper use of the WDT and read the CCS C compiler help.
Regards,
Laurent
WDT or Watch Dog Timer
Different chips provide different options to enable/disable or configure the WDT.
Relevant Functions:
setup_wdt
Enables/disables the wdt or sets the prescalar.
restart_wdt
Restarts the wdt, if wdt is enables this must be periodically called to prevent a timeout reset.
For PCB/PCM chips it is enabled/disabled using WDT or NOWDT fuses whereas on PCH device it is done using the setup_wdt function.
The timeout time for PCB/PCM chips are set using the setup_wdt function and on PCH using fuses like WDT16, WDT256 etc.
RESTART_WDT when specified in #use delay , #use I2c and #use RS232 statements like this #use delay(clock=20000000, restart_wdt) will cause the wdt to restart if it times out during the delay or I2C_READ or GETC.
Relevant Preprocessor:
#fuses WDT/NOWDT
Enabled/Disables wdt in PCB/PCM devices
#fuses WDT16
Sets ups the timeout time in PCH devices
Relevant Interrupts:
None
Relevant Include Files:
None, all functions built-in
Relevant getenv() parameters:
None
Example Code:
For eg:
For PIC16F877
#fuses wdt
setup_wdt(WDT_2304MS);
while(true){
restart_wdt();
perform_activity();
For PIC18F452
#fuse WDT1
setup_wdt(WDT_ON);
while(true){
restart_wdt();
perform_activity();
Some of the PCB chips share the WDT prescalar bits with timer0 so the WDT prescalar constants can be used with setup_counters or setup_timer0 or setup_wdt functions.
Macas
Posted: Sun Jan 24, 2010 5:38 am |
but i really do want to reboot because my code is stucking somewhere. |
Salenko
Posted: Sun Mar 21, 2010 2:36 pm |
Hi everyone,
Compiler version : PCW 4.057
I wrote this code after reading whole messages of this thread, measures aren't accurate for low frequencies ( I got 11.4 and 10.04 instead of 10 Hz, 19.58 and 25.91 instead of 20 Hz) and when I move to higher frequencies I got absurd values into my screen ( example for 150 Hz , I got 0.79 Hz, 77Hz and 94340.11 Hz ) .
I'm using a precise pulse generator.
Do you think that I miss something in my code ?
Thank you for any suggestion guys.
#include <16F628.h>
#use delay(clock = 20 000 000)
#use rs232 (baud=9600,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8)
#priority CCP1, TIMER1
#byte PortB = 6 // Address of PortB for 16F-series PICs
#byte PIR1 = 0x0C // PIR1 : REGISTERS ASSOCIATED WITH TIMER1 (contains TMR1IF in bit0)
#byte CCPR1_REG = 0x15 // Adress of CCPR1L
#bit TMR1IF = PIR1.0 // TMR1IF
#define BytePtr(var, offset) (char *)((char*)&var + offset)
#define SysClock 20 000 000
#define led PIN_B0
//========Variables=======
//========Routines=======
#int_timer1
void timer1_isr(void)
#int_ccp1
void ccp1_isr(void)
char timer_ext_copy;
int32 current_ccp;
static int32 old_ccp = 0;
current_ccp = (int32)CCPR1_REG; // Read the current CCP
if(TMR1IF)
if(*BytePtr(current_ccp, 1) < 2)
timer_ext_copy++;
float frequency;
int32 current_ccp_delta;
set_timer1(0); // for capture mode CCP1
disable_interrupts(GLOBAL);
if(gc_capture_flag == TRUE)
frequency = ((5000000L + (current_ccp_delta >> 1)) /(float) current_ccp_delta);
printf("%4.2f Hz\n\r", frequency);
printf("No Signal\n\r");
Posted: Sun Mar 21, 2010 5:11 pm |
The problem is in your frequency calculation formula. If you're doing
floating point math, then you don't need the integer round-off stuff in
the formula. The formula just becomes this:
frequency = (5000000L / (float)current_ccp_delta);
Substitute the line above for your frequency calculation line, and it should work. |
Salenko
Posted: Mon Mar 22, 2010 3:54 am |
Hi and thanks PCM,
I've changed the frequency formula , but I'm still getting the same wrong values. |
Posted: Mon Mar 22, 2010 11:46 am |
Somewhere else in the code you posted, you have changed something so that it doesn't work. Instead searching for the problem, I'm just going to post some working code. This code was tested with vs. 4.057 and vs. 4.105.
