| I2C Locks up after reset |
Posted: Tue Feb 09, 2010 2:01 pm |
I’m currently working on a data logger that uses an 18f4620, one DS2482-800 one-wire hub and several ds18b20 temperature probes. The I2C and OW bus seem to work just fine after a power on reset. The trouble is that it appears to get stuck in a infinite loop at the “#use i2c(MASTER, SCL=PIN_C3, SDA=PIN_C4, FORCE_HW)” line of code anytime I perform a reset and run it in mplab using my ICD2. I’m using an 8mhz can oscillator with the pll set to h4.
Here is the main.h file code:
#include <18F4620.h>
#fuses EC,H4,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT,NOPUT,NOPBADEN,NOPROTECT,DEBUG
#use delay(clock=32000000)
#use standard_io(e)
// use hardware i2c controller
[b]And the main.c code up to the point it hangs:[/b]
#device PIC18F4620
#include "main.h"
#include "Flex_LCD420.c"
#include "DS2482.h"
unsigned char a, error_code=0;
//Setup internal controller peripherals
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
//setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
setup_wdt(wdt_off);
//setup_power_pwm_pins(pwm_off, pwm_off, pwm_off);
//setup_power_pwm(pwm_off);
lcd_init(); //LCD is ready for data
lcd_gotoxy(1,1);
printf(lcd_putc,"Welcome" );
//#use i2c(MASTER, SCL=PIN_C3, SDA=PIN_C4, FORCE_HW) // use hardware i2c controller
OUTPUT_FLOAT(PIN_C3);
OUTPUT_FLOAT(PIN_C4);
if (a=(!DS2482_detect(DS2482_Base_Addr)))
Anyone have a quote why this is happening?
Thanks Much! |
Posted: Tue Feb 09, 2010 2:05 pm |
What happens if you don't run it in MPLAB with the ICD2 debugger ?
What if you run it as a standalone program ? Does it still lock up ? |
Posted: Tue Feb 09, 2010 4:48 pm |
I tried it without the ICD2. It wouldn’t run at all. Either I inadvertently changed something in the code or there really is something strange going on. Now it won’t work with the ICD2 after Powerup. The driver code I wrote for the DS2482-800 was based on Dallas’s ap note 3684. It would be nice if there was a driver out there for CCS. I’ll keep plugging away at it. Hopefully the problem will show up. I forgot to mention the DS2482 is on a separate board. The symptoms didn’t change with or without it plugged in.
Thanks |
Posted: Tue Feb 09, 2010 6:29 pm |
Do you have 4.7K pullup resistors on the SDA and SCL lines ?
There is a schematic on the first page of the ds2482 data sheet
which shows how to connect the pullups. Also, do you have the
AD0-AD2 pins connected to ground, as shown in the schematic ?
http://datasheets.maxim-ic.com/en/ds/DS2482-800.pdf
If that doesn't help, then post your ds2482 driver. |
| DS2482 Code Help Needed |
Posted: Thu Feb 11, 2010 9:41 am |
Sorry for the delay, I’ve been out with the bug. All the address lines on the DS2482 are tried to ground and I’m using 2.2k pull-ups on both I2C pins. I’m posting my driver code. Hopefully someone can find the bug in it. If not it should be a good start for someone to use to derive their own driver. There is definitely something unstable with the code or hardware. Without touching either one from the last time I posted, it now works but only after a power up reset as before! The code goes out and resets the DS2482. It performs a channel change to IO1 looks at the one wire bus and correctly reports the presence of a device on the port. I’m also going to include the balance of the main code not posted previously. This is from the point past where it hangs the second time though.
Thanks Much!
