control led and pwm..
zack
PostPosted: Tue Feb 23, 2010 6:30 am     Reply with quote
how i want to make my led flashing for 30 seconds...what is the command that i need to use..
what is the command to control the pwm for dc motor...
i want to control 3 different speed which will increase from slow until it reach the desire speed...
i use PIC 16f877A...
help me please...thank you...
Gabriel
PostPosted: Tue Feb 23, 2010 7:01 am     Reply with quote
To flash the LED
int i=0;
While(i<30)
   Output_high(PIN_D1);
   Delay_ms(500);
   Output_low(PIN_D1);
   Delay_ms(500);
   i++;
That should flash your led for 30 secs....
As for the PWM.... I can't help you there. I only used sofware PWMs for RGB LED control not motors.
g
CCS PCM 5.078 & CCS PCH 5.093
jaimechacoff
PostPosted: Tue Feb 23, 2010 12:16 pm     Reply with quote
I believe you need a speed ramp.
look on google Trapezoidal Ramp, furthermore, PCM programmer gave us an example about it:
http://www.ccsinfo.com/forum/viewtopic.php?t=41473&start=3
good luck.
zack
PostPosted: Wed Feb 24, 2010 3:24 am     Reply with quote
Alright...thank you guys...I really appreciate that... Very Happy
