onionrack Guest
Different levels of indirection |
Posted: Sun Feb 14, 2010 4:49 pm |
I am trying to pass variable arrays from a function, but get the compile error 105 Different levels of indirection. The same code works in Visual C++. Is this me, or a compiler 4.104 fault please? I've tried PCH and PCD with same result:
#use rs232(UART1,baud=9600,parity=N,bits=8)
int can=1;
void my_function(unsigned int &one, unsigned int *two){
one=69;
two[0]=2;
two[1]=3;
two[2]=7;
unsigned int three[4];
unsigned int two[4][8];
my_function(three[can],two[can]);
three[0]=999;
printf("%u %u %u %u %u",three[0], three[1], two[can][0], two[can][1], two[can][2]);
while(true);
Thank you! |
Posted: Sun Feb 14, 2010 8:33 pm |
Quote: | The same code works in Visual C++. |
CCS is not C++. If you compile your program as a .c file in
Visual C++ then you get errors.
I tested this with MSVC++ 6.0. |
tinley
Posted: Mon Feb 15, 2010 3:07 am |
Thanks PCM P,
I am aware that C is not C++, but the syntax I have used is C ANSI/ISO according to 'C The Complete Reference', so should work.
Can you or anyone suggest a workaround to pass variable arrays please. I don't really want to re-write the function, as it is the standard can_getd() from the CCS can-dsPIC30.c
Thanks! |
Posted: Mon Feb 15, 2010 3:32 am |
You're following the bad habbit not to tell, which line of code and partial expression gives the error.
The problem occurs when the "Reference Parameter" argument unsigned int &one is supplied with a
non-constant array element, don't know why. The problem isn't specific to V4.104 however. It's no standard
C Syntax, so I don't use it in my code. You can use a C standard pointer unsigned int *one instead.
P.S.: I understand, that you're problem is in the extensive usage of "reference parameters" in the
CCS supplied can driver. Personally, I would rewrite the driver code.
Furthermore, the problem is a basic restriction of the CCS "reference parameter" concept. It doesn't work
with variable array elements, because it uses an absolute variable address in the function code
instead of a pointer. |
tinley
Posted: Mon Feb 15, 2010 4:30 am |
Thanks FvM,
Your input gives good insight and at this point I shall modify the CCS can library so it does what I want! There are many badly documented aspects of this 'nearly' C compiler, especially the PCD version, so thanks to this forum and your time!
Sorry for my bad habits... oversight, not intention.
Cheers |
Posted: Mon Feb 15, 2010 5:26 am |
CCS, is very close to 'C' (original K&R version). What it misses (still), is getting close to 'ANSI C'....
I'd reckon that 99.5% of C constructs work with CCS, but perhaps only about 90% of ANSI C constructs, especially more 'complex' steps like reference parameters, work 'fully'....
If you stick to original C syntax, CCS is a lot easier to use!...
Some of it is still to do with hardware. In this example, CCS are trying to save complexity in the code, by 'pre-solving' at compile time, the reference parameters. Works well for constant parameters, but makes variable ones effectively a 'no-no'. Advantage smaller code size, but reduces flexibility. :(
Posted: Mon Feb 15, 2010 8:25 am |
When you say, reference parameter is an ANSI C feature, can tell which clause of the specification defines it? I couldn't find it yet. |