I set my function generator to give 10 Hz, and I got this output:
| Quote: |
9.99
10.00
10.00
10.00
I set it to put out approximately 20 Hz, and I got this output on the
terminal window:
| Quote: |
20.01
20.00
19.98
19.98
19.99
20.00
19.98
19.98
20.00
Then I set it for 150Hz, and I got this output. Even my scope's frequency
counter jumps around a little bit, so I don't think the B&K function
generator is perfectly stable. In other words, I don't think the variation
below is caused by the PIC program. It's the function generator.
But anyway, it's still very close to 150 Hz.
| Quote: |
149.86
149.94
149.88
149.96
149.92
149.90
150.01
149.96
149.97
149.91
149.97
150.08
Here is the test program:
#include <16F628.h>
#use delay(clock = 20000000)
#byte PIR1 = 0x0C
#int_timer1
#int_ccp1
void ccp1_isr(void)
int32 current_ccp;
current_ccp = (int32)CCP_1;
if(TMR1IF)
if(*BytePtr(current_ccp, 1) < 2) // Was CCP captured after Timer1 wrapped?
timer_ext_copy++; // If so, inc the copy of the timer ext.
// the processor.
// CCP value.
// Save the current ccp value for next time.
float frequency;
set_timer1(0);
current_ccp_delta = g32_ccp_delta;;
printf("%4.2f\n\r", frequency);
printf("No signal\n\r");
Salenko
Posted: Mon Mar 22, 2010 2:10 pm |
Hi PCM,
finally I got a working code !
the error in my code was the use of:
| Code: | #byte CCPR1_REG = 0x15 // Adress of CCPR1L
instead of :
| Code: | | current_ccp = (int32)CCP_1; |
thank you for making a hardware test.  |
vsmguy
Posted: Thu Jul 08, 2010 4:51 am |
| PCM programmer wrote: |
if(TMR1IF)
// the processor.
// CCP value.
I have a question:
I am assuming that CCS clears an interrupt flag ( IF ) *only* after the corresponding ISR has executed.
Hence, in your code ( I am putting only the comment )
// Check if a Timer1 interrupt is pending. If so, check if
// the CCP capture occurred before or after the Timer rolled
// over. We can tell if it occurred after it rolled over, if
// the CCP's MSB is zero. ie., if the CCP is somewhere between
// 0x0000 and 0x00FF.
Is not the check for overflow redundant as the Timer1 IF set inside the CPP1 ISR *implies* that the overflow was not accounted for?
Can there be cases when the ISR for an interrupt has been serviced but its IF is still set? ( only under these circumstances, if any, will your extra check above make sense )
I am sure my assumption is wrong as a lot of people have used your code, so this is really an effort to clear up my understanding :-) |
alextee89
Posted: Sat Apr 02, 2011 2:57 am |
#include <16F628.h>
#byte PIR1 = 0x0C
#int_timer1
#int_ccp1
void ccp1_isr(void)
int32 current_ccp;
if(TMR1IF)
// the processor.
// CCP value.
float frequency;
set_timer1(0);
if i am using 16f877a, izit just change to #include <16F877a.h> ? |
SergioGM17
Posted: Thu Apr 25, 2019 9:01 pm |
Hi!! First of all, sorry to bump this old thread.
Im using this code (ver 5.0xx), almost the same posted above, just using a LCD instead of a rs232, internal clock (4Mhz), to measure low freqs (0-3hz):
| Code: | #include <16F628A.h>
#FUSES NOWDT,NOBROWNOUT,NOLVP,PUT,NOPROTECT
#use delay(internal=4MHz)
//#priority CCP1, TIMER1
#define LCD_ENABLE_PIN PIN_B5
#define LCD_RS_PIN PIN_A4
#define LCD_RW_PIN PIN_B7
#define LCD_DATA4 PIN_B4
#define LCD_DATA5 PIN_B2
#define LCD_DATA6 PIN_B1
#define LCD_DATA7 PIN_B0
#include <LCD.C>
#define BytePtr(var, offset) (char*)((char*)&var + offset)
//#byte CCPR1_REG = 0x15
#byte PIR1 = 0x0c
BOOLEAN gc_capture_flag = FALSE;
#int_timer1
#int_ccp1
void ccp1_isr(void)
int32 current_ccp;
if(TMR1IF)
// the processor.