DS2482 Driver code:
| Code: | //DS2482.h
//DS2482-800 device driver
//Code is based on Dallas App Note # 3684
//function headers:
int DS2482_reset(void);
int DS2482_write_config(unsigned char);
unsigned char OWTouchBit(unsigned char);
unsigned char OWTouchByte(unsigned char);
unsigned char DS2482_search_triplet(search_direction);
int OWReset(void);
int OWSearch(void);
//void calc_crc8(void);
//Global Variables / Defines:
unsigned char I2C_WRITE= 0;
unsigned char I2C_READ= 1;
#define DS2482_Base_Addr 0x30 //Address of DS2482 on I2C Buss if pins 6, 7 and 8 are tried low
#define NACK 0
#define ACK 1
#define STATUS_1WB 0b00000001
#define STATUS_PPD 0b00000010
#define STATUS_SD 0b00000100
#define STATUS_LL 0b00001000
#define STATUS_RST 0b00010000
#define STATUS_SBR 0b00100000
#define STATUS_TSB 0b01000000
#define STATUS_DIR 0b10000000
#define POLL_LIMIT 16 //Number of time to retry OW Buss Scan Waiting to unbusy it self
unsigned char CMD_DRST=0XF0;
unsigned char CMD_WCFG=0XD2;
unsigned char CMD_CHSL=0XC3;
unsigned char CMD_SRP=0XE1;
unsigned char CMD_1WRS=0XB4;
unsigned char CMD_1WWB=0XA5;
unsigned char CMD_1WRB=0X96;
unsigned char CMD_1WSB=0X87;
unsigned char CMD_1WT=0X78;
// DS2482 state
unsigned char I2C_address;
int c1WS, cSPU, cPPM, cAPU, CONFIG_APU=0x01;
int short_detected;
// DS2482 Detect routine that sets the I2C address and then performs a
// device reset followed by writing the configuration byte to default values:
// 1-Wire speed (c1WS) = standard (0)
// Strong pullup (cSPU) = off (0)
// Presence pulse masking (cPPM) = off (0)
// Active pullup (cAPU) = on (CONFIG_APU = 0x01)
// Returns: TRUE if device was detected and written
// FALSE device not detected or failure to write configuration byte
int DS2482_detect(unsigned char addr)
// set global address
I2C_address = addr;
// reset the DS2482 ON selected address
if (!DS2482_reset())
return FALSE;
// default configuration
c1WS = FALSE;
cSPU = FALSE;
cPPM = FALSE;
cAPU = CONFIG_APU;
// write the default configuration setup
if (!DS2482_write_config(c1WS | cSPU | cPPM | cAPU))
return FALSE;
return TRUE;
// Perform a device reset on the DS2482
// Returns: TRUE if device was reset
// FALSE device not detected or failure to perform reset
unsigned char status;
// Device Reset
// S AD,0 [A] DRST [A] Sr AD,1 [A] [SS] A\ P
// [] indicates from slave
// SS status byte to read to verify state
I2C_start();
I2C_write(I2C_address | I2C_WRITE);
I2C_write(CMD_DRST);
I2C_start();
I2C_write(I2C_address | I2C_READ);
status = I2C_read(NACK);
I2C_stop();
// check for failure due to incorrect read back of status
return ((status & 0xF7) == 0x10);
// Write the configuration register in the DS2482. The configuration
// options are provided in the lower nibble of the provided config byte.
// The uppper nibble in bitwise inverted when written to the DS2482.
// Returns: TRUE: config written and response correct
// FALSE: response incorrect
int DS2482_write_config(unsigned char config)
unsigned char read_config;
// Write configuration (Case A)
// S AD,0 [A] WCFG [A] CF [A] Sr AD,1 [A] [CF] A\ P
// CF configuration byte to write
I2C_start();
I2C_write(CMD_WCFG);
I2C_write(config | (~config << 4));
I2C_start();
read_config = I2C_read(NACK);
I2C_stop();
if (config != read_config)
// handle error
DS2482_reset();
return FALSE;
return TRUE;
// Select the 1-Wire channel on a DS2482-800.
