Problem with LCD
cenadius
PostPosted: Sat Mar 13, 2010 9:25 pm     Reply with quote
Hi, I am using pic18f452 with 20MHz crystal. I am using PortB for my LCD, but my LCD display still didn't display anything although it compiles with no errors.
// flex_lcd.c
// These pins are for the Microchip PicDem2-Plus board,
// which is what I used to test the driver.  Change these
// pins to fit your own board.
#define LCD_DB4   PIN_B2 <-- i have change the port to my connection
#define LCD_DB5   PIN_B3 <--i have change the port to my connection
#define LCD_DB6   PIN_B4 <--i have change the port to my connection
#define LCD_DB7   PIN_B5 <--i have change the port to my connection
#define LCD_E     PIN_B1 <--i have change the port to my connection
#define LCD_RS    PIN_B0 <--i have change the port to my connection
//#define LCD_RW    PIN_A2 <-- do i need comment out this? my R/W is connected to ground
// If you only want a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.
//#define USE_LCD_RW   1
My main program for testing is as follows:
#include <18F452.H>
#use delay(clock = 20000000)
#include "flex_lcd.c"
lcd_init();  // Always call this first.
lcd_putc("Hello World");
Pls help me check is there any wrong?
My LCD display is in good condition.
PostPosted: Sat Mar 13, 2010 10:25 pm     Reply with quote
#include <18F452.H>
The HS fuse is required for a 20 MHz crystal. It won't oscillate with the
XT fuse.
cenadius
PostPosted: Sat Mar 13, 2010 10:46 pm     Reply with quote
#fuses HSPLL, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
so i change the XT fuse to HS, ok i get it.
thank you very much.
