madhu Guest
| 18f97j60 3v and rs232 5v |
Posted: Sat Feb 06, 2010 12:55 am |
Dar friends,
My hardware is PIC18f97j60 with 3.3v and rs232 with 5v supply whether it works or not. Please help me. |
arunb
| re: |
Posted: Sat Feb 06, 2010 1:43 am |
how is the voltage translation done, between 3.3 V to 5 V and vice-versa ??
thanks
arunb |
madhu Guest
Posted: Sat Feb 06, 2010 2:22 am |
hi,
u mean it should be either 5V or 3.3V supply voltage for both. |
bkamen
Joined: 07 Jan 2004 Posts: 1617 Location: Central Illinois, USA
Posted: Sat Feb 06, 2010 10:03 am |
why not use a 3.3volt capable rs232 interface IC like the MAX3232?
asmallri
Joined: 12 Aug 2004 Posts: 1660 Location: Perth, Australia
| Re: 18f97j60 3v and rs232 5v |
Posted: Sat Feb 06, 2010 10:20 am |
| madhu wrote: | Dar friends,
It will work but as already suggest, a 3.3V RS232 converter would be a better fit electrically between the PIC and the transceiver however a +5V RS232 would provide a better solution for RS232 because of the high signal level and therefore better signal to noise ratio. _________________ Regards, Andrew
bkamen
Posted: Sat Feb 06, 2010 10:47 am |
huh??
The max3232 still puts out about 10V on the RS232 side running at 3.3 or 5. _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D |
asmallri
Posted: Sun Feb 07, 2010 9:31 pm |
| bkamen wrote: | huh??
The max3232 still puts out about 10V on the RS232 side running at 3.3 or 5. |
Not on the test boards I have. _________________ Regards, Andrew
bkamen
Posted: Sun Feb 07, 2010 9:36 pm |
| asmallri wrote: | | bkamen wrote: | huh??
Not on the test boards I have. |
Funky. The spec reads +/-5 5 for a 10V swing.
Good to know.
Those spec sheets... they LIE... ;)