// Returns: TRUE if channel selected
// FALSE device not detected or failure to perform select
int DS2482_channel_select(int channel)
unsigned char ch, ch_read, check;
// Channel Select (Case A)
// S AD,0 [A] CHSL [A] CC [A] Sr AD,1 [A] [RR] A\ P
// CC channel value
// RR channel read back
I2C_start();
I2C_write(CMD_CHSL);
switch (channel)
default: case 0: ch = 0xF0; ch_read = 0xB8; break;
case 1: ch = 0xE1; ch_read = 0xB1; break;
case 2: ch = 0xD2; ch_read = 0xAA; break;
case 3: ch = 0xC3; ch_read = 0xA3; break;
case 4: ch = 0xB4; ch_read = 0x9C; break;
case 5: ch = 0xA5; ch_read = 0x95; break;
case 6: ch = 0x96; ch_read = 0x8E; break;
case 7: ch = 0x87; ch_read = 0x87; break;
I2C_write(ch);
I2C_start();
check = I2C_read(NACK);
I2C_stop();
// check for failure due to incorrect read back of channel
return (check == ch_read);
// Reset all of the devices on the 1-Wire Net and return the result.
// Returns: TRUE(1): presence pulse(s) detected, device(s) reset
// FALSE(0): no presence pulses detected
int OWReset(void)
int poll_count = 0;
// 1-Wire reset
// S AD,0 [A] 1WRS [A] Sr AD,1 [A] [Status] A [Status] A\ P
I2C_start();
I2C_write(CMD_1WRS);
I2C_start();
status = I2C_read(ACK);
do
status= I2C_read(ACK);
// status = (status & STATUS_1WB);
while ((status & STATUS_1WB) && (poll_count++ < POLL_LIMIT));
I2C_stop();
// check for failure due to poll limit reached
if (poll_count >= POLL_LIMIT)
// handle error
//lcd_gotoxy(1,1);
// print(lcd_putc,"OW pole timed out");
DS2482_reset();
return FALSE;
// check for short condition
if (status & STATUS_SD)
short_detected = TRUE;
short_detected = FALSE;
// check for presence detect
if (status & STATUS_PPD)
return TRUE;
return FALSE;
// Send 1 bit of communication to the 1-Wire Net.
// The parameter 'sendbit' least significant bit is used.
// 'sendbit' - 1 bit to send (least significant byte)
void OWWriteBit(unsigned char sendbit)
OWTouchBit(sendbit);
// Reads 1 bit of communication from the 1-Wire Net and returns the
// result
// Returns: 1 bit read from 1-Wire Net
unsigned char OWReadBit(void)
return OWTouchBit(0x01);
// Send 1 bit of communication to the 1-Wire Net and return the
// result 1 bit read from the 1-Wire Net. The parameter 'sendbit'
// least significant bit is used and the least significant bit
// of the result is the return bit.
// 'sendbit' - the least significant bit is the bit to send
// Returns: 0: 0 bit read from sendbit
// 1: 1 bit read from sendbit
unsigned char OWTouchBit(unsigned char sendbit)
int poll_count = 0;
// 1-Wire bit (Case B)
// S AD,0 [A] 1WSB [A] BB [A] Sr AD,1 [A] [Status] A [Status] A\ P
// Repeat until 1WB bit has changed to 0
// BB indicates byte containing bit value in msbit
I2C_start();
I2C_write(CMD_1WSB);
I2C_write(sendbit ? 0x80 : 0x00);
I2C_start();
// loop checking 1WB bit for completion of 1-Wire operation
// abort if poll limit reached
do
status = I2C_read(status & STATUS_1WB);
I2C_stop();
// handle error
DS2482_reset();
return 0;
// return bit state
if (status & STATUS_SBR)
return 1;
return 0;
// Send 8 bits of communication to the 1-Wire Net and verify that the
// 8 bits read from the 1-Wire Net are the same (write operation).
// The parameter 'sendbyte' least significant 8 bits are used.