// CCP value.
float frequency;
set_timer1(0);
frequency = ((1000000L + (current_ccp_delta >> 1)) / (float)current_ccp_delta);
printf(lcd_putc,"%4.2f Hz\n\r", frequency);
// printf("%lu Hz, delta = %lx \n\r", frequency, current_ccp_delta);
/* else
printf(lcd_putc,"No signal\n\r");
I got it working, simulating on Proteus showed the variable freqs. But then I changed something that don't know what it was (apart from changing from int to float), making the simulation show a static value (10, and in float 10.79), and not working as expected. And if I activate the
| Code: | /* else
It jumps to that, even with a signal
Any guess of what it could be?
Thx in advance |
Posted: Fri Apr 26, 2019 12:43 am |
To find the differences between your code and the forum's code:
1. Download ExamDiff from: https://www.prestosoft.com/edp_examdiff.asp
I have been using vs. 1.8 for years. I notice they are now up to vs. 1.9.
2. Make a new folder on your Windows desktop.
3. Copy the forum's code into a text editor and save it as "working.c"
in that folder.
4. Save your code into the same folder as problem.c or whatever you call it.
5. Run Examdiff and select those two files in the new folder to compare.
6. Examdiff will load both and show differences highlighted in yellow.
You can go to the View menu and have it show differences only, if you want.
Now start to undo the changes you made in your program, as you test
which one is causing the problem. |
Joined: 01 Jul 2010 Posts: 9611 Location: Greensville,Ontario
Posted: Fri Apr 26, 2019 5:08 am |
Couple of comments, possible shortcuts to save time and pots of coffee..
Sounds like you always edit the same program, over and over again.
What I do with every PIC project is 1st, create a '1Hz LED' program, get it working then save it. I then copy the source, naming it 'pictype_program_v2.c', where pictype is the type of PIC, program is then name of the project. V2 means version 2.
I then edit the V2 version, compile, burn, test. I then copy v2 --> v3.
I then edit the V3 version,compile,burn, test. I then copy v2 --> v4.
Yes, it mkes for a LOT of files on the harddrive BUT I can go back to any previous version and not lose a day wondering which of the 3 or 4 or ?? changes I made didn't work. I have 1,000s of PIC files on this HD, but tons of room, have yet to 'clean up'.
I do something similar with 'fuses'. Since today's PIC have more fuses than instructions, I create a #INCLUDE file that has EVERY fuse in it, ONE per line, WITH a comment. Once I have the 1Hz LED program running, I save the 'fuses' file as 'pictype_1HZ_fuses.c'. This does 2 things. One, I have a set of known WORKING fuses for basic PIC operation. I copy/edit/save this for project specific requirements. Two, it 'cleans up' the main project. Just one #INCLUDE line not 20-30 lines of fuses information. 3rd, It saves me a LOT of typing AND retyping ! Say you decide to not use the WDT but you forget to type in 'no'WDT. You could spend hours not seeing why 'it worked before but not now'........
SergioGM17
Posted: Thu May 02, 2019 8:52 am |
Hi, thank you for your responses.
Started from zero, with a signal generator + pic + virtual terminal (rs232) and the code worked perfectly.
Now, using with my own input signal, works with the virtual terminal, but when I use the LCD (16x1, LM020L on proteus) on A or B ports, or mixed, it seems like the CCP stops functioning, showing the "no signal" msg.
Adding to that, the #include lcd.c is below the #define pins, and the lcd_init() is on main().
In the meantime I will test with another lcd module.
EDIT: Apparently was a problem with the printf's and something on proteus, seems like it is solved.
TY! |
