karthickiw
| Problem with RS485.... |
Posted: Thu Mar 18, 2010 5:50 am |
Hello CCS Friends,
I try to sending data in between the two PIC micro-controller using RS485. I using Inbuilt driver RS485.c to write the programs for master and salve micro-controller. i use the ISIS software to test the circuit.. but program is not working.. kindly check my program, what mistake i done in program...
Master PIC IC Program
| Quote: |
#include <16F877A.h>
#device *=16
#device adc=8
#FUSES HS //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
#FUSES PUT //Power Up Timer
#FUSES WRT_50% //Lower half of Program Memory is Write Protected
#use rs232(baud=9600,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8,stream=PC)
#include <string.h>
#define RS485_DEST_ID 0x11 //Destination's ID
#define RS485_ID 0x7F
#define RS485_USE_EXT_INT TRUE
#include <rs485.c>
int8 i, msg[32];
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
rs485_init();
Fprintf(PC,"Master Ready\r\n");
While(True)
Output_high(pin_D7);
Delay_ms(500);
Output_low(pin_D7);
Delay_ms(500);
strcpy(msg,"A");
rs485_wait_for_bus(False);
i=1;
while(!rs485_send_message(RS485_DEST_ID, i, msg))
delay_ms(RS485_ID);
} // While Close
Salve PIC IC Program..
| Quote: |
#device *=16
#device adc=8
#define RS485_ID 0x11
#include <rs485.c>
int8 i, msg[32];
setup_adc(ADC_OFF);
setup_vref(FALSE);
rs485_init();
Fprintf(PC,"Salve-01 Ready\r\n");
While(True)
if(rs485_get_message(msg, FALSE)) {
for(i=0; i<msg[1]; ++i)
fputc(msg[i+2], PC);
} // While Close
ISIS Circuit
Humberto
Posted: Thu Mar 18, 2010 7:13 am |
Nobody respond this thread because it does not have an easy/short answer.
Looking at your code and schematic is easy to see some 'beginner mistakes' -do not offend-
Search in this forum you will find very good discusions to read and learn regarding RS485.
Let me suggest you to read them, and if you need further help, ask an specific problem,
not in the way: "why does not function my whole project ".
Regards,
Humberto |
SherpaDoug
Posted: Fri Mar 19, 2010 6:58 am |
It would also help if you could tell as specifically as possible what it does or doesn't do. For example: Does the transmitter send anything? Does the receiver receive anything? Does it receive the wrong thing? Is the first character right? Examples of what you tried to send and what was received, preferably both in hex would help. _________________ The search for better is endless. Instead simply find very good and get the job done. |
arunb
| RE: |
Posted: Sat Mar 20, 2010 4:21 am |
The #use RS232 directive does not contain the enable option, this is essential to enable and disable transmission and reception of data.
Is the RS485.c file same as the one in the PICC folder ??
thanks
arunb |
karthickiw
| Re: RE: |
Posted: Sun Mar 21, 2010 12:02 am |
| arunb wrote: | The #use RS232 directive does not contain the enable option, this is essential to enable and disable transmission and reception of data.
thanks
arunb
Hi Arun,
I use inbuilt driver(RS485.C) for RS485. I don't understand your point. I connect circuit as per driver file of RS485.C. |
Humberto
Posted: Mon Mar 22, 2010 8:46 am |
The point is, in your code there is not any code to handle the enable Rx/Tx pins
of the SN75176 transciever. Remember that a with single loop in RS485, you are able to
run in Half Duplex Mode only, that is:
If you activate the transmit enable pin, you can transmit but as soon as you end the transmition,
you must disable it in order to release the line and set the transceiver for Rx listening, that
is the state to receive data in the loop.
A workaround regarding this is to wire both control pins (2 and 3) to an output PIC
pin and use the option ENABLE in the #use RS232 directive to tell the compiler that
you are using an RS485 transceiver, then let the compiler to generate the appropiate
code to handle the communication direction control.
http://www.ccsinfo.com/forum/viewtopic.php?t=33778
http://www.ccsinfo.com/forum/viewtopic.php?t=39115
http://www.ccsinfo.com/forum/viewtopic.php?t=33914
Regards,
Humberto |