// 'sendbyte' - 8 bits to send (least significant byte)
// Returns: TRUE: bytes written and echo was the same
// FALSE: echo was not the same
void OWWriteByte(unsigned char sendbyte)
int poll_count = 0;
// 1-Wire Write Byte (Case B)
// S AD,0 [A] 1WWB [A] DD [A] Sr AD,1 [A] [Status] A [Status] A\ P
// DD data to write
I2C_start();
I2C_write(CMD_1WWB);
I2C_write(sendbyte);
I2C_start();
do
I2C_stop();
// handle error
DS2482_reset();
// Send 8 bits of read communication to the 1-Wire Net and return the
// result 8 bits read from the 1-Wire Net.
// Returns: 8 bits read from 1-Wire Net
unsigned char OWReadByte(void)
unsigned char data, status;
int poll_count = 0;
// 1-Wire Read Bytes (Case C)
// S AD,0 [A] 1WRB [A] Sr AD,1 [A] [Status] A [Status] A\
// Sr AD,0 [A] SRP [A] E1 [A] Sr AD,1 [A] DD A\ P
// DD data read
I2C_start();
I2C_write(CMD_1WRB);
I2C_start();
do
// handle error
DS2482_reset();
return 0;
I2C_start();
I2C_write(CMD_SRP);
I2C_write(0xE1);
I2C_start();
data = I2C_read(NACK);
I2C_stop();
return data;
// The 'OWBlock' transfers a block of data to and from the
// 1-Wire Net. The result is returned in the same buffer.
// 'tran_buf' - pointer to a block of unsigned
// chars of length 'tran_len' that will be sent
// to the 1-Wire Net
// 'tran_len' - length in bytes to transfer
void OWBlock(unsigned char *tran_buf, int tran_len)
int i;
for (i = 0; i < tran_len; i++)
tran_buf[i] = OWTouchByte(tran_buf[i]);
// Send 8 bits of communication to the 1-Wire Net and return the
// result 8 bits read from the 1-Wire Net. The parameter 'sendbyte'
// least significant 8 bits are used and the least significant 8 bits
// of the result are the return byte.
// Returns: 8 bits read from sendbyte
unsigned char OWTouchByte(unsigned char sendbyte)
if (sendbyte == 0xFF)
return OWReadByte();
OWWriteByte(sendbyte);
return sendbyte;
// Search state
unsigned char ROM_NO[8];
int LastDiscrepancy;
int LastFamilyDiscrepancy;
int LastDeviceFlag;
unsigned char crc8;
// Find the 'first' devices on the 1-Wire network
// Return TRUE : device found, ROM number in ROM_NO buffer
// FALSE : no device present
int OWFirst()
// reset the search state
LastDiscrepancy = 0;
LastDeviceFlag = FALSE;
LastFamilyDiscrepancy = 0;
return OWSearch();
// Find the 'next' devices on the 1-Wire network
// FALSE : device not found, end of search
int OWNext()
// leave the search state alone
return OWSearch();
// The 'OWSearch' function does a general search. This function
// continues from the previous search state. The search state
// can be reset by using the 'OWFirst' function.
// This function contains one parameter 'alarm_only'.
// When 'alarm_only' is TRUE (1) the find alarm command
// 0xEC is sent instead of the normal search command 0xF0.
// Using the find alarm command 0xEC will limit the search to only
// 1-Wire devices that are in an 'alarm' state.
// Returns: TRUE (1) : when a 1-Wire device was found and its
// Serial Number placed in the global ROM
// FALSE (0): when no new device was found. Either the
// last search was the last device or there
// are no devices on the 1-Wire Net.
