Making a menu with 3 buttons and a LCD
Ezequiel
PostPosted: Sun Feb 02, 2003 5:40 am     Reply with quote
Sorry for the question, but I'm a newbie in PIC C (I used to program with a PBASIC Compiler, but I realized C was much better). I have to make a rutine that scan for 3 buttons, UP, DOWN and SELECT. So with UP and DOWN you choose a option from a menu (written in a LCD using LCD.C) If a have 5 options in my menu, the rutine shows the first one, with UP the rutine shows the last one, and with DOWN it shows the next one. When you press SELECT, it calls a Subrutine and BREAK the loop.
Thank you very very much
Zeke
___________________________
Original Post ID: 11196
Re: Making a manu with 3 buttons and a LCD
PostPosted: Mon Feb 03, 2003 12:42 pm     Reply with quote
:=Hello,
:= Sorry for the question, but I'm a newbie in PIC C (I used to program with a PBASIC Compiler, but I realized C was much better). I have to make a rutine that scan for 3 buttons, UP, DOWN and SELECT. So with UP and DOWN you choose a option from a menu (written in a LCD using LCD.C) If a have 5 options in my menu, the rutine shows the first one, with UP the rutine shows the last one, and with DOWN it shows the next one. When you press SELECT, it calls a Subrutine and BREAK the loop.
:=Thank you very very much
:=Zeke
<a href="http://www.pic-c.com/forum/general/posts/6702.html" TARGET="_blank">http://www.pic-c.com/forum/general/posts/6702.html</a>
Original Post ID: 11237