int OWSearch(void)
int id_bit_number;
int last_zero, rom_byte_number, search_result;
int id_bit, cmp_id_bit;
unsigned char rom_byte_mask, search_direction, status;
// initialize for search
id_bit_number = 1;
last_zero = 0;
rom_byte_number = 0;
rom_byte_mask = 1;
search_result = FALSE;
crc8 = 0;
// if the last call was not the last one
if (!LastDeviceFlag)
// 1-Wire reset
if (!OWReset())
// reset the search
return FALSE;
// issue the search command
OWWriteByte(0xF0);
// loop to do the search
do
// if this discrepancy if before the Last Discrepancy
// on a previous next then pick the same as last time
if (id_bit_number < LastDiscrepancy)
if ((ROM_NO[rom_byte_number] & rom_byte_mask) > 0)
search_direction = 1;
search_direction = 0;
// if equal to last pick 1, if not then pick 0
if (id_bit_number == LastDiscrepancy)
// Perform a triple operation on the DS2482 which will perform
// 2 read bits and 1 write bit
status = DS2482_search_triplet(search_direction);
// check bit results in status byte
id_bit = ((status & STATUS_SBR) == STATUS_SBR);
cmp_id_bit = ((status & STATUS_TSB) == STATUS_TSB);
search_direction =((status & STATUS_DIR) == STATUS_DIR) ? (byte)1 : (byte)0;
// check for no devices on 1-Wire
if ((id_bit) && (cmp_id_bit))
if ((!id_bit) && (!cmp_id_bit) && (search_direction == 0))
last_zero = id_bit_number;
// check for Last discrepancy in family
if (last_zero < 9)
LastFamilyDiscrepancy = last_zero;
// set or clear the bit in the ROM byte rom_byte_number
// with mask rom_byte_mask
if (search_direction == 1)
ROM_NO[rom_byte_number] |= rom_byte_mask;
ROM_NO[rom_byte_number] &= (byte)~rom_byte_mask;
// increment the byte counter id_bit_number
// and shift the mask rom_byte_mask
id_bit_number++;
rom_byte_mask <<= 1;
// if the mask is 0 then go to new SerialNum byte rom_byte_number
// and reset mask
if (rom_byte_mask == 0)
//calc_crc8(ROM_NO[rom_byte_number]); // accumulate the CRC
rom_byte_number++;
rom_byte_mask = 1;
while(rom_byte_number < 8); // loop until through all ROM bytes 0-7
// if the search was successful then
if (!((id_bit_number < 65) || (crc8 != 0)))
// search successful so set LastDiscrepancy,LastDeviceFlag
// search_result
LastDiscrepancy = last_zero;
// check for last device
if (LastDiscrepancy == 0)
LastDeviceFlag = TRUE;
search_result = TRUE;
// if no device found then reset counters so next
// 'search' will be like a first
if (!search_result || (ROM_NO[0] == 0))
return search_result;
[b]Balance of main code:[/b]
error_code=error_code | no_DS2482_detected;
lcd_gotoxy(1,4);
printf(lcd_putc,"No DS2482");
lcd_gotoxy(1,2);
printf(lcd_putc,"DS2482 configured");
if(DS2482_channel_select(1))
lcd_gotoxy(1,3);
printf(lcd_putc,"Port 1 selected");
lcd_gotoxy(1,3);
printf(lcd_putc,"Port 1 not selected");
if (OWReset())
lcd_gotoxy(1,4);
printf(lcd_putc,"OW Device Found");
lcd_gotoxy(1,4);
printf(lcd_putc,"No OW Device Found");
lcd_clr();
while (1)
while (1)
Posted: Thu Feb 11, 2010 12:31 pm |
Do some tests:
1. Remove the H4 fuse and run the PIC at 8 MHz. Edit the #use delay()
statement to be for 8 MHz.
2. Remove the FORCE_HW parameter from your #use i2c() statement,
so the program is using software i2c.
3. Test i2c operation with a more simple chip, such as an i2c eeprom.
Put the eeprom on a separate board, just like the ds2482.
4. Put the ds2432 on the same board as the PIC, using the same
power supply as the PIC.
The above tests will check if there is something flakey about:
1. PLL mode.
2. Hardware i2c mode.
3. The ds2482 chip or the driver.
4. Using a separate board with a separate power supply. |
Posted: Thu Feb 11, 2010 1:08 pm |
Thanks for the ideas.
I'll give it a try!
Thanks Much |
